PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 [178] 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. houston area people
  2. Which Service Manuals?
  3. delco Alternators on a 351W
  4. which mounts?
  5. Vortech V-2 Inlet pipe
  6. LX 5.0 conversion
  7. Head codes
  8. a good port....
  9. surging idle?
  10. KING COBRA CLUTCH
  11. does anyone know anything about.....
  12. Anyone in Arizona
  13. distributor position
  14. cams..,cams???
  15. Cobra foglight lights on a SN95 GT
  16. installing an aod having problems tq converter dont fit?
  17. 87-93 Manual rack kit for sale
  18. battery cables
  19. starter?
  20. HELP
  21. getting gears installed
  22. Procharger questions.....
  23. new carb for 85gt
  24. Anyone here gone through more than 1 5.0 Stang?
  25. new style
  26. 460 in a fox body
  27. gasket question
  28. Transmission probelm
  29. 5.0 vs 4.6
  30. Modded 5.0 vs. Supercharged 95 Cobra
  31. where to get front slotted/drilled rotors for my 93 GT ?
  32. Which should i use
  33. 93 Cobra & 93 Cobra "R" Information
  34. clutch cable problem
  35. WOOT! Getting 94 GT vert
  36. performance-evolution
  37. high mileage modified 5.0's
  38. ok i think i solved my problem
  39. new K&N filter
  40. trick flow street manifold
  41. How quick will the car be?
  42. manifold?????
  43. my 5.0 sits uneven--why?
  44. 351 in a fox?
  45. maf conversion
  46. Hypertech
  47. Just ordered my b-day present!!!
  48. heads question
  49. Just talked to C.A.R.B. and affiliates...
  50. new seats??
  51. Notchback question?
  52. Convt Inter Lighting
  53. new part
  54. max milage to buy a 5.0 at.
  55. bad feel bad sound part 2
  56. Size of a 92' quarter window for a decal?
  57. Mass Air & Computer Help
  58. how to bump timing?
  59. Changing Intake? Need help
  60. ? about smog pump?
  61. how do delete the heater core ?
  62. St.louis area machine shops
  63. weird thing on start-up
  64. Hood wont shut
  65. Exhaust question
  66. How to install starter solenoid
  67. paint
  68. new clutch today
  69. The best body kit for my ride
  70. timing
  71. blinking CEL
  72. tools
  73. 390 and c6
  74. good deal??
  75. CAI fittings
  76. Tweecer...
  77. capri
  78. quick question
  79. went to the track!
  80. vortec supercharger
  81. would this pass
  82. ne pics of a/c delete!!!
  83. Long Tubes vs Shorties
  84. oil diptick tube help
  85. GT Front Bumper Rivets Help
  86. where can i get lx lights?
  87. emmision tricks
  88. Would this look ok
  89. Factory Manuals
  90. Speedometer gear
  91. 93 Cobra & 93 Cobra "R" Information
  92. Great site for fox parts
  93. How Hard is it to change
  94. Pistons in a 302 need help
  95. Shifter Poll!
  96. How to tell OEM from Replica? 1993 SVT CObra wheels?
  97. Good Mustang Websites?
  98. FPR guage????
  99. new guy, long post!
  100. neeed someee help!!!!
  101. 4 wires to gas tank on a Fox body???
  102. newbie to the 5.0, help please.
  103. fox body odometer
  104. Steering grinding noise.
  105. paint interior or not?
  106. front bumper fitting issues!!!!!
  107. How many are from texas?
  108. Swapping in new axles this week end - Need help
  109. T5 and rear end experts please come in ...advice needed
  110. paint color
  111. NEED SUGGESTIONS
  112. Suspension tips?
  113. lost 2nd gear
  114. Just a reminder...
  115. CAMS!!!! what size???
  116. Odd Interior issues!
  117. Paint
  118. 5.0 acting funny
  119. 5.0 acting funny
  120. Suspension Setup
  121. good setup?
  122. The final word on gear break in
  123. good longtubes?
  124. my 302
  125. 1.6 roller rockers and pushrods
  126. I need some suggestions....
  127. Need stock Fox TB-emergency!!
  128. Track's closed - What kind of 1/4 times...
  129. Where to get leather seat material?
  130. Springs, springs i need new springs...
  131. 95 cobra motor question
  132. afr's or complete explorer
  133. Cooling fan issue?
  134. how do u put a pic where ur name is?
