PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 [282] 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. oringed?
  2. Do i need a FPR?
  3. help with cam install!!
  4. balancing stroker kit...
  5. What Music You Listen to when working on your 5.0?
  6. best tranny for me
  7. where can I get a index plate
  8. 75/MM T/B ?
  9. about iac
  10. Whats the difference????
  11. Need new rims
  12. lifters and new cam
  13. Spintech Mufflers
  14. 306??
  15. What year of mustang?
  16. what's better
  17. Which Injectors
  18. the right supercharger?
  19. short block
  20. Less than $3600
  21. black smoke?
  22. wtb forged pistons from a fox
  23. Rear Main Seal
  24. Battery Cables Replacement
  25. Good head and intake combo
  26. cold air intake
  27. Thinking of 351 Swap
  28. heads installed-car hesitates sometimes
  29. Trans removal question
  30. 65mm tb off exploder
  31. Sub Frame Connectors - weld in
  32. L4 to V8 conversion
  33. 5.0. making ugly noise?
  34. Rear Suspension Question
  35. Leaking from the roof
  36. clutch pedal travel?
  37. Hatchback vs Notchback ?
  38. help please
  39. new guy first stang
  40. Help!!...TICK,TICK,TICK
  41. 93 Mustang
  42. What does this car look like ?
  43. Cam lift+ 1.7 RR
  44. Which 5.0 do you like better?
  45. front end on 85gt
  46. Power Steering Pump Question
  47. SWAP 4.6 to 5.0
  48. I need your help!!!
  49. Shift Kit
  50. any one have a kenne bell BLOWZILLA need help ???
  51. 5.0 mustang NO POWER post 2 checked timing!
  52. Need Replacement Door Panels
  53. 5.0 weight
  54. H.O. vs non-H.O.
  55. Vfast help w/ Lower Intake
  56. IDLING ISSUEs
  57. First time to the Drag Strip.
  58. MAC AIT and MAC TB (FPR NEEDED?)
  59. Front struts
  60. trick flow cam
  61. i have heard is it true....
  62. Have you ever heard of these gears??
  63. rear coil overs
  64. Magnaflow cat-back for the foxes???
  65. Worth it or not?
  66. Suggestions on engine rebuild.
  67. Putting in tranny off a 85 Stang I think...
  68. 347-vs-331
  69. Transmission Dilemma T-56, Cobra R, T-5
  70. RPM
  71. gorilla chipz
  72. good motor build......
  73. Ever so pissed
  74. air fuel ratio gauge
  75. Gets gas and spark but wont fire???
  76. Alternator upgrade.
  77. Elec. Tuning
  78. which stroker kit
  79. TREEmendis mistake (rip 5.0)
  80. Posi????? in 93 Mustang??/
  81. Death Of a Stang (thank god were ok)
  82. Need help with boost pipe
  83. need help building windsor
  84. MAF and injector interchangability
  85. HELP HELP HELP
  86. Rear sags
  87. Modding my first car
  88. whats a 5speed worth
  89. about to get h pipe any percautions?
  90. Got my car running again
  91. Budget Question
  92. Installing headers
  93. Water pump
  94. cost for tranny swap?
  95. Noobie > What exactly is a 306?
  96. Underdrive Pulleys
  97. Exhaust...What mufflers to go with?
  98. push rods
  99. 5.0 and oil..
  100. ?? HELP SLIP YOKE!
  101. Rear Sags
  102. tranny
  103. Suspension, intake manifold, and cam
  104. What color paint
  105. pics of my 87 gt w/ttops
  106. Raw gas small
  107. help with air fuel ratio gauge
  108. 18"
  109. A/T Radiator for a 5-Speed
  110. heads?
  111. side skirts/weatherstripping
  112. ford performance
  113. Looking for Police Mustang?
  114. is 30lb injectors too much
  115. finally installing my clutch kit...
  116. mustang sale
  117. c-clip elimatetors
  118. Bought eBay mustang NO POWER help!!!
  119. Pypes x-pipe with cats
  120. curb weight on a 87.....
  121. left front side sagging??
