View Full Version : 5.0 Mustang
  1. Smog pump and EGR valve removal questions...
  2. 1991 LX 5.0 Need Some Pointers
  3. Turbo on my 86 mustang
  4. quick AOD question
  5. were is the inertia swith
  6. humm vibration under high rev load.
  7. hotchkins caster camber plate help
  8. broke bolt off in block
  9. Hood problems
  10. suspension/ rear end
  11. fuel pump ??
  12. new headers and shifter
  13. couple questions on carbuertor cars
  14. Tank unit for gas guage
  15. Ignition Setup
  16. Burning Oil
  17. Question About Restoring Rear Quarter Windows
  18. Performance Chip
  19. Question about stainless steel brake lines
  20. first performance parts. intake and heads
  21. Question about Trick Flow top end kit
  22. timing
  23. Loudest Exhaust for a 92 5.0?
  24. 88 5.0 wont start
  25. What's the best type of oil to use?
  26. help installing boost pressure regulator
  27. Needing help with heads
  28. svo extender
  29. Noise coming from AOD Trans?
  30. Stalling
  31. EGR spacer coolant lines
  32. Tail Lights
  33. intake manifold
  34. AOD shift cable install
  35. question on heads
  36. What the hell is going on?
  37. spark plug arcing
  38. wipers dont work...
  39. Help with dipstick
  40. "E3" spark plugs
  41. Header leak still
  42. 2 questions
  43. Motor Swap...
  44. transmission swap
  45. correct spark plug gap?
  46. Idle Problems... (Yes I searched)
  47. Streetable on a Budget.
  48. Do I need a standard or high volume oil pump
  49. scanner codes? possible cures
  50. problem worse, can't drive now....help!
  51. Help......
  52. Please dont burn me on this.
  53. fuel pump questions
  54. x-pipes
  55. Hear the ping?!?!? What is it!?! HELP?!
  56. need to find a 90 mustang THIRD BRAKE LIGHT WIRING HARNESS
  57. Cage install ?'s
  58. 87 oil pan Gasket
  59. IAT sensor location?
  60. 3.8 to 5.0
  61. is this my door pin?
  62. canister purge?
  63. Clutch?
  64. intake torque specs?
  65. Broken Bolt, Help, Please!!!
  66. 1988 GT turn signal flasher location
  67. new tps, same problem
  68. just died at fast idle
  69. UPR 2 PIECE UPPER CONTROL ARM BUSHINGS
  70. fuel injectors replacement
  71. t5z Rebuild kit?
  72. gauge problems
  73. biggest cam or best cam for a pretty stock 302
  74. How is this ele. water pump!?!
  75. motor mount questions
  76. electric fan???
  77. will a 93 cobra tps work on a '88?
  78. tps sensor problem
  79. fuel pump????
  80. Little black box
  81. Won't restart
  82. rear shock tower brace
  83. foxbody cleveland vs. windser
  84. dss racing engines
  85. Bearing race? need help :(
  86. biggest tires on lowered coupe
  87. head casting number question
  88. Tire Question
  89. on my 6th clutch cable in a week.
  90. torque specs
  91. bolt-ons?
  92. Replacing Manifold gaskets
  93. Shocks and Struts
  94. 351 cleveland in 88 foxbody what is needed
  95. Can't find the miss
  96. 84 not wanting to start
  97. car jerks/bucks when let off the gas
  98. Wheels used to tweark now they don't ..Why?
  99. Alum. Radiator Questions
  100. Carb Sizing
  101. Intake Gasket ??
  102. Really weird fuel problem
  103. fuel pump mounting
  104. Fuel system Upgrade questions
  105. hesitation woes
  106. my 5.0 is not running right,whats wrong??
  107. lower shifter boot and plate
  108. leaking head gasket
  109. Valve Grinding
  110. Need help with cam and heads
  111. Sea foam cleaner
  112. oil pan gasket question
  113. gt40 ?s
  114. Stock spring specs
  115. Catted Mac H-Pipe
  116. what transmission mount to use???
  117. coolant problem
  118. Injector color/size
  119. part questions
  120. Topic: HELP!!! Intake Valve Discoloration, anyone have experience running terrible
  121. serpentine belt
  122. interesting hesitation??
  123. flywheel problem?
