- Smog pump delete???????
- where to get the cheapest roller 331 or 347 crate engine
- help disabling the factory alarm
- HELP
- converting 95 mustang gt 5.0 to a HO 5.8 351 help
- Scrapes on Intake ?'s
- What Size Alt?
- 89 Mustang Gt 5.0 how to get engine codes?
- '94 5.0 Clutch
- 99' cobra wheels w/ 3/8 spacer...won't fit!!!
- engine rebuild list
- MAF/Injector size difference
- TREMEC 3550
- alternator kit Anygood?
- 17X9 Bullitts w/ 275/45's...will they fit?
- Will these wheels and tires work?
- EGR Issue
- quick cam question
- Underdrive pully's
- gasket question
- Heater Core Good or Bad?
- troubles with a '89 Mustang 5.0
- eaton rear end?
- octane and timing
- Where to find a nice c4
- quite a hesitation not too sure help me
- 306 supercharged computer ?
- check engine light turns on when smashing on it
- Bad floor pans
- Quick help please - Will 1.6 rollers fit GT40 Heads?
- Rocker profiles for stock E7 head
- smoke + tailpipe question
- placement of starter wires
- Supercharger Problems
- feathered oil pan gasket
- Metallic Rattling noise
- Cam Bearings?
- Timing chain sprocket stuck on cam
- Where is my computer and which one would it be
- stupid question but let me know
- 89 to 90 Cluster Swap
- Putting a 70 302 in my car.
- FNG.. mass air question
- Project 306 - Patriot Aluminium Heads Your Opinion on Cam.
- Temperature sending unit!!!
- Idling problem after driving
- trans decision
- Where does this wire go under the hood
- in need of technical info....
- RIP
- new cam installed
- solid motor mounts?
- Consistantly Blowing Header Gaskets!!!
- 5.0 H.O. Question?
- Exhaust, Intake
- Leaking coolant
- Code 22 w/ new map sensor
- balancer questions
- 1979 Mercury Capri Vacuum Lines
- Venom 400 Control Module?
- Will these pistons work for my setup?
- Throw Out Bearing?
- Still getting code 91
- dizzy question and pic
- stock rearend
- solid or hyd roller in 347?
- need help quick
- 94 gt wont start :(
- 18 volts at idle!!!
- 4.10 speedometer speeds
- AOD's Please!!
- fuel pressure problem
- solid roller springs with hydro roller cam?
- 4.250in stroke in a 351?
- HAVE BACKFIRING/HESITATION PROBLEM WHEN COLD OR SITTING AT IDLE THEN ACCELERATING!!!!
- what 5 lug conversion is right for 02 oem bullitt wheels
- One side of car higher than other?
- Headlight Issue...
- Blinker light stuck on!?
- Difference between fox body and sn95 pulleys?
- carb to efi
- New seat bracket
- are these injectors good?
- aluminum flywheel
- Question about Belt length.
- Aftermarket Headlight Review/Rating
- Window Louvers
- wiring power seat
- hypertech performance chip
- help with tires PLEASE!!!!
- Throttle body too big?
- let me know what you think of my new motor setup!
- Suspension Question
- is this process the same for our cars?
- wiring help
- Question about O-Ringed block
- what harness do i need?
- Convert EFI to Carb
- Fuel Level Guage Issue
- 306 deal or no deal help plz
- 1979 Mercury Capri coolant plug
- coolant resivor relocate
- 8.8 or 9 inch rear
- power window help
- Which pistons to go with?
- headers type
- Block
- 1.6 or 1.7 roller rockers? e7 heads
- Clutch related squeak...
- Best Heads?
- Lights blink randomly on startup
- Car thinks it's starting when it hits bump...
- 450+ HP with a 302. Comments
- Would a 429 work in my 95 mustang?
- Gears
- cam and heads?
- 1.7 rockers
- performer rpm vs victor jr on a 347?
- what all came out with gt40 and gt40p head and intakes?
- Anyone running an AFM camshaft?
