View Full Version : 5.0 Mustang
  1. T5 Slip yoke play (how much)
  2. 95 Exhaust question
  3. idle problem 92 5.0L efi convertible
  4. Auto Specialties A/C delete kit
  5. Stock Ported Heads and Intake questions
  6. 30# injectors
  7. Idle surge and sluggish driving me crazy
  8. WHAT INJECTORS DO I HAVE?????
  9. Water Pump Question
  10. Clutch recomendations
  11. 94 gt auto trans question
  12. transgo shift kit
  13. Turn signal/electrical question
  14. Computer Help
  15. where do I start?!!
  16. A/C problem
  17. Stahl Problems!!!
  18. Hi everyone
  19. bolt size rear upper control arm
  20. 90 vert rear window motors
  21. front end vibration?
  22. idling/stalling issue when gas is applied
  23. z303 cam in explorer 5.0 block
  24. Rear rotor replacement, noticed large amount of axle play....WTF?
  25. buildin a 302 lookin for a power estimate
  26. engine turns but doesn't start
  27. HELP TV CABLE ADJUSTMENT!!!!!
  28. How Far is To Far
  29. Code 72?
  30. not revving over 4000rpm in new 331
  31. what pistons?
  32. Clutch wont engage
  33. c6 in a fox?
  34. Speedo gear?
  35. weird vibration
  36. wont start when hot
  37. electric fan question
  38. t5 tranny question
  39. Clutch Pedal Effort
  40. Can I unhook the egr?
  41. What size MAF and injectors?
  42. Afr 165's
  43. MAF Sensor...?
  44. gt40 heads, intake
  45. KOER code 21...ECT sensor
  46. Questions on aftermarket parts
  47. 1986 GT 5.0 REAR BUMPER
  48. PCD Chips
  49. Oil Dipstick
  50. 347 build thoughts
  51. help with selecting timing set and oil pump
  52. Driveshaft vibration after clutch swap
  53. Electric fan?
  54. going with manual steering
  55. budget ls1 killer?
  56. Thermostat Issues!!
  57. Mystery Problem
  58. Questions on my alt. and ele. fan...
  59. puttting a 302 in a 96
  60. Need Help PLZ!!!!!!!!!!!!!!!!!!!!
  61. Breaking in clutch? help please
  62. 347 stoker problems
  63. z303 cam
  64. new driver/owner? budget
  65. miss under light load
  66. Oxidized Aluminum
  67. manual trans fluid
  68. Who knows whats up with this clutch?
  69. bad hesitation after freeze plug replacement
  70. EGR block off
  71. Quick Question about exhaust cut offs!!!
  72. AODE and 4R70W Valve bodies
  73. antifreeze problems
  74. 1985 mustang amp bypass help!
  75. Broken valve cover bolt in head
  76. vortech how much boost on 306?
  77. 352 a good block? Just curious?
  78. Suttering, and sometimes death
  79. truck motor?
  80. 6al vs. 6al-2
  81. tv cable adjustment
  82. Transmission Problem?
  83. T Stat Question??
  84. Are ported E7TE heads w/ GT-40 valve train worth it?
  85. cam thrust plate
  86. new supercharger
  87. 88 Mustang runs terrible!
  88. Help need suggestions
  89. storing longblock
  90. where's the thermostat???
  91. Head ???
  92. Crane cams fireball HI-6 any good?
  93. Question On Pulling Codes
  94. New and need some performance tips
  95. misfire for awhile then died, elec problems
  96. help installing electric water pump
  97. Which TB is this?
  98. what ignition module to choose
  99. Temp Sensor
  100. 89 INTAKE ON A 95 302
  101. best s/c
  102. HELP I JUST INSTALLED CAMSHAFT
  103. trans ideas?
  104. Weird headers won't seal
  105. V8 Spindles - what's going on here???
  106. Cruise Control ?
  107. New Alternator won't fit
  108. Control Arm Issues
  109. who makes 3.5" or longer wheel studs
  110. 1995 Gt starting issues
  111. c6 and BB
  112. 5.0 Generation Swap?
