View Full Version : 5.0 Mustang
  1. thud?
  2. switching to MAF
  3. Clutch Problem HELP
  4. cams
  5. 17x9
  6. clutch cable seems too tight
  7. 306 advantages?
  8. high beams
  9. Fuel System
  10. valve springs & lifters help
  11. Pacesetter
  12. strong smell of gas after fillup
  13. Steering shaft
  14. Valve Spring Trouble.
  15. 95 computer code reading???
  16. Widest Rims that will fit
  17. Valve Springs and Roller Rockers GT40P heads???
  18. best carb for my car?
  19. I need to find parts and solutions for problems! I need HELP!!!!!!!
  20. 1991 5.0 fuel injector does not pulse #1 cyl
  21. Factory appearing headers
  22. The stickied "Tech Articles"
  23. mustang 306 build up
  24. stroking it
  25. Supercharger
  26. 84 gt rearend
  27. spark plugs
  28. axle question
  29. Rockers
  30. headlight switch knob
  31. auto to clutch pedals switchs
  32. switched
  33. Can You Please Tell Me What Is Wrong With My 5.0
  34. Can someone explain how a Tweecer works
  35. Turn signal flasher location(87 Fox)
  36. 8.8 Build
  37. 331 running rich
  38. gt40 and gt40p max valve lift?
  39. Emissions- Hydrocarbons, remove spout connector?
  40. 1 5/8 Equal length headers or 70 mm throttle body??
  41. Turbo Cam ?
  42. cobra blower swap
  43. 351W Cylinder Heads on a 302 (5.0L)
  44. Ranger Axles
  45. no crank, just a click
  46. Water inlet part mt the thermostat??
  47. B-303 and 1.7RR
  48. 65mm or 70mm Throttle body?
  49. IM SO FED UP!!!!!
  50. New here, rebuilding 302, many questions!
  51. NEED GOOD PERFORMANCE SHOP IN RI OR MA.
  52. No spark or fuel after 5.0 fuel injection swap
  53. 331, Twisted Wedge Combo Questions
  54. what size mass air meter will be good for 24lb injectors
  55. bleeding brake problem
  56. 351 heads on 302
  57. throttlebody help
  58. help with altenator
  59. wont stay running
  60. battle boxes
  61. Widest tires on fox?
  62. 93LX rear disc break conversion
  63. What cars...Timing Chain Cover
  64. stock 85 intake rpm range
  65. I don't know what to do about a shortblock :(
  66. what year diesel ranger has the pilot bearing to use a 2.3l t5 with a 5.0??
  67. auto 2 stick swap
  68. used t5
  69. 79-86 Brake upgrade with stock spindles
  70. Ignition Switch Cylinder Questions
  71. lets talk swaps
  72. compression question
  73. NO SPARK, NO FUEL.. ECM?? Need help!
  74. Is the water to the EGR spacer needed???
  75. 347 cam help
  76. F1 Racing stage 1 clutch
  77. 93 cobra intake vs 94/95 cobra intake
  78. 93 lx brake rotors different?
  79. Stock front rotor diameter?
  80. Can this be used without switching to carb?
  81. What tool to remove ignition module off dist?
  82. questions aboutcar computer
  83. Eddy RPM II...hood clearance????
  84. whos got the info on MAFs and tuning?
  85. post a want ad again and you will be banned
  86. fox struts on sn95?
  87. Car won't start... no spark
  88. Gears
  89. Widest tire on SN95
  90. another injector question
  91. vibration problems
  92. gas leak?
  93. what to expect with a 347
  94. how to test injetors
  95. Switching from FI to Carb Need Help
  96. Looking for 300rwhp
  97. Replacing control arm bushings
  98. flow numbers for gt40 heads and gt40p
  99. Installing an AOD
  100. oil pan
  101. Edelbrock Performer VS Performer RPM
  102. stock bottom end rpm?
  103. Need help quick
  104. Electrical Help Needed
  105. Help?
  106. HELP!!!!
  107. my engine build progress!
  108. HELP!! it's raining & my vert leaks bigtime
  109. Problem with my 92 5.0
  110. Rear seal leak question
  111. tremec 3550
  112. stud girtle ?
  113. probems wit brake lights
  114. power loss when i floor it
  115. Horsepower!!!
  116. GEAR FLUID
  117. 1994 Mustang GT OVERHEATING?????
  118. Oil filter mounting location problem.
  119. Whats better-C4 or T5?
  120. power seat
  121. stuck on intake for my 347?!?
