- fouled plugs
- front 17X9 wheels and coilover clearance
- Where did the torque go on my 331?
- 88 5.0 gt wont run till it warms up?
- high idle problem
- egr back of heads
- wind rushing noise with cold air intake
- swapping mt into auto 95 5.0
- Starting problem
- running a little warm I think
- changing fluid in power steering?
- fuel injector not fitting snug into fuel rail
- 5.0 Questions
- big boys of the 5.0s need expertise
- Start up taking to many cranks
- 87 stand want to hide engine compartment wiring
- Heater core through glove box?
- Pig rich after emissions delete
- temperture gauge not working
- '93 gt fog light delete?
- It starts but wont stay running!
- cam question??
- running lean and pinging...help
- Exhaust pipe closeness to fuel tank
- GT40 Tubular Paired with what lower?
- Speedo gear install?
- 61 mile to the tank WTF
- New speedo gear install?
- 5.0L Question????
- alternator problems
- 347 Build help.
- oil cooler
- Oil pressure guage problems
- ignition situation
- 5.0 to 2.3?!
- fuel pump issues
- will maximum motorsports coil overs lower my car?
- 94 Mustang Rebuild
- Howling noise?
- 302 to 351
- Squeking noises!!!
- 5.0 down! loss of power need help
- Body kit installation
- egr connection
- Can't get my dizzy back in?
- idle problems
- 88 5.0 no maf?
- Oil Pump Shaft on the outside of the dist. eyebolt
- 95 Convertible Top Problems
- Cost cutting engine building
- d00e heads
- car turns off after i start it
- installing a cobra degas bottle
- Stalling Out Problem
- Did i make a mistake?
- i've got an odd cutting out problem...
- cold starts and laying down under pressure
- 5.0 starting problems, i need help bad
- Throttle Body problems. NEED HELP ASAP!!!
- Transmission harness wires cut!
- 5.0 Build up questions
- Steeda #19 Cam & 1.7 Roller Rockers
- 5 Lug Conversion
- Questions 86 GT
- Heater does not work well
- Starting issues
- front rotors
- 1990 mustang cold starying
- convertible rear view mirror
- install questions
- Coolant loss need help
- High Idle after making run?
- Tilt converion
- Dash Removal
- 1994 convertible mustang 5.0 parts
- 86gt rough idle and missfire
- Chip to tune 93 Cobra MAF, or aftermarket MAF???
- hurst shifter problem
- 1989 mustang map question
- swap from a straight 6 to a v8 302 any info
- rock hard hoses
- driveshaft or rear end?
- need help exhaust ?
- 1966 mustang to 5.0L project any suggestions
- spark plugs have oil on the threads
- question about solenoid wire on starter
- still runs bad! Help!!!
- rebuilding 302 with 289 heads couple ??
- power steering
- Mark VIII fan mod question
- ATTENTION NEW MEMBERS!! READ!!!
- gt40 intake spacer ?
- fox body headers/ sn95 car
- best cam for stock bottom end SD setup
- 03 GT Brake upgrade
- jack point
- how do i check fuel pressure?
- What year doors will fit a 1986 Mustang GT?
- Nitrous plugs
- Fuel Pressure ?'s
- stock 5.0 cam specs
- Will 2.02 valves clear the pistons?
- Crappy AOD Tranny's
- 80MM COBRA MAF HOUSING
- clutch cable problems
- upper control arm bushing not seated?
- my morning from hell
- Flickering check engine light
- Location of headlight relay
- car shuts off while driving
- F/R manual steering rack
- temp gauge not working
- Compression ratio help
- Alphabet cams
- need some help
- turn signal issues
- gutted resinators
- Got somethin weird goin on with my 87 GT
- Just finished the swap...
- fuel pump doesn't prime
- Headlight problems
- DomeLight wiring
- 70mm BBK throttle body spring stiff
- prob:hesitation/surge at 2500-3000rpm
- noisy clatter coming from intake manifold area?
