PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 [155] 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Brakes are hard as a Rock?? Help
  2. rpm question
  3. oil pressure guage
  4. 0.330" spacer for 5-lug conversion.
  5. Timing pointer
  6. Is mine a real GT
  7. Temperature mystery, sort of
  8. problems starting up right
  9. a video of me, ripping it up in Denmark.
  10. LA CRUISE DETAILS: Saturday May 12th Galpin Auto Sports
  11. Clunking Found!!!
  12. car wont start
  13. Question about coil-overs
  14. Superchargers
  15. maf installation ?
  16. wow, my car runs a helluva lot better now!
  17. Opinions on these stroker kits
  18. Smog Eliminator
  19. oilpan gasket
  20. injectors
  21. how to remove the condensor in sn95
  22. argh emissions
  23. disconnected IAC valve..
  24. * * LA Cruise Details - Saturday May 12th Galpin Auto Sports * *
  25. fuel tank strap removal (NEED HELP ASAP)
  26. Aftermarket Computer
  27. Son of a B*$ch!
  28. someone ruined this car
  29. mass air question
  30. Stator/Pickup replacement ?
  31. did a compression check.....
  32. mass air or what?
  33. smog pump
  34. Raced a WS6 TA yesterday
  35. Tinted Windows
  36. Yikes running way lean.
  37. Painting my wheels
  38. Body help need rot found!
  39. Submitting pics to 'modified mustangs'..enough for a small feature?
  40. Fox Door Panel Question
  41. Long Block 302
  42. help
  43. What do you think?
  44. more trans problems
  45. sometimes will run and other it just dies
  46. header install issues
  47. too much vacuum
  48. What is the minimum you need to get a car running?
  49. Little Help Real Quick
  50. Headers
  51. Putting distributor pack in TDC!
  52. Engine Compartment ?
  53. mass air
  54. Looking for a new horse
  55. v6 to v8
  56. Need help: smog/ac delete
  57. Oil Motor/Tranny?
  58. tire ?
  59. fuel pump question
  60. Flickering Headlights
  61. car was broke into
  62. suspension
  63. Better Sound??
  64. need mass air harness
  65. Need Help Trouble Shooting - Starting Problem
  66. What kind of potential
  67. possible buy!!
  68. lifter question
  69. need help i want to build a motor
  70. Before And After
  71. looks or balls?
  72. newbie with ?
  73. fuel injection or carb!!??
  74. EGR removal
  75. shift at what RPM
  76. Need a favor..adding a VSS
  77. new heads
  78. tach base piece
  79. Will be buying a 302 VERY soon...
  80. cut off
  81. EGR question
  82. I think I'm too hard on her!
  83. quick in need of
  84. newbie here needs some help
  85. performance help...
  86. SEMA show coming to atlanta...
  87. OMG harmonic balancer is a b*tch
  88. took her out today!
  89. explorer id?
  90. 94 gt dyno this Saturday..!!!! Need to know some things before I go!
  91. where can i find out what heads i have
  92. New Mods now car won't run right
  93. misfiring when warm
  94. Tach wire location
  95. Fuel Pump's going out- suggestions?
  96. 85 GT Holley Carb Help
  97. PTK Systems
  98. stang stalls and surges
  99. IGNITION LOCK
  100. ?
  101. check this out
  102. gas tank
  103. turbos
  104. Over heating?
  105. Will i need a Tune?
  106. car gets hot then wont start
  107. Track tomorrow, race gas?
  108. T5 to AOD swap, neutral safety and kickdown cable ??s
  109. new 347 stroker questions
  110. ++Looking for some good advice++
  111. AFR 205's!!!
  112. H pipe clearance
  113. Mod List, Advice Appreciated
  114. Better pics of Project 1992 Coupe with new paint
  115. Lower control arm bolts
  116. can you sand blast a 89 mustang
  117. Noob with a 5.0 ???
  118. im going to the drag strip soon!!!