  124. smog pump delete
  125. Explorer Intake question
  126. Suspension ?'s
  127. need help with headlights!!!!!!!!!
  128. harmonic balancer...can I fix it?
  129. ok newby with problems
  130. Waterpump leak
  131. supercharger??
  132. what h/c should i get
  133. Msd Dist.
  134. ok 5.0 or 5.8
  135. Whining noise before startup
  136. Side Exhaust
  137. Steeda vs MaxMotorsports Subframe connectors?
  138. 331 stroker need help h/c/i
  139. Timing chain
  140. Axle Housing Bushings
  141. Finally finished lowering the Mustang!
  142. hesitation when giving gas
  143. Head ?'s
  144. Imbalance...
  145. Schrader valve / fuel ??
  146. cigerret lighter problems before fire starts....
  147. Do these come out with smog pump delete?...
  148. Bad Harmonic Balancer. Whats involved in replacing?
  149. Car over heating again....
  150. Efi to carb?
  151. the most asked question around...
  152. cam differences
  153. 91 Clutch Problem
  154. LOOKING FOR ADVICE AND HELP. 89 mustang with 85 engine
  155. Fuel Sender Access
  156. What size bolts are needed?
  157. question on thermostat
  158. fuel pump q's
  159. Spec Clutch Issue?
  160. 4000 RPM Limited Rev
  161. white'ish smoke out pipes
  162. What temp do ur cars run at?
  163. Cracked Header Q
  164. Pulleys
  165. Fuel Pressure Question
  166. Car dies
  167. stock injectors on HCI swap?
  168. Need help with setting ignition timing Pics included
  169. IRS
  170. fuel pressure ??
  171. will this work
  172. Box A title?
  173. a/c problem
  174. need help please
  175. Clutch Q
  176. TV cable Problems/ Shift Cable Problems AOD
  177. Head Gasket thickness
  178. help with 91 gt overheating...stock!!
  179. Which ele fan...
  180. Bad TPS or TFI module??
  181. Tech question about valve train geometry
  182. Phenolic spacer help...94 GT
  183. fix random no start issue, now random idle problem?
  184. Help Running Rough
  185. What is all needed for 28 to 31 spline conversion?
  186. 87 5.0 starting/idling problem
  187. 89 gt vert
  188. Fuel pump relay
  189. need some advice
  190. My car is being difficult. (long post)
  191. SVO N351 Heads
  192. what is a good top and bottom set for daily driver ?
  193. Confused
  194. Mass air problem
  195. tuning question
  196. leaving soon need advice
  197. need help!!! plz!!
  198. Spring and conrtol arm install advice please!
  199. Which thermostat do you run?
  200. flooded car after storm
  201. clutch packs install questions
  202. Shiftless beotch!
  203. 5.0 Edelbrock Intake
  204. need to adjust front windows on convertible
  205. another h/c/i about 300 whp
  206. My foot hits the fuse box after swap to T-5
  207. HELP!!! my car is being a btch
  208. T5 Bolt Size Question
  209. greaseable balljoints?
  210. tail light housing
  211. Are these clutches any good?
  212. Hi all new here
  213. n-61 cam
  214. Need Help
  215. h/c/i combo question
  216. what about redneck trans. on ebay? any good?
  217. Help please!
  218. hatch wont close
  219. ideas for 12 sec build
  220. measuring pushrods
  221. I Found my coolant leak
  222. Tri -State Cylinder heads qusstion
  223. Need the opinion of mustang connoisseurs...
  224. 1993 SVT Cobra
  225. Can I use....
  226. stroker build.
  227. need help quick
  228. please help, huge problem
  229. 5.0misses when it gets hot
  230. 88 convertible top staple size/type
  231. 1994 GT PROBLEMS
  232. 331 curiousity
  233. Advancing Camshaft
  234. Which Balancer
  235. California smog legal long tubes?
  236. i need someones help please
  237. I now know why I have a vacuum leak... With PICS!
  238. 90 foxbody coupe
  239. new guy
  240. XE276hr and 1.6rrs question
  241. fuel line question
  242. Dip stick location
  243. looking for a good t-5 rebuild
  244. do i need a hood latch when i have hood pins?
  245. "clunk" when turning sharp
  246. 12v key on source..
  247. what will i need to do
  248. Intermittent start
  249. '93 Stang....AOD or AODE?
  250. GT-40 heads