- Fuel pump sizing
- bbk long tubes 5.8
- Alternator cable names?
- Bucking at low RPM
- Compression Question
- Thermostat question
- need help making a headlight harness
- Crankcase Evac Pump
- x cam
- check engine light?
- Custom Speedo/tach/other gauge question
- When hood is open, does the interior lights stay on?
- Sooo.... doing a top end rebuild....
- inline fuel pump
- what is wrong if I need to hold the shifter in 2nd until the clutch engages?
- Bad idle - probably vacuum leak
- fuel pump issues
- 1988 5.0 LX having trouble with turn signals
- back pressure
- Power Loss
- 85 GT question
- pinging at 10 degrees timing?
- Engine idle "hunts" and stalls............
- help
- No start, kills power
- quick question
- dash lights dimming
- Has anyones car remained on WOT while driving?
- 3rd Alternator in as many months
- Coolant Flush
- Idle/Low fuel pressure?
- melted wire at starter relay
- 1986 mustang has three DTC's need help
- T-56 Viper Trans help
- Flaming River Steering Shaft Problem
- Egine compression
- Cranking but no start
- Stock fan
- 89 GT 5.0 stumble between 1500-2300 RPM
- T5 Whines in 1st 2nd and 3rd?
- installing Magnalfow X w/ cats....won't fit!
- SN95 5.0 --- Help ? I Think?
- 1986 mustang fuel light
- parking brake adjustment
- Car wont start . Please help
- Rocker arm bolts
- Tie rod problems.
- torque specs anyone know??
- misfire
- distributer ???
- timing cover
- How to degree a cam please!!!
- clutch pilot bearing go on the crankshaft?
- Replacing crankshaft and bearings
- suspenion ?'s
- Heater Vent problem
- 95 GTS window to main dash plug different?
- Exhaust
- Electrical genious needed
- wat is normal temp?
- Need help identifying a factory Cobra T5 transmission
- Help in a fun way
- a few ?s about overheating problems
- How much coolant goes in
- PCV/breather with s/c question
- Manual Rack or Power.
- Need advice oil on spark plug #8
- 89 5.0 under drive pulleys install info
- jersey/exhaust/cats/inspection
- taking apart a starter
- Need headlight rewiring help! PLEASE
- Valve spring recommendation
- Transgo Shift Kit
- Timing chain removal?
- Gt40 head question...
- rearend?
- fuel problems
- lights
- Power seat issues??
- headlight problem NEED HELP FAST
- Bad tail light question
- F303 cam help
- how do i set the timing???????
- bad vehicle speed sensor?
- 5 to 4 lug switch.
- 347 help?
- Need help with technicalities of 347 build please
- bogs down when floored...
- HELP!!!CAR STOPPED ALL OF A SUDDEN!!!!
- 5.0 Vibration Problem
- Heater Core
- driveshaft
- can you tell a headgasket is blown by the spark plug?
- Stupid '86 headlight question.
- Edelbrock Pro-Flo XT Manifold for 5.0
- is this a 8.8 rear end
- pushrod length
- 393 shooting some oil from dip stick incert
- Adjusting Front clip-fender fitment
- whistling from inside the block?
- tb question
- installing hood pins
- pinched trany seal?
- Stang starts first time, then dies
- posi traction
- 5 lug disk conversion
- aod transmission problems HELP
- ignition problem on a 89 mustang
- 1990 Mustang 5.0 Rough idle and Shuts off
- Rediculous question...
- Rear issues
- Mustang gas tank
- different ball joints?
- rusted frame rails
- Battery disconnected, bad idea?
- RHS heads
- front control arms
- ? about seat track compatibilty
- starting problem
- car just dies
- can a bad egr valve cause car to run lean?
- car feels like its going to die at idle? pulled codes
- c4 ? !!! help
- 1987 LX Fender/Bumper Cover issue
- best spark plugs for gt40 heads?
