- AC compressor no good - need belt reroute!
- PCM LocAtion
- BBK H pipe or homemade ?
- Pretty sure some hit my car...
- wth? ruined sn95
- Well I just poured in some seafoam.
- Anyone here changed an oil pump?
- Heads?
- Anybody willing to part from their factory H-pipe?
- Advice on Automatic transmissions
- noise from intake tract
- anyone need sunvisors?
- a/c
- What it takes to beat a 04 SC GT
- wet sanding
- Quick Shift Knob Q
- Disc Conversion kits
- SN95 5.0 parts not in some websites
- LOWERING SPRINGS.WHAT DETERMINES DROP?
- e303 cam with stock motor?
- BOOSTED/WHERE DO YOU GET VACUUM?
- Emblem
- 347
- determining if my5.0 Is worth installing bolt ons
- ranger axles for 5 lug conv.
- New fuel pump and injectors and running Rich!
- bright headlights
- Those with Pro 5.0 Shifter
- Check out this 5.0 swap I found...
- Probably a stupid question but....
- Thinking about getting this
- just ordered new tranny
- horsepower differences with a 306ci
- Real life exhaust gains?
- dumb question
- Battery relocation...
- Rear sway bar?
- Brenspeed COUPE STOLEN
- 3 or 5 Link Rear?
- NEED HELP Please!! PCV Crankcase pressure/Bogging
- suspention upgrade
- Quick Easy Question
- wheel/tire qestions?????? will they fit?? come on!!
- My lower ball joints
- almost crashed
- ignition box and ignition upgrades
- what do stock GTO run in the 1/4 mile??
- which look better
- full exhaust on a an 84 gt
- Gotta love the Terminator
- anyone with black engine pic's please post them!
- Computer # id
- roller rockers!!!
- Bad vibration?
- Fuel pump question
- Pics
- 93 MUSTANG GT 5.0
- door handle question..
- Progress......and 1 quick question.
- New intake, which one?
- Brakes
- Cheepest place to get new T-5 for stock motor
- Pistons
- Carb question
- 351w heads/headers
- customizing hatch lock?
- Subframes with seat bracket?
- Headers and midpipe
- My steeda tri-ax on an 03 Mach 1...
- Ebay GT-40 Intake
- cobra intake
- block/other engine parts...paint
- new project 5.0 question
- AOD Problems
- Need Help--diagram or pic of '69 clutch assembly installed...
- gt side skirts
- Headers
- This noise makes my car sound like a peice of ****.
- what should I mod next?
- Just Ordered the ZEX wet kit...Pretty Excited
- licence plate bracket
- extra horses
- please help, tensioner pulley?
- what intake
- Offroad H-pipe choices -BBk? Flowtech?
- 1994 Mustang GT Rims & Tires question
- oil in coolant tank?
- Where are the VIN
- Where are the
- Coolant
- Question about 5.0 Roller and Non-Roller motors
- gear install 3.73
- look at this ****
- My Procharger isn't loud enough! (video)
- Car has a miss and is runing rich
- Proper way to Launch....
- wheels on fox stang
- tranny's ratio?
- I think I have a vacuum leak
- Tailshaft bushing question again.
- what the hell.
- Transmission Bearing Noise
- Coolant leak..where does this hose go?
- that is right...another head question
- turboed mustang without MASS air
- Fuel Pump Stuck On - Fuel Pump Relay, where is it?
- Underdrive
- i got a question new here ...
- good tune
- AOD-Is it a vac leak or is it shot?
- I NEED HELP
- I need help FAST concerning block compatibilities
- Manual Steering Rack and Pinion
- away for the winter
- CAR IS DEAD NEED HELP
- 87 - 92
- black magic
- TRick flow HCI
- 130 Amp ALternator install dual fans also
- GO READ THE FIRE EXTINGUISHER POST IT MIGHT SAVE YOU LIFE
- Is This Normal?