  122. Rear bushings
  123. AMP PERFORMANCE FLYWHEEL VS FIDANZA FLYWHEEL.
  124. HISSING SOUND COMING FROM UNDER MY DASH NEAR BRAKE PEDAL????
  125. Hissing noise of sorts?
  126. seat lean
  127. Seafoam
  128. how can i get 300hp cheap?
  129. Looking for help spening some money
  130. EFI parts
  131. best stock heads
  132. Finally got a video! Help diagnose problem...
  133. Why the disco headlights? Someone help
  134. How to 5 lug conversion
  135. Required TB size
  136. Tripple hook clutch quadrant
  137. Speedo Drive Gear (AOD to T5 Swap)
  138. Bad News... I Need your help!
  139. Header back exhaust
  140. Gauge pod for steering column?
  141. can u really adjust the e-brake?
  142. Battle Boxes
  143. Rebuilding Trac Lock
  144. Clutch Wont Stay Adjusted
  145. tire question
  146. Intake manifold Gasket leaking coolant
  147. lower ball joints?
  148. 5.0 gt one wheel burnout??
  149. Head Flow Data
  150. Clutch Question
  151. Brownish Power Steering Fluid
  152. 1.7 Rockers won't fit GT40 Heads...?
  153. bad solenoid?
  154. Head/Alternator swap, belt won't fit?
  155. new o2's
  156. REPLACED TRANNY
  157. poert and polish question
  158. clicking sound
  159. Car Wont Hold Charge
  160. junkyard find question
  161. Help Me Decipher these Engine Block Codes
  162. Rear Control Arm Bushings
  163. Engine building questions
  164. wont stay started
  165. Starting the one wheel burn
  166. Spider gears help!!!!!!
  167. Boxing in Lower Control Arms
  168. Starting problems...
  169. New member-Well to this area anyway!
  170. Brakes!!!!
  171. gt-40p stock springs e303 cam
  172. '95 GT Need Fuse Layout!!!????
  173. help! car wouldn't shut off!!
  174. canfeild heads ?
  175. retorquing lower intake after running engine
  176. Gauges go crazy and wipers stop working
  177. Question about IAC.
  178. 93 302 assembly questions
  179. new to me notchback
  180. exhaust setup?
  181. fog light bulbs?
  182. 5.0 motor swap
  183. TR-3550 HELP
  184. throttle body question
  185. Help!!! Installed intake and no start
  186. HELP..What pair of bushings go here? pic
  187. 92 rear axle length
  188. 1995 5.0 timing
  189. Will not Idle
  190. EGR Vaccum
  191. pcv valve
  192. A9L WITH MARK 8 FAN !!!
  193. quick question..
  194. how do u clean out injectors
  195. Oil inside Upper intake manifold
  196. NEEDING SOME ADVICE 347
  197. Flowtech l/t headers!
  198. Help...again
  199. Electrical Prob. Need Help
  200. Baffled with a noise
  201. no heat due to faulty water pump?!?
  202. Vortech Boost Question
  203. ticking
  204. 1993 Mustang GT
  205. LX Summertime Wheel Paint
  206. no headlight ?
  207. tdc on #1
  208. Need Help Asap
  209. Tire Size?
  210. GT40 Heads
  211. a9l vs a9m
  212. help Identify heads
  213. Quick Vortech Bracket Question
  214. Holley Red Pump Noisy
  215. installing gaskets on explorer lower intake
  216. Rod Bolt Replacement
  217. clutch problems???
  218. ignition
  219. Help
  220. 5 lug conversion spindle question
  221. Oil Pan replacement
  222. 5.0 GIRDLE
  223. noise
  224. another header ?
  225. my brakes are driving me crazy
  226. dogbone
  227. Victor Junior Heads ???
  228. Headlights
  229. Coil overs for 1985 Mustang GT
  230. swaybar question
  231. Eagle
  232. Fox Body Rear Coilspring HELP
  233. Ready to Rebuild
  234. CA LEGAL?
  235. 5.O Knock, Please Help
  236. 86 gt(backfiring out intake
  237. fixed gas gauge problem!!!
  238. Shock/Strut tower replacement
  239. destroyed door lock switch. HELP with wiring
  240. Smog pump delete???????
  241. where to get the cheapest roller 331 or 347 crate engine
  242. help disabling the factory alarm
  243. HELP
  244. converting 95 mustang gt 5.0 to a HO 5.8 351 help
  245. Scrapes on Intake ?'s
  246. What Size Alt?
  247. 89 Mustang Gt 5.0 how to get engine codes?
  248. '94 5.0 Clutch
  249. 99' cobra wheels w/ 3/8 spacer...won't fit!!!
  250. engine rebuild list
