View Full Version : 5.0 Mustang
  1. Intermittent backfire/hesistation
  2. Steering Shaft help
  3. Fitting the Clutch Cable
  4. Confused about - Alternator 1 or 3 wire?
  5. tightening the parking brake cable?
  6. BBK Headers question
  7. Finally my mustang is drivable
  8. 92 notch rear window molding replacement?
  9. Power Steering Hell
  10. Front Bumper Help
  11. 1992 Mustang LX. Need help?
  12. do i need these
  13. How messed up is my Car?
  14. pulling steering wheel
  15. whining noise from tranny
  16. Sagging door...
  17. turn signal problem! need some help
  18. F cam in a 94
  19. can any one tell me what this tranny out of .
  20. rust areas by trunk
  21. Bracket positions and pulley setup-easy question
  22. Weird miss
  23. 5.0 not getting fuel.....
  24. moving the battery
  25. T-5 to C-4
  26. z cam specs
  27. which injectors to use
  28. Can I use a injector harness from any other 5.0L car?
  29. Door lock actuator question
  30. fuel pressure/ timing
  31. Steering Rack In's-&-Out's
  32. T56 In an '85
  33. which swap?
  34. Performing Intake and Head Swap, Quick Q
  35. Oil Gallery plugs on 1970 302
  36. suspension
  37. Oh snap! (I broke a bolt)
  38. Please answer ASAP! Transmission troubles
  39. Cracked oil pan
  40. So I have some money to spend.....
  41. Thermostat?
  42. Exhaust Job
  43. New Struts? Front tires rubbing...
  44. '95 Cobra rebuild/upgrade assistance
  45. excuse the newb question
  46. 95 GT Crashed
  47. Z303 cam question
  48. purge valve?
  49. 86 to 92 lx tail lens change
  50. in the middle of changnig inner tie rod ends...
  51. header bolt retighten?
  52. semi-cheap upgrades
  53. Buying my first Tang! 1994 GT
  54. What are the DIFFERENCES between an 87 LX 2.3L EFI & 87 LX 5.0L EFI from the factory?
  55. Clutch Cable Troubles....
  56. Explorer motor balancer?????
  57. Stock 95 Cam with a 90 Computer
  58. shifting problem in 1990 gt
  59. Emergency Brake
  60. Clearing codes????
  61. 86 gt throttle body
  62. Can't figure out CEL
  63. Too Rich? Please help....
  64. bbk upper n lower
  65. Save an Idiot.
  66. 73mm Caliper Question
  67. Counting the CEL light, need a little help
  68. 94 GT engine help
  69. GT40 head question
  70. removal of input shaft
  71. New rings?
  72. Throttle body, Injectors?
  73. upgrades on a budget
  74. exhaust help
  75. Cobra oil cooler on a 94 GT?
  76. help me pick out cam and pistons
  77. Milled heads, what will it take for the intake to line up
  78. How to remove t5 overdrive gears
  79. Mirror Removal
  80. AOD to T-5
  81. got my 88 coupe back...but the cats glow red hot??
  82. 93 5.0 Back Fire!
  83. Brakes
  84. Remote unlocks doors, doesn't deactivate alarm w/o repeated presses
  85. what size e brake cable?
  86. either starter/flywheel/something is grinding....
  87. Going 5 lug on my 90 LX street/strip. Few Q's for yall
  88. sway bar help...
  89. got some starter issues, namely power to it.
  90. Smog Pump hose/tube missing
  91. non mustang 5.0 specs?
  92. 87 rear sway bar fit a 94?
  93. 1995 t5
  94. Suspension Set up For the Dragstrip
  95. no power above 3000 rpm
  96. GT40
  97. problem with E-Brake
  98. Rear Gear Size Identification
  99. trans swap problem t5
  100. Fox Brake Swap
  101. 1995 GT 5.0 aftermarket ECM's????
  102. 98 explorer rear
  103. fan not running
  104. ok im back n real power n have questions lol
  105. trans temp gauge
  106. 351 head swap for 302 block
  107. procomps
  108. Some questions about my four eye
  109. EGR DELETE
  110. cheap c6?
  111. Just making sure Crane 44308-1 are correct with GT40P
  112. fuel pressure
  113. suggestions ??