  122. lx and gt differences
  123. My Exaust Pt 2 ( this vid actually works )
  124. Here is my Exaust
  125. Crate engine question
  126. GT to LX
  127. Question
  128. How much is my hood worth?
  129. Help Bent Axle
  130. Next is Cams..
  131. O/r H pipe installed, idle probs.
  132. Shorty X or H?
  133. best catback with x pipe
  134. 347 rear main seal leak
  135. strange 10 way adjustable shocks
  136. dash swap and triple pillar pods
  137. what kinda insurance do you have?
  138. U/D Pulley
  139. suggestions on moving new mustang
  140. HELP WITH MAJOR PROBLEM
  141. HELP WITH MAJOR PROBLEM
  142. Will this work???
  143. Still Looking for Cam Advice
  144. How would i reprogram my EEC IV
  145. estimated horsepower ?
  146. whats going on?
  147. LT headers good deal or no..
  148. police package??
  149. Shop charges..
  150. Crossmember
  151. The T-56 Trans.
  152. Little steel filter in lower intake....
  153. Need Help Putting Distributor back in
  154. Anybody have a noisy fuel pump??
  155. car won't start
  156. Overbore and Piston Size?
  157. reliabilty of stroker motors
  158. spent $2200 in parts!!!
  159. Springs, what do you think
  160. Cobra Suspension dilema...Ill ask here too..
  161. Struts
  162. to sell or not to sell?
  163. Finally gears are in
  164. oil pressure problems..
  165. Set top dead center
  166. FRPP C springs
  167. normal temp?
  168. HOW much should this add (Power Pack)
  169. black interior conversion.
  170. Relocating E-Brake
  171. STEEDA AERO SPOILER?
  172. Compression numbers
  173. wire positions..
  174. Exterior Styling
  175. 1986 GT Vert saved from rotting
  176. unplugged iac help!
  177. Exhaust Wrap
  178. No current in 2 plugs or distribution box
  179. need to sell exhuast to get long tubes
  180. clear headlight covers for 85/86 car??
  181. good tire?
  182. fan clutch quesions
  183. long tubes or short tubes??
  184. Short shifter for 82 4 spd manual ??
  185. timing chain.....
  186. best upgrades for the money
  187. throttle body size
  188. What size gas tank do I have???
  189. 86 gt roller lifters or just hydraulic lifters
  190. Head install question
  191. twinturbo 5.0
  192. god damm idle!
  193. 5.0 v.s. 4.6
  194. Esscence de`antifreeze
  195. Fuel Pump stuck on -->
  196. egr delete
  197. seat choice
  198. Piston choices
  199. 30lb injectors
  200. installed msd/factory tach not working/ anyone running this setup
  201. Aluminum heads or port gt 40's
  202. NEED ANSWER?? 93 Gt Vs. SRT-4
  203. Which alternator??
  204. does any one know for sure....
  205. CAI or MAF Kit?
  206. Rim and Tire Question
  207. Motor Oil
  208. paxton supercharger
  209. bigger valves with stock heads
  210. how many miles..
  211. what brand rubber are you putting on your skinnies?
  212. Auto Tranny Decision
  213. heater core
  214. can i.....
  215. the right UD pullys?
  216. some stang whoring
  217. False Advertising???
  218. tps voltage?
  219. roller rockers question
  220. 93 wiring harness
  221. T5 gear ratio
  222. Which head gasket?
  223. cam to give away+ a set of stock heads to
  224. 91 hatchback wing
  225. Clutch kit for my application?
  226. will this work together?
  227. Check Engine Light and Blinking Air Bag?
  228. Theft light wont turn off!! AHH
  229. Just curious
  230. BBK intake selection option....
  231. Stang wont start hot
  232. If you ever have wondered about Flow American Thunders...
  233. head gasket
  234. need some help
  235. Pix of new purchase...
  236. Have to sell my 5.0...
  237. 1995 thunderbird
  238. Flywheel imbalance
  239. which is better?
  240. quick question about wiring harness
  241. Electric fan
  242. lookin for quick!!!
  243. CHECK THIS OUT!!!
  244. .514/.544 224/230@112 WILL THIS WORK?
  245. electric fans
  246. YearOne Car Show Pics
  247. idle problem?
  248. Pro 5.0 or Steeda Tri-Ax
  249. 4 to 5 lug
  250. what should i do?
