- Throttle body or cable problems???
- Explorer Motor in a 94GT...Whats needed?
- can you DD a 3000-3200rpm stall built AOD??
- GT40P heads... have EGR?
- rattling noise from rear driver side
- Engine build
- TPS settings
- emission system nightmare! Please help!
- Cant drive it anymore
- Confusion with clutch cable replacement
- E7 Heads
- inner tierod seal?
- Fuel pump problem
- rockers
- Stock gears in 89 convert?
- dying on 1st start of the morning
- timing cover
- Coil Spring Pigtail Orientation
- I Think I've Burned Up My Clutch
- Flow Tech Heads to Mid pipe
- 1988 2.3l 289 swap
- 94-95 cobra intake on fox?
- SN-95 big block
- Transmissions
- check engine light
- V8 Swap
- waterpump removal issues
- 1.6 roller rockers for stock heads
- Front suspension! Need input!
- 91 stang dead overnight help
- 88 gt 5.0 acting strange
- Suspension - Coil over conversion? Input welcome!
- T5....Do any of these parts need replacing?
- looking at this timing chain?
- BBK O/R H Pipe fitament issues
- Hub Studs Replacement?
- Wheel Spacers
- need help with ATI super dampr?
- cant find part number on victor jr heads?
- 1984 gt 350 to dual exhuast
- 94 GT 5.0
- Oil Pressure Gauge
- What TPS goes in my car??
- Head Identification
- 10" Draglite offset?
- Mustang fox body ECUs
- anyone running a UPR x pipe?
- Good chip for an `87 T-Bird?
- t-45 in a fox?
- 4cyl springs on the front? questions
- okay, what the hell is going on (Crankshaft/piston contact)
- rearend width
- HELP!
- 4 cyl t5 tranny
- 5.0 shaking... help!!
- 65mm EGR spacer or 65mm EGR delete bracket?
- Edelbrock Power package question
- Header Bolts
- sn95 fog light question
- overheating 347
- What Programing is out there
- fuel tank question
- need help, i think my heatercore is goin
- gas tank problem
- I think I broke my clutch cable...
- Engine Build Pics, etc.
- which transmission is better.
- key has to be in start position 4 car to stay running help!!!!!!!!!!!!
- Did H/C/I need a tune but what do i do
- no spark... please help
- question about EGR
- Head gasket maybe??????
- All bolts took a walk on me
- Ignition problem. Car won't start
- i need help!!!!
- 5-lug conversion
- Some advice please
- 2.3 to 5.0 EFI
- D80E Block
- Swapping gears and posi im told i cant put 4.10 gears in...
- Electric fan issue
- Trunk Leaking Problem
- Newb to mustangs
- Possible Head Gasket Leak????
- flywheel shim?
- Turn Signals
- Mod motor for a Fox
- Windsor JR 180cc heads...
- Engine has a miss!! HELP!!!!
- New to the forums!!!Looking for discussion on V8 swaps!!
- 4.6 to 5.0
- I hate voltage problems
- need some help on my seats
- proform rockers
- Rear axle swap question..
- How to use a proportioning valve
- Helping a friend with a carbed H/C/I
- AOD rebuild
- Need some help with street engine setup
- car sputtering and poping
- T-5 rebuild kit
- Rim/Tire Help
- KOER KOEO Codes
- A9P or A9L ECM??? HELP
- preferred intake manifolds for my car
- starting problem
- T5 swap done, 1 question though...
- just a thought
- 10 MPG!!!! wth
- gt40p heads combo help!!
- Installing short throw shifter in fox body stang!!
- UPR Coilovers
- what do i need
- clutch cable
- compression ratio questions
- Arched Battery need help
- h/c/i swap
- Cant Pass Pennsylvania's emissions... need help with decision
- help on 91 lx build
- how to remove horn pad
- c4 help
- 87 engine (efi) into 84 (TBI)
- Please Read, Help!!
- Any link between the two...????
