- in major need for Tranny help
- Advance Timing
- Clutch life?
- My door is hard to open?
- About my Rear End
- speed density ?
- Suspension bushings, how to remove/what to put back in?
- window
- mod that adds a little kick?
- prochamber/h-pipe
- BACK FIRE
- charcoal canister missing - help
- i hope i did alright.....
- Runs stronger when cold?
- Cold air question
- POPPING noise from rear.. suspension?
- Just for the sake of conversation..can a carb's CFM be made bigger?
- The measurements to install an H pipe?
- deal or no deal
- over heating under boost...need help
- '03 Cobra vs. '95 S/C 347
- Explorer 5.0
- Anyone ever re-use the headbolts???
- winter mods, questions
- 351c vs.w
- nitrous install question (pic added)
- I know, i know, OT, but check it out.
- Seafoam?
- nitorus on my motor???
- 5.0 injected revisited
- ceramic coated worth the $$$?
- she's smokin bad after the H
- yankin the front tires?
- WTF..Something bad?
- Heres what I ordered
- cheap gears
- vacuum leak question
- 400 hp
- Just bought 94 gt have many question
- 50resto arms
- heads twisted wedge HP gain
- h or x
- turbo, supercharge, or stroker?
- 1987 Mustang GT supercharger question...
- what wheels?
- ford answer to 09 camaro
- audio question
- 18" wheels--what are the offset on these?
- pushrod ????
- 4cylinder turbo t-5 in a 5.0 gt
- Manual Or power steering?!
- valve to piston clearance
- I need some 42# injectors
- fox body 351 swap..
- 351 intake question
- steeda vs pro50 vs MGW vs Pro ripper ..which is better?
- Compression on the 5.0
- engin upgrade
- need help
- possible oil and not head gasket
- Rear Main Seal (and its parts)
- set up question
- Twin Turbo
- Have you ever lost control of your FOX?
- 5.0 rebuild
- Thumper Heads
- runs rough
- Some questions about the stang
- GT 500
- New stock height springs
- porting trick flow heads
- ground effects
- starter
- my mustang has a lx body but a 5.0 engine
- Need torque specs quick!
- What are the chances of finding a 89 5.0 notch?
- converting manual options, to power?
- GT-40 Upper and lower question
- running rich problem solved
- Driveline clunk...still have it! :(
- GT40P heads
- any interest in a A/C setup?
- CLUTCH KEEPS NEEDIN ADJUSTED
- T5 to C4
- fuel pump relay location
- Edelbrock Preformer Intake
- flame thrower kits????
- my swap
- SD cam questions.
- exhaust
- overheating issue???
- Custom Paint Booth - Soon to be on EBAY!
- this a good deal or not? (weld wheels)
- rim size
- Ported E7's
- nitrous questions....
- Updates on the cam install
- performer 5.0 heads??
- 1993 Cobra- R? + Pics
- struts
- C4 with aod
- 89 gt fuel pump
- Carb vs Fuel Injection????????????
- WTF!!!
- Help with 5th gear? Accerlation stops in 5th
- AOD for sale
- 200$ race tonight!!
- Why so cheap?
- seatbelts
- Pulling the engine to clean bay
- anyone have a vortech supercharger?
- 1.6 rockers on stock motor
- what size tb
- Should I go with 24 or 30 ib injectors...
- idle problems
- tuning and nitrous on higher milage 5.0L
- quick question on fender and quarter panel
- help me guess my hp?
- line lock question
- what to do next
- cam question
- head/cam/stroke question
- Some pics of my heater core install
- 95 5.0???
- What head do I Have (351C orW)?
- Radiator
- I Can't Take It Anymore
- cant figure it out
- bellhousing?
- which clutch to get
- converting to MASS air
- having trouble driving this clutch
- got a package today....
- 1987 vert for $80
- Help, I have an unusual fuel problem with my 5.0
- ok heres my more inside on 25th anv bage
- afr or trick flow
- good news
- h-pipe or x-pipe
- LEAKING INTAKE!!!
- How much for (PICS ADDED!)
- wheels
- ANDERSON POWER PIPE
- I need engine help 350
- sn-95 5.0 best intake manifolds?
- Just got GT-40 intake, need help
- supercharger crank pulleys
- TB question
- warlok mufflers
- movil one 10w-30 or 10w-40?
- Stumbling cold start advice...
- sry. but i need sum opinions
- an est on my 1/4 times
- New Rims
- 3.55's or should i go higher?!
- springs
- holley systomax heads
- Doom on my 5.0
- what is the best oil,
- What Should I Do
- Rebuilding c4
- Milling the heads
- Missing @ Full Throttle
- Oil Leak from head gasket
- a/c delete
- spacer for 5 lug swap?
- New clutch cable snapped after a month.
- muff lers
- What else do i need?
- Nitrous kit help
- Long tube headers
- Sluggish Pony
- Took the delivery on a 94 SATURN !
- Need help with Clutch cable fast
- selling stang need help
- supercharger question
- X-pipe with an AOD???
- What do these wired go to on my headlights?
- Battery? Alternator?
- Getting Ready to make a big order
- kinda off topic...mirror glass
- black 95 cobra R's
- Saleen body kit on a 94
- Relocating Battery Help
- new guy needs advice
- Shift points
- One piece headlights!
- Sunday Dec 3rd Cruise. Be there!!
- Considering an 85 rag
- Hondas
- mustang RPM SPEED
- door to body weatherstrip i don't need
- Saleen wing
- Different way to put it on?
- satellite radio in 92 mustang lx
- JBA headers on a fox
- pacesetter hpipe?
- HOW MUCH IS THIS 84 GT350 WORTH???
- head removal
- 85 gt mods
- carbed intake
- H/C/I...
- 10 series flowmaster
- Help removing/reinstalling spindles/lower control arms?
- stock cc size
- MSD problem
- New Sponsor - Fast Toys Performance
- running straight pipes??? help
- new 302 in what mustang
- Might be off topic, I hope not
- kenne bell?
- What primer???
- Just got my car back
- Vibration
- What Tires to buy...
- 82-89 conversion.
- is ebay really a good deal?
- How much compression gain ?
- finaly got a pic guys of the fox look
- OK, possible new wheel choice
- Need Suspension
- Spped Density to Mass Air ??
- Best Rim/Tire/Shipping deals
- need expert advice.
- What size fuel injectors?
- a 89 5.0 on a 95 3.8l body
- Need help!!! removing balancer!
- what size belt???
- Mac Dura Black exhaust
- We must start somewhere (project 1986GT)
- Should I increase to 24LB injectors?
- s/c questoin
- trading my 5.0 for civic???
- torque converter
- Project N/A '92 Coupe underway
- this is getting anoying
- Hope some of you can make it!! Cruise 12/3
- 95 GT tell me how it sounds.
- mother****er.
- Headlight seals..
- wooooooohoooooo!
- 351W dyno tune results - 350rwhp
- Question for those with trickflow top end
- How much RWHP will stock fuel rail support?
- dyno tune
- oil pressure is slowly creeping down
- Tranny trouble
- EBAY TWIN TURBO!!! (megasquirt)
- kaf question
- New Mustang