  113. Clutch Cable?
  114. Starter problem
  115. installing new mass air meter
  116. Pulley driving me nuts / Other issues
  117. Tires
  118. engine locked up
  119. 5.0L engine swap help
  120. 1992 LX 5.0 Convertible rear suspension
  121. yet another MAF question
  122. head install question
  123. gear install
  124. question about changing my gears
  125. Boost
  126. Need help with clutch decision
  127. Tuning Nitrous on a Carb
  128. Coolant problems!!
  129. car wont stay running
  130. 5.0 fuel pressure problem
  131. Help... with thrird brake light harness
  132. USED AFR 165 HEADS (ON BUDGET)
  133. Need Advice plz
  134. Control Arms
  135. Adj Clutch Cable Installation Q's.
  136. tire question
  137. gears
  138. wut shocks to run street/strip
  139. 302 transmission mating question.
  140. 5.0 gods, I call upon thee....
  141. Mass Air Meter and ERG Plate
  142. What parts can I use off of an '94 Taurus SHO?
  143. Have codes?
  144. wtf is up with my trans
  145. tuning
  146. 3G Alternator Conversion Question
  147. Transmission Help...please!
  148. Rear Tires
  149. Removing Wheel Locks and Replacing 6 Piece Headlights
  150. can i put 95 axles on an 88.....
  151. 95 gt computer
  152. Steeda Clutch Quadrant Install Problems
  153. 94 gt tranny
  154. cleaning fuel injectors
  155. How to tell if T5 is good with it out of car
  156. Easy Question
  157. Where to connect gauge pack (oil psi and temp)
  158. k member problem
  159. Speedometer Problem
  160. Nitrous on stock internals
  161. Over heating - With VID!
  162. Double checkin' on smog delete...
  163. Mustang issues
  164. goin to the junk yard
  165. Need help with timing...?
  166. still hesitating!!
  167. car wont scan
  168. Hey need help with 87 gt
  169. (new?) Edelbrock Pro-flo XT manifold
  170. starter vs solenoid
  171. Torque Boxes
  172. E-brake question
  173. Rearend Seal Problem
  174. Mass air conversion
  175. buying heads and cams
  176. Rim & Slick Combo ?
  177. Motor build questions
  178. 4banger Turbos vs. 89 Mustang
  179. Broken crank bolt
  180. hyrdaulic, roller....
  181. Opinions on fine tuning my setup
  182. lost 5th gear
  183. aod noises
  184. What cam
  185. lil help choosing an intake?
  186. Gasket Sets
  187. my turbo build
  188. new member
  189. mini tubs, 6 point cage rear seat?
  190. hesitation and some backfiring in 1st
  191. Will a ported intake work well with unported heads?
  192. Need injector and MAF/TB sizing suggestion for 393 stroker
  193. E7/GT40 valve question
  194. Still having crazy idle problems!
  195. '94 stang ele. fan...
  196. cobra rockers vs svo rockers
  197. centrifigual blower question
  198. Steering wheel
  199. Sensor going to oil pan
  200. something is drawing power
  201. exaust manifold gasket for p headers
  202. 93' fox loud valvetrain
  203. Engine building 101...project semi-n00b
  204. need 94 gt help please
  205. Dyno Charts
  206. put all back together still knocking
  207. unanswered conversion ???
  208. taking off intake again!!!!!!!!!!!!!
  209. Wheel hop
  210. 88 GT crashed and won't start
  211. What does everyone do for e-brake afte 5 lug?
  212. Clunking in exhaust
  213. Carb Wiring set-up
  214. t5 out of Thunderchicken turbo coupe?
  215. 93....posi?
  216. Rev limiter on 94 GT
  217. 5.0 Block questions
  218. 306 build
  219. Turn Signals Inop.
  220. 92 5.0 won't start
  221. Efi to carb swap question
  222. New to the fox game, beginner questions.
  223. one or two piece main seal?
  224. Will MAC LTs fit gt40ps?
  225. Car stalls after approx. 5 mins of idling.
  226. tire option.
  227. Emission Junk Removal????
  228. Cobra intake vacuum line question
  229. Driveshaft
  230. transmission
  231. Possible Clutch Cable Issues...
  232. 5.0 Trouble
  233. need a picture of a stock 5.0 intake
  234. i need to get this fixed!
  235. whats a normal price on t5 rebuild?
  236. 89 mustang 3 issues
  237. 93 mustang gt tapping sound number 1 piston
  238. bad iac problems help
  239. Got some new door pins and wanna put them in
  240. B&M Hammer Shifter for AOD
  241. Another Running Rich Thread
  242. worth changin rotors?
  243. How to add nitrous to boosted application??
  244. backfiring through carb
  245. engine temp not reading
  246. still locking
  247. Need help tuning, car is sputtering...
  248. heads
  249. rims
  250. Smog pump and EGR valve removal questions...