  135. to my fellow tech's
  136. headlights (for pro and others w/aftermarket lights)
  137. MAF Conversion- ECU harness
  138. car wont crank
  139. Car Cover or H Pipe...
  140. rebuild
  141. Need help quick: How to tell if this is a true Cobra motor?
  142. Aftermarket Rocker Arm ?'s
  143. Help, need to outright beat an evo
  144. start rebuild
  145. power lock fix
  146. Wiring Harnesses
  147. P/S cr@pped out
  148. Instrument Cluster Swap 87-89 to 90-93
  149. What is a rear stabilizer shock??
  150. OVER HEAT!
  151. should i buy this?
  152. what you think of this 5.0?
  153. automatic tranny
  154. Venom Fuel Injectors
  155. baffles necessary?
  156. turn signal dont work
  157. problem with the turn signal
  158. anybody ever use these?
  159. 4 cyl transmission
  160. smog pump
  161. clutch question
  162. DIABLO TUNER??????
  163. four point harness?
  164. 1990 LX Coupe ideas?? Where can I find some??
  165. need to know how to retro fox harness in sn95
  166. 3.73 gears
  167. 5.0 mystery
  168. Think I'm asking to much, not getting many offers
  169. To those with pcv oil separators...
  170. part # for oil press sending unit?
  171. clutch cable routing !!HELP!!
  172. Now, to those with rear disc brakes..
  173. Valvoline Race oil
  174. update
  175. Timing Settings
  176. Does anyone have a billet grille on there 94-98?
  177. next upgrades for 89 lx 5.0
  178. pistons, hyper and forged
  179. Dumb Question
  180. what would you guys rate my stang ?
  181. aod tranny problem
  182. remove door locks
  183. the regular alloys?
  184. 4 eyes no more (hopefully)
  185. cts-v
  186. Orig Header Question
  187. what's the difference about Flowmaster ?
  188. Fuel Issues... NEED HELP!!!
  189. 5 lug kit fitment
  190. 255 lph fuel pump
  191. Pretty sweet =)
  192. Buying my 5.0 back????
  193. Fuel Injector Install
  194. Tried everything, still no luck
  195. how much hp & tq should i be making once i put all this on?
  196. What exhaust is everybody runnin' ?
  197. Which wires to use?
  198. gears
  199. How to prime a new motor
  200. How much?
  201. whoooo hooo!!
  202. bolt circle size?
  203. what to ask for at the junkyard
  204. Four Eyes with Saleen Wing?
  205. GEAR OIL T5
  206. typhoon intake is a copy of what??
  207. Ebay do's and dont's on my 5.0GT?
  208. value
  209. anyone use z3 fenders?
  210. I know this is off topic but i would like to know whats goin on.
  211. upgrades-bang for your buck
  212. oil priming
  213. 85 GT Front Spindles refurbished
  214. Should I replace my weatherstriping (convertible)?
  215. rear end
  216. Anyone installed SN95 brakes onto a fox 8.8 before?
  217. Door locks....
  218. Odd overheating
  219. is a 5.0 interference engine?
  220. Priming though distributor
  221. help
  222. Color option on moulding
  223. fuel injectors
  224. rear seat delete??
  225. KVR CD or Slotted Rotor Super Sale!
  226. changed motor in my 87 and now it wont start.
  227. No start
  228. need help from the 5.0 boys
  229. one hell of a burnout
  230. 2.73 or 3.08?
  231. woooo my trans came today so excited
  232. *Update* Re-torque lower intake bolts? *Update*
  233. Subframe Connectors
  234. Whats the best motor swap?
  235. What do i have?
  236. Won't turn over...
  237. Cleaning TB ?
  238. Weird Loud Sound
  239. 347 ?
  240. what to look for without touching?
  241. Heater and a sweet smell
  242. OD band screwed up?
  243. need opinions please
  244. 429Cobra Jet swap
  245. heater core
  246. SS454 vs 5L with bolt ons
  247. Are In-Line Pumps Noisy?
  248. How much weight does an aluminum block save? and more cubes?
  249. Speed Density Driveability problem
  250. Which gauge series do you run?
