- car skipping
- fluid change?
- Flashing airbag light?
- panhard bar
- Locked Timing Q's ?
- Stiff clutch pedal anyways to.......
- Spark Plugs and GT40 Heads...PLEASE Help
- Welding the diff
- 4-barrel not opening
- When Installing Underdrive Pulleys..
- Problem/question
- C-4 swap
- fuel injector question
- tach wiringggg
- gt 40 upper
- BUDGET BUILD REVISITED!!!!!!!
- HELP! MSD AND WIRES!
- looking to build stroker w/ stock block
- building a race car need some q's answered
- 5 Lug conversion question
- what are these codes?
- exhaust from a lx going on a gt???
- what to do
- A T/F or S/C battle
- Best bang for the buck
- BUMPING UP TIMING
- wining noise from the rear????
- 1995 gt steering question
- hp estimate mod adivce
- sqeaking noise from left front wheel, help please, not good with suspension.
- worth it?
- Taming the 5.0's rear end for handling applications
- Nitrous Boys lend me your ear!!!
- fox body and 17*9s on the front question
- 650 holley DP with slight hesitation
- Need Help
- smog pump bypass
- broken crankshaft... possible 331?
- fox body auto-x suspension setup question
- Rebuild question
- Extreme Bucking
- Need Input. How Much?
- Hi Torque starter wiring
- whole in gas tank...
- Troubleshooting help- power top on '91 convertible
- need your help
- I need HELP w/ trick flow top end kit
- tps adjustment
- auto vs manual
- 90 Mustang GT voltage/wiring troubles?
- bolt in my lower intake
- fuel pressure drop after shutting off engine
- TURBO QQQ
- gt40 heads on stock 86 block, any clearance issue???
- What gas should i get for my 85GT
- FUEL PRESSURE?
- camshaft
- t-5 problems question
- Solenoid hookup, starter, what could it be?
- Looking for pictures of fuel pump installs
- Clear headlight question
- sway bar upgrade: SN95?
- ATTENTION!!!!!!!!!!!!! BUDGET BUILD!!!
- Rust hole in my frame????
- more power with less money
- Pulled codes......did anyone get these
- Air
- Autox but what seats?
- Starter won't always completely dis-engage.
- Off Road x or h pipe?
- Lazy till 3500?
- Engine Swap Help
- Decent Suspension Kits For 90' 5.0 - looking for input and advice -
- Power steering pump fittings?
- seat brackets
- what cam for stock motor/springs
- Can't solve problem with my 94 5.0!! plz help
- 100 shot on my motor...good or bad?
- HP & 1/4 estimate please
- New Mods...
- parts swap
- Blower Motor for A/C Heat help
- GT Suspension 95 vs 98
- Gas fill up problem
- Need help ASAP
- HELP! 94gt 5.0 start making random loud rubbing!
- Gt40p + nitrous, which spark plugs?
- Charging SYS Issue
- Trick Flow intake Help
- tko-500
- DIY maf cleaning tips
- Clutch Drivetrain Problem
- 94 gt MAF
- H.I.D's
- Gear problems
- Gear Replacements
- 1987 Needs some TLC. Need your help
- supercharger question
- exhaust & intake
- BEST MODS FOR GREATEST HP
- weird ignition
- ac issues
- Can I replace my power steeing with manual?
- Opinions on Professional products intake???
- Fuel Tank ???
- quick radiator question
- Pulling codes and Timing Q
- e-303 1/4 Times
- how to set fuel pressure, and help me pick a kit
- can someone please explain
- CEL question
- Best Setup for 1990 Ford Mustang ?
- quick qusetion
- Temp gauge and tachometer not working . NEED HELP PLEASE!!!
- how fast should i run in the quarter mile?
- New to the 5.0 world... starting questions?
- tweecer help
- spark plugs and wires?
- Wont start, clicking but not the starter?