- Timing bump and fp bump
- cam/converter
- Pics of my car
- bolt kit
- car will cut off while driving and wont restart for a couple of hours
- BRAKES & ROTORS
- Quick tweecer rt question
- Is my clutch on its way out?????
- Serious Mod (s) question.
- Throttle Spacer Plate
- Anyone with a Comp Cams XE276HR??
- Fire Extinguishers
- Ford Ranger Conversion..
- There is something about this car.
- 351w...NEED TO KNOW
- Inexpensive ways to freshen up a motor?
- 85 Porsche or 89 GT
- What temo does your E fan come on?
- It pops out!
- Pics of my project
- OIL...
- interior trim paint...wtf?
- Check Engine Light
- 235/60/15?????
- a few projects this weekend on my new 87 lx hatch, removed cats and new Lights (lot of pics
- will donut spare ruin my auburn if i use it
- hurst shifter
- need 2 kno!
- Engine trouble?
- Cleaned up the engine bay today
- Fuel pressure & Fuel Pump, cutting out and stalling
- best looking rims on a fox GT
- Track rules and guidelines?
- Rear end question
- Tires for 700rwhp?
- finished taking apart the 302 today!
- Boost/Nitrous On a 1995?
- It's alive!
- Headers
- New track times
- Just moved to Illinois
- 93 cobra intake on 95 gt
- Keith Craft engines
- TFS Track Heat package for $2030!
- wondering about the 1.7s
- Wiring question
- 4.10's
- Help with fuseable link
- Stalls when shifting into gear at idle
- winter driving
- curb weight
- winter plans
- car wont start...
- 94 MODS
- My fan it hitting the shroud and my 5 speed does not line up.
- Best Spark Plugs
- Cowl hoods in rain?
- port and polish
- rebuild or new engine?
- No cruise or horn or cig lighter
- lean question
- Can't make up my mind on Go-Fast parts...
- carbed fule psi
- 140mph speedometer
- ? for everyone running w. no cats...
- Crossmember
- losing compression
- what actually determines your redline?
- need speedo cluster anyone want to sell ?????????????
- New cobra r wheels
- battery wiring
- Cats make a huge difference?
- IAT bypass chip?
- Flywheel
- fox blue interior
- Too rich
- will this pass inspections?
- Wild Strawbery Pic Request.
- valve guide seal replacement
- trusting EBAY??????
- Where to get custom Chip?
- Check guage light???-- only first thing on cold mornings
- Strange burnt smell from exhaust
- Clunk in rear
- how to get the most outa my 225hp
- My car POPS through intake and that sucks
- It is finally done!
- adjusting shift points
- ? the little groung wire on the neg battery post
- come on someone !!!!!!!!!
- will it lift
- Dexcool okay coolant to use?
- 5.0L engine numbers
- spin ou
- anyone want to sell speedo cluster w/or without gauges 4 a 89
- Idle with Cam????
- LOOK!!!MUSTANG PICS FROM CAR SHOW- GT500 , CALIF SPECIAL OTHERS
- any idea??
- fuel sender
- normal?? idle was high today and seemed to rev as clutch pushed in
- Take Off's Fly By's and Doughnuts!
- Can I replace my 94 GT 5.0 with a 97 Mountaineer?
- What headers to use?
- strange cooling pattern
- What size tire will be equal height to my old set up?
- two issues related to supercharger (I think)
- Vacuum/main seal problem
- Tall valve covers. Do i need spacer ?
- No spark geting to coil wat could it be????
- problems possible with converting 93 ho to carb
- 1986 gt sugested mods
- removing rear bumper
- how does the MAF sensor work???
- Need Help ASAP on timing
- Texas Registration
- Electric fans...
- slp1??
- Sportsman Block
- edelbrock rpm 210cc ??????????
- pics of fox gt's w/ cobra rear?
- speedometer gear???
- rear arm bushings
- Is my oil pump dieng????
- aod people to the table
- H or X Pipe
- emblem still made? where?
- exhuast question
