- Vibrating when decelerating?
- Your MPG?
- 17 inch pony r wheels?
- Need help with bottom end
- a few ?'s
- fuel injectors
- exhaust
- a/c delete sucks
- Scary battery smoke. please help
- car wont go past 4000rpm
- RPM durability
- 100k miles and a blower
- What's a 5.0 Cobra intake worth?
- Heater Core
- **UPDATED!!** Starting problems.........continued....
- 5.0 with a C4...Who's done it?
- issue when turning car off- 87 stang
- Combo Help
- AOD fast shifting then slips in overdrive
- fuel pressure regulator removal
- another 5.0 head question
- best clutch suggestions
- INTERCHANGABLE??
- who all!!!
- Replacing U-Joints with C Clamp
- T-5 reference # question
- pw relay
- adjustable fuel pressure regulator
- 331 stoker?
- cobra intake
- what do you think of this tranny?
- pulling trans, have ???
- little prob here...
- tell me if this setup will work ok
- whats this time??
- turn signal switch
- LOUD!!
- Fuel filter question
- Need help....any ideas from the pros
- Belt Problem
- SERIOUS Drivability Problem HELP!
- drag car only,need some help on engine parts.
- 5.0 AOD Transmission
- Bad MPG?
- NAKED CHICKS!!! BURNOUTS!!! 5.0s!!!
- Cold air intake ques...
- Cobra Swap
- sound
- Carb spacer & brakes
- speed help
- here's a brain teaser...
- Me Vs. C230 k
- Video Clip of my Car/Exhaust
- Stroker Durability?
- Well, crap......
- wierd idle?????
- slight problem
- TALK TO ME !!!
- weight Diff? on 79-86 to 87-93
- More dumb timing questions...
- Economical 4-5 Lug Swap..?..
- heat extractor hood
- THANKS EVERYONE,REALLY!
- installing a cam
- New to community...!!! Motor question..
- Broke key in ignition
- Which heads?
- New Motor Options
- 5.0 cobra/1993 Injectors dont work?
- 87-? cheese grater tail lights..?
- Help quick (3g alternator)
- Some kind of lean issue
- TPS from another car?
- gear install Q..
- Plug gap
- shifting/2nd gear issue continued..
- Best Rear-end gear?
- 2 Quick Questions....
- Slow 1/4.... help!
- Shattered Yoke, Need U-Joint Rolled I mean Help!
- Quick help guys... Need fast answers, leaving to race in 2 hours
- A/C Removal and new hose??
- Fuse box and diagram
- Motor Mounts
- broken bolt blues
- idle ?
- What mods should I do.
- Foggers on an LX?
- Same spark plug question, different day....
- My block after rebuild?
- Can I get a fuel pressure gauge that mounts here???
- 95 cobra brakes question??
- anyone with mikey tompson et streets??
- Anyone ever use?
- Power Adder, can it be done?
- fan too loud
- mexican block???? diffrence usa!
- Swapping power windows for manual?
- What exhausts do you prefer on a 94?
- sub frame connectors
- Carb Vacuum Lines
- Stock wieght, and wieght reduction.
- Heads
- what do you think?
- suggestions and opinions on ignitions boxes
- HEATER CORE REMOVAL AND INSTALL HELP!!!
- K&N vs. cold air
- Idles At 2000?
- Look at what brown did for me!!!
- GT/LX...Notch/Hatch... better?
- MOVED: ProCharger Or VortecTurbo
- Sagging doors
- Smog Delete
- ?LX/GT?
- Oil Filter Relocation
- WHO Has The Sickest Stang On Mustang Forums
- HOw much hp on stock block
- loud?
- so bad.
- I have $7000, what should I do?
- 95 comp
- h pipe
- line lock
- throttle bodies and egr spacers?
- 5.0 Heads
- 1988 notch.
- Losing Wieght.
- Finally.. Got My Timing SET:)
- ignition coils
- Temperature problems. Please help!
- f***ing rain
- idle
- car is running bad
- custom chips, need help
- Has anyone tried this???
- wow... im dumb
- Paint and paint prep questions
- Throttle sticking?
- Not running right, PLEASE HELP
- numbers off a stock meter please
- 4 Lug on 5.0
- cam specs
- Water temp ques....
- painting rims?
- Will 94 Headers work on 91 302?
- Recalibrating
- Hyper Pistons
- My 5.0 block to a 5.4,
- MAF Pegged at 2.5V?
- Finally have a picture to post
- upgrading alternator!
- Compression?
- Stock Operating temp?
- I want a computer for my car what should i do ?
- Short tube headers
- Good deal on these heads or not???
- Timing?
- Mass Air and Injectors ??
- lookin for cobra r rims??
- How hard is it to rebuild an engine
- need help
- Some questions...nitro, tranny...
- Can I get my money back?
- CAM idle is gone??
- MOVED: So, I smoked a 330ci tonight...
- 113 octane in 88 gt 5.0 no mods
- Turbo Track Times...
- MOVED: 5.0 vs 5.0?
- yet another CAI install question...
- 3.43 or 3.73 gears
- afr 165 and KB
- 91 octane and 18 degrees really worth it???
- What other years tail lights fit 86?
- SN95 Cobra Running Bad.
- tranny question
- Best engine
- help me choose!!!
- T5 tranny
- Power Locks
- help with rear springs!!!
- Is Redline Gear Oil red?
- 2 fox's on pinks
- Which cam to buy
- Convertible Top Products?
- aftermarket lights
- Vacuume line help!
- so i just found out...
- What oil to use
- o2's going bad again
- Tighten header bolts after heat upso you dont blow header gaskets
- Spark plugs ????
- what transmission should i use?
- Rotor ques...
- '82 Scoop installed!!
- convertible question
- drag radials, which are the best??
- Front suspension making clunking noise
- Need help with codes..
- waht timing
- 5.0 302 engine rebuild
- want a badazz radiator, suggestions please!!
- neone in GA near jackson area??
- transgo shift kit HELP PLZZ
- MOVED: BOOST
- i'm shooting fireballs
- Dumb ques..
- 5.0's response to mods?????
- 1988 notch,should I buy?
- loud clunk from the rear end
- is my 95 gt coupe slow??
- What to do..
- Going To The Dyno on Saturday!
- wheel hopping?
- MAF conversion question
- Altenator???
- MAF Conversion Kit from Summit
- 331 stroker from dss
- lentech street terminator lockup?
- My Tire is Loose from the 9 and 3 o'clock Position?
- Hard clutch
- RACE
- intake manifold
- Pink stuff dripping from my diff.
- tranny rebuild price
- Front Nose Alignment
- BIG BLOCK OR NOT?
- Please Help!!!!!
- Harmonic woes...
- 1990 5.0 upgrades
- 5.0 kicks ass!!
- Steering wheel ?
- ford e303 cam worth it?
- transmission question
- Should I buy this?
- BBK header / x pipe fit?
- Plz Help! noob questions
- sn95 dash in a fox
- question on painting car
- MOVED: twin turbo? or supercharger?
- intake manifold or heads what to do
- Newb to fox body question.
- which is better? smog legal or not?
- afr 185's or vic jrs.?
- Blinker Problem again
- Anyone know where to get custom carpet
- new block
- power window
- Rear axel codes
- Need Help On Timing Car...Tommarow ill have it in my shop at work ..