  114. EGR & AC DELETE ?
  115. cigg lighter
  116. Rear Seal Leak, Brakes Stick
  117. 302 GT40 V8 Engine limits at 2500 RPM
  118. driving 50 miles w/ a bad egr and o2
  119. Ford Motor Co. Spindles?
  120. Lower control arms installation problems...info needed
  121. squeaky clutch pedal
  122. T-5 to AOD swap
  123. Rear end (8.8 28 spline to 8.8 31 spline?)
  124. Starter Solenoid question
  125. BBK intake system?
  126. mass air flow sensor upgrades
  127. Cooked Engine???
  128. FLOO TEK 5.0 FORD HEADS
  129. HEADLIGHT PROBLEM
  130. A few tech questions
  131. Intermittent Check Engine Light
  132. egr delete
  133. New Years GIFT :) and a few ?s
  134. 95 5.0 help
  135. 1993 4 Cylinder Conversion
  136. Attn Moderators
  137. Blown Head Gasket question
  138. How To Remove Power Steering Hoses
  139. Convertible top problem 92 mustang
  140. new Ram clutch trouble
  141. Swapping a V6 for a 5.0 in a 95'
  142. mass air tube
  143. 1994 mustang v6 motor swap for old school v-8
  144. running rough
  145. Mark VIII Fan Fitment Question..
  146. Front Springs.
  147. suspension question
  148. suspension and strut tower brace?
  149. I'M BACK! and with some new exhaust questions!
  150. H-PIPE QUESTION
  151. o/r H pipe will it fit?
  152. Need Help Building 347
  153. Underdrive Pulleys?
  154. OK i $%&#*@ up my t5 rebuild lol
  155. rebuilding T5 (3&4) slider question
  156. what size fuse for 150 amp alternator
  157. Bad brake problem
  158. maf, injector, and throttle body size help
  159. 4 pt k member brace
  160. wheel bearing nut cover on 95?
  161. ROUGH IDLE
  162. tranny
  163. is this the right controller for a electric fan install?
  164. Let's play "where the hell does that go?"
  165. 94 Cobra Oil Leak
  166. sn95 5.0 computer
  167. GT40P Heads
  168. GT-40 Upper
  169. HELP with check engine light!
  170. shorty or full lenght headers
  171. Hesitation under throttle
  172. One Peice HeadLights
  173. GT40 cylinder head question
  174. gt40 lower
  175. Questions on torn torque boxes
  176. T5 rebuild help...what bearing puller?
  177. Answer a question for me?
  178. Replace ball joints or Lower Arms?
  179. hoisting engine?
  180. Fuel Tank
  181. any idea where to start
  182. 28oz or 50oz balance
  183. Decent Combo?
  184. what stall for my car
  185. couple of ?'s
  186. 302/351
  187. Tips on passing CA Smog w/89 Vert?
  188. What Next?
  189. ac compressor squeaking bad
  190. Putting The Oil Dipstick Back In
  191. pcv valve
  192. Need some help from Carb guys
  193. The Mustang is running again, but with 2 orange headers.
  194. MSD 6al ?
  195. 5,000 RPM
  196. cam choice help
  197. Dyno Results!
  198. 1980 Cobra Parts
  199. Once again need help on what cam to get with new upgrades
  200. rear 5 lug conversion
  201. What supporting mods after H/C/I
  202. How Many Is Too Many?
  203. Power Steering Fitting Leaking
  204. c clip eliminator question
  205. Running too rich, Not a good Dyno result
  206. t5 question, whats up with this?
  207. How to Fix Low Coolant Light
  208. stock size 95 tb?
  209. Base Idle Reset and Car won't start again
  210. mustang idle problem
  211. 1989 gt charging problems
  212. Valve Stem Seal Question
  213. looking for a reliable power steering pump
  214. Swapping to Gt40 stuff, Coupple Qs
  215. CFI to Carb
  216. Throttle body
  217. Air intake = bad gas mileage?
  218. 5.0 stock intake spacer..
  219. Bent Valve
  220. 95 gt 5.0 help
  221. timing
  222. timken or national bearing?
  223. Oil pressure gauge
  224. 1995 kenne bell
  225. Installing Lowering Springs
  226. NoOB needs help!!
  227. chip in a 90 GT?
  228. 5.0 problems
  229. reducing tension on tensioner pulley for hp?
  230. Now What...
  231. AOD Shifting kinda hard?
  232. 5.0 donor car?
  233. Engine turning to powder
  234. Water pump replacement
  235. having some probs with my car
  236. installing front springs
  237. viper spec t56
  238. Fox body wire hide
  239. radiator
  240. What size Injectors,MAF, fuel pump on procharger install
  241. Help AOD shifting bad...
  242. t5 rebuild problem :(
  243. 300rwhp with these mods?
  244. turbo with speed demon carb?
  245. What size locking header bolts for Mac ceramic LTs?
  246. Brake light Intermittent
  247. gt-40p and crane cam springs
  248. AFR or Victor Jr. Heads? Why?
  249. gt-40 intake swap
  250. Vibration problem