- rev limiter
- electrical problem
- starter question on 90 5.0
- lower intake
- HELP calling all techs
- 225 or 205/50/16 on a 16 x 9 rim?
- Air Failter
- Tuning my 94 gt
- 1990 Mustang LX Third Brake Light
- Low beams work but high beams don't!!! HELP!!!
- Will this work?
- Check Engine Light code 66 help!!!?
- Couple Quick ?'s
- My Performance choice
- *Emergency!*Problem with the starter?
- ** Help ** Car won't stay running!
- 1995 mustang grease points
- Exhaust CatBack flange Bolts
- Quick Tire/Rim Question
- 85gt vert gas gauge doesnt work at all, suggestions?
- engine bore
- is there a particular year that is best to go with?
- hesitation under load
- patriot vs edelbroc heads
- bulb problems
- pony mud flaps
- mass airflow
- 351w head swap ?'s
- valve springs
- Flowmaster Muffler Question
- Delta Current Fan Control
- T-44 Turbo
- Popping noises through intake.
- Lowering Springs
- starter relay
- cheap skinnies?
- charcoal canister
- t-5/aod swap
- Inconsistent Idle
- need help replacing pistons?!?
- Seat Belt Not Locking?
- So my car caught on fire today...
- 82 with 87-89 wiring fuel gauge problems
- where can i find these two wires
- CODE 22 AND 85
- exhaust system for LX complete
- suspension 2
- What all needed to convert 93 gt to carb setup
- intake install trouble
- tire size
- tailshaft for a 94
- cam and combo for aod stang
- Decision making time
- adjusting vert windows/weatherstrip?
- Pulled Codes...
- What will my RPM's be at with 3:55 & with 3:73
- Removing the brake booster line.. how?
- Goin Drifing... Tires?
- 1995 brake question
- speedo? tko600 to c4
- GT40 heads Valve, Springs and Cam help
- sct chip for 89 5.0
- one More quick question
- need upgraded springs for windsor heads???
- Power Steering Pump Not Working
- Engine ping (pre-detonation)... what should i do?
- tranny sawap
- Eliminator chip!!!
- best heads?
- 94 cobra injectors
- Clutch Cable Help.... and some other lil stuff......
- T-5
- more things with my car...
- Foxbody
- how to crank over engine manually
- high compession with cast heads?!?
- Cleaning Fuel Tank
- motor mounts
- Cobra Lower/upper intake upgrade
- ATTENTION!!!!! Tranny Questions. HELP PLEASE!!!!!!!!
- Ring and Pinion Question
- Way too rich.
- picked up a 95 cobra.
- Can I use stock pushrods with this setup?
- Hot Air Only
- Heads
- White Smoke
- Looking for a reputable shop in Los Angeles
- stereo buzzing sound?
- Firing Order
- how much??
- SCT 4 bank computer chip?????
- negative batt wire question
- cutting out
- belt tenioser interchanging?
- vortech oil drain
- Carter Fuel Pump
- need new pistons?
- Miss or somthing at High RPMS
- MPH and PRM with Rear End Gears
- mustang idles at about 2000rpm
- anybody know?
- underdrives?
- 4.10s?
- gas gauge
- Rear Sway Bar
- Removing Gas tank
- Fuel Injector Operating Voltage/Current
- got codes pulled...
- Vacuum modualtor Valve
- 24# or 30#?? 65mm or 70mm TB???
- Need info on crank specs
- SN speedo with c-4 tranny
- time for new shocks/struts
- cobra intake
- sounds like a gun shot
- what is the thread on bellhousing bolts?
- Temp gauge not working? Tachometer Problems?
- Stock PV valve
- help with windsor jr heads?
- intake question
- 347 loudmouth 2
- wire tuck
- Ford AOD Question. Please help.
- 88' Mustang GT Manual Trans
- 89 GT Timing problems
- 1995 Ford Mustang GT 5.0L V8
- ATT: All 6 sec 1/8th mile fox bodies