- Time to blow some money...
- fuel pump problem
- Tail Light Panel
- Idol way too high
- need opinions asap on header gasket.
- intake torque sequence
- Question about white exhaust.
- Paint Question
- E7 heads on a non H.O
- where can i order a t5 shift fork set?
- what maf to use with 24# injectors
- Being Dynoed
- 347 Build , New Block - Heads & Cam. Need Advice!?
- supercharger question
- looking for a H/C/I kit
- Advice on fuel injectors and fuel pump needed
- Stock wheels v/s after market???
- ford rotunda 007-00500 series
- 1 5/8 or 1 3/4 headers?
- Flushing the block
- couple cleaning question
- shory headers
- How much would you have to mill a 60CC head to get 58CC's?
- Axle Shaft Differences
- 95 5.0 nedd some help guys
- need to check the lift on a cam
- help
- 90 Mustang loses power in 3rd.
- heat blinkers and dying
- not even 600 miles and....
- Mercury capri tensioning arm
- probe engine kit
- Got a little Project
- 87 5.0 wont start
- Welcome new 5.0 section moderator!!!! ~MJR46~
- Valve Cover Gasket Replacment
- Building my first car
- Need Diagrams
- 1st gear sticking
- changing coil
- mustang heads? E7 vs gt40 budget? get stock redone vs stock gt 40s?
- 1979 Capri VS Mustang
- Help with heads?
- Intermittent start
- Privacy Liner
- AOD filler tube install
- Oil Pan
- 2.3 to 5.0!!!
- loss of power
- Carb to EFI conversion?
- Exhaust mix/match?
- Changing the speedo gear on T5
- Windsor water pumps
- ? Kenne Bell Blowzilla
- Internals question and 02 Harness Question
- What is the best way to store heads??
- 73mm 38mm brakes & factory proportioning valve?
- question about vacuum connection on firewall?
- Clutch
- mercury mountainer
- strange noise
- Gt40p's and TFS1 are in!
- just had clutch cable replaced cant get into 1st
- Why Not 355?
- Speed Sensor
- 347 parts list
- rocker question
- cometic head gaskets?
- notchy shifter...
- Turbo my 5.0
- Gear Drive
- Maf question
- Time for U joints....1310 or 1330's
- 28 oz flexplate?
- 302 setup question
- thread size on gt40 head rocker arm holes
- what size TIRES should i run on front?
- torque converter stall
- do they make this
- Great Mustang shop in lagrange,Oh
- Opinions please, stud mount or pedestal
- speedo question.
- UD PULLEY HELP!! STUCK!!!
- Help with friends brand newish 91 fox
- Auto trans for setup???
- have spark around all spark plugs
- help!! grinding in reverse and third
- instrument cluster
- Can youtell me what this numbers mean? engine recognizion
- Frame Twisting???
- Rear Diff??????
- Drivability problems at low slow speeds
- I Broke My Trans!!!!!!!!
- Could i have an 85GT motor in an 89GT an pass smog?
- lift off hood? Hood pins?
- 90mm MAF?
- i need some advice????
- 1994 gt help on front clip removal
- 2003 cobra wheels
- Aerostar driveshaft
- Electrical Problems
- Manual vs Pwr door
- Rotors
- Fog Light question
- How to tighten e-brake?
- Suspension Time!
- Joining you all soon...
- Power windows and door locks advice
- Cutting Wires
- Fuel Question
- whats wrong with my pony
- Pro Comp Heads 190cc
- Need Pictures and Info
- i want to remove my heating system?
- Differential Cross-pin
- UPR front suspension
- 5.0 swap in v6??
- Is my clutch/trans going to explode???
- question for my fellow techs
- jerking
- trans
- A9L to mark 8 fan?
- 1979 Mercury Capri Exhaust
- quick clutch quadrant question:
- t5 to t56 swap questions
- gt40 vs gt40p heads
- Aftermarket tach?
- wont start help!
- What brand of mass air should I buy.
- Any1 ever heard of this? I havent
