- sloppy seconds
- How to tell what gears
- cleaning upper intake
- seafoam
- MOVED: Who would win.
- MOVED: The real reason my wife loves me!!! (pics)
- '87 5.0 miss firing and back firing when cold
- The HP guessing game
- POWER STEERING RACK QUESTION
- MOVED: 5.8 conversion
- Tweecer RT Question?
- TAKE A GUESS?
- tps
- i am friggin screwed!!!!
- MOVED: lmao funny story
- whats this noise
- engine for a 87 foxbody
- Tune up
- T-5 Help!!!!
- Headers
- Air filter question
- what part is this????? NEED HELP
- Major electrical problem
- how strong?
- Should I Smoke?
- Got a short block dilemma...
- quick question
- My new plans for my 5.0
- 94 GT w/AODE
- Car changes over the last week
- torque box weld spots?
- my new 5.0 + questions
- PMS System
- MSD ?
- are my o2's cooked from blown hg?ADDED QUESTION?
- Will a 26x10x15 slick fit on a 87 GT rim?
- blocks?
- SN-95 body kits
- Exhaust
- Mac pro chamber off road h pipe
- fuel rails?
- 4 banger spring question
- Lowering my ride
- 89 gt, sputtering at high rpms
- all i need...??
- New 5.0 Pics
- best way to smoke headlights?
- Engine Noise
- Tuning...
- Sitcker decal? Yay or Nay?
- 400 rwhp
- E7 help please!
- MOVED: supercharger?????
- shocks and suspuch i'm looking at to get all thisdention
- whistle?
- 5.0 Mustang and Superfords magazine?
- 75mm TB ?
- dont know what happend
- MGW short throw shifter owners be heard!
- Borla exhaust
- 5.0 problems...PLEASE HELP!!!!!
- New Rims installed on da GT
- whick kb pistons?
- Picture question.
- foglight question?
- What interior paint?
- valvetrain and P2V theory question
- popular parts
- ANOTHER ticking noise???!?!?!
- MOVED: 5.0 Supercharger and Power Problems
- 331 stoker
- MegaBites or MM lowers- what would you choose?
- doors and hatchback?
- TPS adjustment--reset the computer?
- Idle screw does nothing.
- First Mustang
- smog pump eliminator
- Crankshaft swap
- manifolds
- new gt!
- Short throw shifter....cant decide
- Passed Emissions, Booyah!
- 5.0 Focus
- sob just snapped the timeing chain
- have a couple questions
- anyone try Ford's "dual mode" mufflers?
- 8.8 question? differential
- Long tube headers on different heads
- worth it
- Help with my stang Urgent!
- new 5.0 what should i do ?
- mass air?
- I can't get a straight answer does anyone know?
- Sputtering at idle - Engine dies out (while hot)
- What Control Arms
- cold air intake
- New Stuff on the Car!!!
- Steering box splines ?
- MOVED: just got back from the track
- MOVED: raced a 91 GT vert and won
- No heat coming out
- Just bought a 88 mustang
- x pipe or h
- wiring?
- Rebuild cost?
- fresh t-5 going bad all ready need some help
- FUEL LINE GUESTION
- timing marks not visible
- Spark Plug Replacement
- MOVED: 351 for my fox
- lower control arm question
- rear end differential, 8.8 question? help!!!
- drain plug question
- What gap size should i set it at
- Looking 4 a Mustang?
- check engne light
- What does "stroker" mean?
- Need some Opinions! First mod to my 5.0
- geting ready for new wheels!
- redlining the engine?
- questions about bolt ons...
- MOVED: how much power can a 351w block take
- One DUMBASS mechanic!
- Injector HELP!!!!
- first set of mods done
- FAST system
- windshield washer pump not pumping...
- GT40E intake q's???
- eibach drag springs
- intake manifold suggestions
- Next Mods after engine swap Any thoughts?
- Took my 86 to track for the first time
- 24 lb. Injectors?
- How about your car?
- convertable guys
- quick spark plug question
- car fax for me
- Which brand of gears would you pick from these?
- Timing advancement?? Topic picks back up on page 4
- Sticky suggestion!
- how to use firewall clutch adjuster
- Ignition UPDATE done
- terminator 5.0
- this is pretty funny
- why in the heck did this happen!
- POWERTRAX NO-SLIP????
- I have a VIN question
- Mechanic?, Houston Tx.
- New noise!
- MOVED: Supercharger questions
- 50 dollar alum driveshaft!!!!!!!!!!!!!!
- 8" Crank pulley belt size?
- wtf my head lights stoped working
- 95 GT is too slow!!!
- Temperature Sending Unit
- 85 Gt with headers
- 85 stock gears???
- Stock cobra header question
- Fox Mustang Wheel question
- I'M SOOOO HAPPY
- summit
- Some Stangs don't use a drop?
- Which Head's?
- looking for some more oomph
- MSD BOX
- 87 302 hydraulic to solid swap question
- smog pump elim
- Short Belt
- rear sway bar
- gt40 vs gt40p
- clutch adjustment, help!
- 1.6 or 1.7's
- how hard is it
- I have no F-en clue now... Help!
- new 1.6 ratio rocker arms
- calculator for injector size
- Buying the AFR 165's 3 quick questions
- MOVED: 5.0 to a 5.8?
- Mustang 5 lug conversion Master Cylinder Question.
- MOVED: Whats up with these neons?
- good news sorta
- 400+hp street machine
- control arms
- E ford racing cam
- Adj Fuel PRessure Reggy
- noise from inside intake?
- steeringwheel is off
- Exhaust help
- broken gears?
- a/c removal help
- Need Help!!
- Motor swap upgrades?
- new spec clutch just in.
- Tick tick tick tick!!!!!!!!!!!!!!!!!!!!! Clutch ticking.
- check engine light after A/C delete
- Launch on DR's?
- 5.0 cobra intake
- Where has he been!?
- I know im asking a lot but....
- uploading pics help
- Loud Squeal/Whine (video)
- getting another 5.0
- Question
- Supercharger or heads
- Anyone running AFR 185 on stock motor
- My starter problem
- 1987 302 block question.
- Fox's only! 18x9 Front & Rear 255/40-18's
- air leaks
- Good Launch?
- Cut off switch
- AC
- No oil presser when at a low idle
- all this 351 talk...is it worth it?
- cam shaft end play?
- 351 windsor swap
- need help with a A9L computer swap
- 4.10 to 3.73 gears?
- finally got pics of my ride!
- RINGS
- finally got my camara today!
- speedometer recalibration gear
- forum rules and information for new members
- low vacuum
- various tech links
- DO NOT PAY ATTENTION TO LOCKED THREADS
- do it yourself head porting
- HOW LONG
- axle ratio id
- Mustang 5.0 powered Volvo...
- lm-1 users....cheap wide band gauge
- emissions?
- exhaust fume question
- Ignition
- Trannsmission?
- how long is to long
- outside trimmings
- my rearend is setting funny..
- Nitrous questions..
- timing
- should I jump on this deal?
- UH OH!!!!!!!!!
- Timing?
- anyone here broken any motor mounts lately?
- Convertible top problem
- UNDERDRIVE PULLEYS INSTALLED NOW CHARGING PROBLEM
- trick flow cam
- crane or msd dist & ignition
- Edelbrock RPM II or GT40 intake
