- runnin like a slug
- car took a crap on me
- hood?
- fuel pressure reg or not?
- Im in a Huge bind here!!
- hard top for vert?
- what kind of ranny fluid, and oil
- clutch, flywheel size? ASAP
- Installing a TB
- a little tranny annoyance fixed now
- Check out my Battery relocation
- Wiring issue
- how to remove head rest???
- Little Clutch Vibration
- a/c recharge
- 86 t bird help
- black bullits on a black fox???
- pilot bearing question
- STK 302 CAM SPECS ?
- injectors and regulator
- FINALLY Installed My New Wheels
- Need help finding a blow off valve??
- Plugging up smog holes
- 65mm TB?
- how do i remove the smog pump
- Lets see some sick SN-95s
- Explorer intake question
- What are the symptoms of a faulty TAD or TAB Solenoid?
- 95 GT Auto Stock RWHP
- Dumb ?
- Spacer...is it worth it?
- Transmission Cooler From C 4
- MOVED: 351windsor & 351 clevland
- efi to carb swap???
- 5.0 swap help....please
- MOVED: Run in with Chevy SSR
- Need some help
- question about shift kit
- 5.0
- 4 lug disc?
- Injectors are the worth it?
- Electrical problem
- Drive shaft q?
- Sidelamp bulbs
- Am I an Idiot??
- Looking for GT Cheesegrater Tailights, Anyone Know Where to Find Them?
- slipping clutch
- Rear springs
- 302 Boyz
- Wierd Idle
- Oil delivery?
- vacuum line?
- dead spot
- can anyone answer
- cam question?
- Egr spacer cooling lines leaking into intake.
- gt40 heads
- steal or not?
- Engine Rebuild Need Suggestions
- Need an Expert
- I just got my U/D Pulleys!
- '86 exhaust vapor (smoke)?
- Does it have to be...???
- ***Belt Tentioner Pully Please Help***
- Rear window louvers installation tape?
- NEED HELP FAST PLEASE!
- Engine Update!
- Front Alignment
- few questions 94 gt.
- BOV?
- Sickest looking front bumper for SN-95
- Long vs Short
- exhaust
- TREMEC T-5
- Will I regret buying a '95 gt?
- running lean?
- #19lb or#24lb
- top speed
- Clutch an tranny....
- flywheel question
- By-pass surgery
- Help me identify the maker of this wing
- Should I Buy-em?
- Newbie Q's about 94 GT, any help appreciated...
- Symptoms of a bad harmonic balancer?
- Good price on mobil 1 10w-30???
- mustang racks
- Rims or no rim
- aod rebuilt?
- Couple of ques's....
- new radiator
- new radiator
- how fast do you all think
- sooo how much..
- Buy or Pass
- Spout Connector?
- Spout Connector?
- intake?
- spindles?
- first speeding ticket
- TIMING ISSUES!!!
- HPM megabite jr's and 90/10's?
- 5.0 info!
- first upgrade either 2 flows or 3.73 gears
- Ignition coil question?
- gear and head questions
- neutral safety switch
- 95 V8 SWAP, Some info needed.
- Having a problem.
- A/C question
- I have no idea whats wrong
- Exhuast...What to do?
- changing exhaust- need an approval of it
- 82 EFI...
- center caps
- So... Who's done a 2.3 to 5.0 swap in a 87+ Fox...
- MOVED: LT1 VS Modded 89 LX
- spark plug q
- header question
- Whos got Shorty unequal or equal headers?
- fuel injectors question.
- trick flow stage 1 or stage 2 cam?
- drivability issue
- fuel issues
- oil pressure drops when over 4k rpm
- 350 in Rustang.
- How much HP to the wheels?
- Rhythmic vibration at 75
- Whats she got?
- Mas help
- shocks
- ANYONE FRMO NEW ORLEANS AREA?
- 5 lug swap with 99 cobra wheels?
- best shocks? strictly straight line!!
- Starting to resemble a running motor.....
- My 87 Hatch
- Underdrive pulley Help!
- MOVED: kenne bell boost
- Quick...i need a really quick answer to help someone!
- intake/carb question
- Engine Balanceing?
- spool or lim. slip differential???
- broken head bolt
- timing chain.
- sway bar
- Got a ?
- Good place to shop for rims....?
- Auxiliary Transmissions
- Intakes.... Street or Track heat? Please help!
- Control Arms Anyone? INstalled!
- Installing '82 scoop.
- Back to '86 instrument panel lights...
- Heater core headaches
- Update on stumble/stall
- hp #'s....
- rear 1/4 window inop
- What's the deal with explorer intakes?
- Heads ques...
- Mickey Thompson ET Street Drag Tire
- Quick ?
- NEWBIE!!!!!!
- Whats a 5.0 bottom end good for?
- combo suggestion
- OIL QUESTION NEED ANSWER ASAP
- PLEASE HELP?
- different branded xpipe and header question
- Clearence issues 94 GT!!
- Weight Reduction 101
- Battery relocation
- weight reductions
- brake?
- how to go around inspection with o/r hpipe
- Hurry! Need Answer Quick!
- Will it fit
- Drive shaft loop and oil pressure line?
- 1/8 mph
- Backfire through intake??
- MOVED: 5.0 block supercharger question
- New x pipe = check engine light
- Throttle body
- dead pony...any info or mechanics?
- mixing tb and egr brands
- Anyone doing carfaxes still?
- Converting my 5.0 foxbody to a 4.6 32v cobra engine?
- Massachusetts anyone??
- wierd IDLE
- WHAT WILL It cost??
- what to do with my AOD??????
- 400 hp with a stock cam and AFR 165s?
- The newest member of my family!
- To those with heads and cams...
- stock header or not?
- ac condenser removal
- Should I check it out?
- 88 5.0 Electrical Problem, Just Bought Car
- Who has done 1.7rr's on stock heads and cam???
- !!!! anti-THEFT controler
- Idle way too high when car is hot
- Whats this short block worth?
- sound?
- harness length...
- new pictures
- which style do you own
- slp for the gt
- Poly motor mounts?
- need help, 87 o2 sensor locations beginning and end
- Guages
- engine problem
- another good ole cat ?
- transmission acting funny!!!!!!
- What driveshaft saftey loop to get?
- Ok guys...degree my cam..
- good price?
- bbk headers and h pipe w/ cats
- header size diff....
- 4 lug rims
- What about these?
- bored so i took pics
- horsepower question
- subframe connectors - which kind?
- new starters suck to install
- Anyone going this year?
- Programmers
- window moldings?
- car backfired
- Are These Gears Junk?
- tremec from 2000 gt fit in 86 gt
- For you GTI lovers.
- Curb Weight
- Is installing a EGR Plate important?
- Need advise
- Speedo Gear?
- Ricer's get a real car - Hilarious vid on streetfire
- spark plug wires
- window play
- 8 Why such low horsepower?
- LS1
- tranny troubles
- Need the experts' help for a moment...
- horsepower call out
- rear main leak
- Help with a/c delete install
- 1994 SVT Cobra
- throttle body?
- MOVED: 1983 GT with 250 shot is that to much
- question what would you get?
- Oil filter BLEW MY MOTOR!!!
- Anybody in Houston, Tx
- research paper is almost done need some more info to finish
- Suspension upgrade