  119. B&M VS TRANSGO (shift kits)
  120. Is this all I need
  121. Better intake setup???
  122. Summit Racing or Jegs???
  123. Spoiler Delete with Chop Pic
  124. Finished Rebuild & Gave Her A Bath
  125. neutral safty switch
  126. Transgo Shift Kit
  127. Anyone running Cainfield Heads
  128. Changing Cam!
  129. porting heads
  130. strength of 4lug set up?
  131. 5.8l worth it?
  132. Help me..
  133. cam spec's
  134. NEED SOME INFO AND HELP
  135. Fuel Injectors Fuel Pump Question
  136. 331 stroker hp gains
  137. what size TB and injectors?
  138. GT40 vs. GT40P Heads
  139. Rear differential messed up
  140. Torque Converter Install Difficulty
  141. Proform billet baseplate and mainbody.750dp
  142. step up headers
  143. New Alternator
  144. trimming the fat
  145. Foxbody 4.6 or 6.0?
  146. Engine hardly running.....need quick help
  147. Trick Flow Intake....!!!!
  148. bbk fuel pressure fuel pressure regulator
  149. Going to sell my 85.
  150. .330 balljoint spacer
  151. got a quick ? about my intake set up on my 87
  152. U/L control arms
  153. t56 or tko600? cant decide
  154. 140 Mph Cluster
  155. cobra bumper
  156. 4cyl springs
  157. 5 lug conversion q's
  158. Hesitation\sticky throttle ---TPS?
  159. Titanium paint code
  160. if you have aol and have put on a aftermarket rear girdle.....
  161. manifolds
  162. ebay heads
  163. mass air question
  164. What is a valvebody??
  165. power steering sqeakikng
  166. Pulley sizes
  167. Anyone here had any bad experiences...
  168. manual valvebody
  169. B&M hammer install...
  170. bump steering kit
  171. question about oil
  172. Spark plugs with tfs
  173. welder
  174. Pinks
  175. idle
  176. Questions on oil/temp gauges. Stock/AfterMarket
  177. Speedo Cable questions
  178. What 5.0 Emblem did 88 have?
  179. Electric or role up?
  180. MAP
  181. efi conversion wont stay running
  182. Alarm system
  183. Some Play In My Procharger...
  184. trying to setup my suspension!!!
  185. Vaccum problem!
  186. need help with the moldings
  187. Pony wheels question.
  188. How much??
  189. STOCK 94 5.0 INTAKE
  190. 1986 gt for sale
  191. HELP door problem
  192. I got a snow blower, literally!
  193. 86 GT Build-up
  194. SN95 Autometer Gauge Holder
  195. SHORT? RADIO HELP PLEASE
  196. fuel pressure
  197. which cam do i go with???
  198. maf question
  199. wont start ?
  200. Suspension Question...
  201. suspension ?'s
  202. Head Gasket
  203. Just spent $800
  204. Exhaust Diameter?
  205. Cainfield heads & custom cam
  206. 5.0/4.6???
  207. ghetto fuel connection
  208. help with the engine bay
  209. Check engine light after headers
  210. Heads.
  211. ?
  212. Clunking and Pissed!!!
  213. rubbing noise... shaking
  214. look what i seen at autozone today
  215. AOD Racers
  216. Whats with the smell?
  217. What is the level of difficulty?
  218. Found My Problem....
  219. Paint questions
  220. 347 stoker?
  221. Gears, Suspension
  222. what am i supposed to be running?
  223. Thinking about selling my 5.0
  224. What does reconstructed mean?
  225. How much power could i be making?
  226. can anyone lift my spirits before i torch this thing?
  227. nub questoin
  228. tranny question
  229. how can i tell what amp alternator i have
  230. 3000 to spend on what?
  231. keyless entry
  232. rear springs??? supposed to be there?
  233. !nx kit on my 5.0???
  234. maf question
  235. gaz
  236. efi wiring diagram
  237. clutch problems
  238. zex 125 hp shot
  239. 91 5.0 dies out
  240. Pro 5.0
  241. Fog Lights go out
  242. Gauges
  243. installing cam
  244. performance issues
  245. Need to beat a cobalt.
  246. NEED HELP!!!
  247. Fox or SN95
  248. JBAs sound good, but are they loud?
  249. Intake question.
  250. Will thumper heads emmissions legal?
