- 5.0 timing problem...help
- 500 hp?
- lifter noise
- 94-95 5.0 or 96+ 4.6?
- Tranny Questions
- New here...possibly seeking turbo build
- rack and pinion ???
- Open wires under dash
- This sux!!!!!!
- Head Gasket
- Oil being pulled through PCV
- car wont start
- s-trim setup???
- Brake help
- 86 gt stock oil pressure gauge
- Tubular gt-40
- overheating... help
- Suspension
- Clutch?
- 302 vs 306 HP performance wise
- Having prob with my car. First time to drive after HCI
- sound buff
- Bigger Injectors on Speed Density
- engine bay welding
- Header Bolts
- Shifter bracket
- Bent Axle
- oil pressure gauge
- Bad rear end??
- new 306 wont start..
- strange problem update...
- 1.6 RATIO ROCKERS
- wanna upgrade to f303..got a ? about ptv
- need help setting STOCK valves (not roller rockers)
- Clutch/shifting
- overheated
- will my 1991 4cyl springs hold my 351?
- Temp Guage issue, and Overheating issue
- Holley carburetor issue
- hey
- Newbie Here.......5.0 Fox Questions!!
- lifters
- i dont know
- Need Help
- Mustang Fan
- 28oz or 50oz?
- How much hp?
- electical issue
- Spark Plug Color
- Strange problem..
- Poor idle, no power
- emissions
- Clutch adjustment?
- Identify this Paxton
- Problem with Bassani X pipe!! HELP!
- Computer question
- Will this head gasket lower my compression ratio?
- 1992 Mustang Gt 5.0 HO Tranny Issues
- Hydraulic clutch
- 460 swap
- PLS HLP: Overheating on Freeway
- OK...
- stick to auto ?
- bought a motor that has a knock..need help?
- RAM vs King Cobra
- To mod, or not to mod. That is the question!
- need help ASAP top end re-build. troubles starting.
- Will These Fit?
- anybody got experience with tweecer
- Need help! 347 Stroker Emissions
- What is this shock behind my rear tire?
- Clutch cable?
- kickdown cable?
- 94 mustang MAF
- Fox Short Tubes on a 94?
- Sunroof owners
- witch supercharger to use on 86 gt sd
- CC plates
- noob to 5.0's
- Need suggestions for temp gauge problem
- 88 running rich
- 1994 mustang gt intake
- weird noises
- What Year 302 Do I Have?
- TACHOMETER!
- Bird living under my hood.
- brake lines needed
- the mystery problem
- Headlight harness wiring question
- Motorcraft???
- Problems with my 5.0
- Bell housing t5 sr4
- 12.61 @ 108 - need more power!!!
- Might be getting a 5.0
- tubular k member ?'s
- t-5z
- Gt40iron's vs Patroit aluninum heads???
- battery cut off switch
- Car bucking/breaking up and revving itself
- Downloadable Service manual for 1995
- PA supercomp c4 vs, dynamic mighty mite c4
- 347 COOLING PROBLEMS
- Breathe of fresh air!!!!!
- MAP Sensor
- Heads
- oil in tb??
- What years?
- Car wont idle!
- anyone mount there msd under the seat?
- Belt Size to Bypass Smog Pump??
- 14 sec range
- I got $3,000 to spend..
- just got 90 lx hatch. it's white, i'm looking to get rid of the black trim..
- general question
- need cam help!!
- A9l spark advance
- HOW MUCH CFM DO YOU NEED ELECTRIC FAN?
- Crane Compucam Kit 444222
- New Engine Input
- HELP!! 92 notch aod to t5 swap.
- running really rich
- EGR Help
- sensor help!
- Vacuum @ idle with trick flow stage 1 cam
- Tires and Gear ratios
- tko600 to c4 swap?
- Cutting out the trunk to get to the fuel pump
- 1987 Ford Mustang('92 Cobra Kit and '92 302 H.O)
- Big guy in a little Mustang
- HELP! PCV VALVE
- What Brand roller rocker is this?
- What Plugs do 5.0s like
- crazy problems, need help
- Quick Question about Upgrades
- 95 mustang W/carburated 302 swap
- 1992 5.0 Hatchback
- Launch master
- 4-5 lug conversion
- 90 mustang sn95 rear brake proplem
- problem starting?
- which one?
- top speed?
- Nitrous and Compression
- Need help with MM control arms !!!!
- have a problem. HELP!!!
- Stock 5.0 needs help
- Need help changing rotors
- h pipe question
- Blower Motor
- Questions?
- 190lbh pump VS 255lbh
- need help fast with fuel gauge
- anyone have a pic of what wires go where on the noid?
- Unusual hole
- differential
- Timing question...
- Alternator fuse keeps blowing
- Engine Identification
- Starter problems
- identify my upper intake?
- tire problems
- auto to t5 in notch x[ help
- Fuel issue?
- Will not stay running after it warms up!!!!
- Stalls out only on cold start?
- tapping noise
- Stock Tach not working
- GIONG CRAZYYY help me select a cam! pls
- Underhood Starter?
- 245/40/17 on 17"x9" rim
- In the market for heads but which ones?
- 86 AND A 429
- Porting Eddy Performer Intake
- Auto To 5 Speed
- putting 5.0 into hotrod questions..
- Rust on shocktower
- Roll Cages?
- Headlight help!
- New Forum Member
- Flood Or Not?
- RESTORE???
- Tranny fluid and Gear lube?
- Backfiring problem
- ford 8.8 rear end issue
- wheel hops like a MOFO after lower control arm install
- Rpms?
- surging at steady throttle
- Newbie please help
- Fuel Pump Recommendations
- Cylinder wall damage
- CAI filter size & relevance
- what do i need for sn95 convertion
- 4.10 gear/speedo question
- is there a way to fix this
- MAF bracket
- Moment of Truth (first fire)
- Location of under hood fuses
- A9L work with an auto???
- Holley Red Pumps
- Maf conversion help
- Manual steering swap trouble HELP - (tie rods too short)
- heads for my set up?
- HELP quick alternator question
- 1986 5.0 Auto mustang upgrades??
- Stock timing for a 90 GT
- ANYONE IN OR CLOSE TO THE MILWAUKEE AREA
- 302 with 351 heads
- Throttle/RPM Issues
- Timing maybe?
- Blinker Fuse
- rattling pingy sound
- Ford racing 351 1.6 Roller Rocker + GT40p heads
- trick flow typhoon or Edelbrock intake
- does this even matter? crush sleeve question
- EGR & Idle Air Control
- 351W Head choice
- not running good
- window problem
- BBK headers and BBK under drive pully
- need help quick tranny lines which one
- Blow-thru carb design on 89 GT
- Holley Blue Pump
- Advancing the timing
- F cam questions
- valve guide inserts
- PCV problem
- AEROMOTIVE 1000
- Help with Hooking!!!
- K&N part number
- emission equip. on 94
- Engine Oil
- Hard to Start and Buring Way too Rich
- Adjusting Stock rockers for aftermarket cam.
- PCM differences?
- What can cause the shifter to vibrate?
- vortech msd ignition/boost control
- 1994 gt front spindle question
- just got an 87!!
- Does a cold air intake REQUIRE a tune?
- Eibach drag springs
- Determine if its a cobra??
- 5.0 turbo
- Picked up a stumble
- sensor/ground voltages reversed?
- running rich please help
- seat bolts and nuts
- HELP!!
- NO POWER AT TOPEND
- HELP, I'M AN IDIOT.
- Hanging idle?