- Running 24lbers with SD
- 97 cobra 302 swap
- t5 tranny
- 1 pc. Rear Main Seal Question
- car wont run
- anybody??????????? idle prob
- New Spark Plugs
- 331 injectors!
- v6 to v8
- 7.5 to 8.8
- how to install bumper covers on sn95
- holley heads?
- Help with suspension
- question about bypassing EGR valve
- 3.73 or 4.10
- carb'd supercharger
- supercharger?
- 4cyl to V8 swap Question.
- Distributer Module?
- Positive Crankcase Problem!!!!
- hatchback rear seat in a convertible?
- [B]Two blown head gaskets[/B]
- Question about Gt40's
- Engine, Tranny swap into rolling chassis
- 302 rebuild suggestions
- Finally after 2 years
- Wiring Up
- stock forged 4" pistons
- still having transmission problems
- EGR spacer delete?
- Quick Question.....69 Windsor or GT40Ps?
- max lift on gt40p springs
- 5.0 swap
- Smog Eliminator Kit SN95 (95)
- pilot bearing eaten?
- Which injectors are these?
- witch diff locker to get?
- Help! Starting Problems
- k member qa1
- Torque Converter whine in AOD?
- 99 Explorer 5.0 Into 94 Mustang
- SN suspension suggestions
- adjusted clutch cable too much
- my 1991 mustang vs my buddys 22005 dodge deisel....
- Mach and Cobra springs
- Help me with springs!?
- stroker engine build up
- 17X9 wheels with 96-98 spindles??
- traction lok clutches
- I need Auto Trans Help
- Radiator fans are dead, anyone used Mishimoto fan shroud?
- Engine Question
- Start and Die - Fuel Pump?
- cfm gain from 3 angle valve seats
- Looking for a look-over
- AIRBAG light
- Question about rims.
- Electrical Issues
- Fuel Mileage
- questions about radiator
- Pedal placement
- Anderson B-31 cam?
- 1984 GT - Suspension Upgrade Advice Please!
- Did my fuel pump take a dump?
- Spark plugs for GT-40P heads
- GT40P heads
- MAF conversion, bad cold idle/intermit starting probs, KOEO KOER results... help
- F303 cam questions
- want to upgrade brake booster for disc?
- 5 lug brakes and wheels--- just buy sn95??
- 4.10/4.30/4.56 Acceleration
- Help with Valvetrain Problems!!!!!
- 351W heads on a fuel injected 302
- throttle body injection
- Explorer intake
- alternator question from new member
- NOW MY CAR RUNS
- Won't idle
- Cast parts vs Forged
- Injectors???
- Fuel Pressure?
- 95' mustang auto to manual conversion
- quick valve question
- TrickFlow Street to Track Intake
- Header back exhaust
- Cruise
- New to thread and had a couple question.
- Question about an Engine Swap
- How long will these 5.0's last?
- t5 Question
- Headers
- pistons
- couple of questions about head/cam set up
- Possible Wheel and Tire Combo
- C&L inlet pipe.
- xe274hr gt-40 cast iron heads
- Road course spec suspension
- sn95 Strut Bolt Size?
- another question for fellow techs
- 88 turbocoupe rear
- Idle Mixture on Holley Carb.
- Spark Plugs
- Biggest/Best tire on 10 holes
- is new mass air meter needed
- Engine main bearing clearance, need some quick input plox
- just pulled codes need help!
- Rear Suspention Suggestions
- Rockers
- 302 Wiring harness on a 351W?
- headers for a boss 302
- got some rust...
- just wanna run crank waterpump and alt pulley how do i??
- REPLACING MY CLUTCH WHAT DO I NEED?
- Oil Pressure
- EGR/Heat riser question
- Major clutch cable problems! Need help please!
- Headliner???
- pulling motor
- heads???
- looking to buy a 5.0 need some help
- Diff Fluid
- stalling out right before I stop
- URGENT! FP relay!?
- Lost the clutch fork housing screw!!!! HELP!!!
- hanging idle to idle surge?
- Fuel Pressure Question
