- Motor mounts?
- adjusting clutch
- 98 Explorer U/L intake manifold to 94 GT
- installing a clutch
- What is needed for 140 mph speedo swap?
- driveshaft problems- leaking tranny fluid
- Do you think my fuel pressure gauge is shot?
- Capri 5.0 Vs. GT 5.0
- This article pisses me off...
- Is a '92 5.0 reliable???
- rocker adjustment
- my car
- Cervini hoods
- Solid drag style wheels for 90 mustang?
- GOT A GOOD ONE!!!
- Rear End Shop
- Compression too high?
- EFI or carb for a 351w?
- Shifting points
- Torque Converter Question
- Help with AOD build PLEASE!
- Anybody running a gear drive on your 5.0?
- broken motor mount??
- Dyno Torque Question
- Big Problem, need help fast!
- Making plug wires...
- change stock fuel pump???
- how to install new lifters the right way
- Difference between Long headers, and shorties
- FINALLY FOUND OUT WHY CAR IS RUNNING BAD!
- difference between cobra front bumper/GT
- Possible Transmission Problems
- coolant
- Please help...First year for Mass Air
- cooling issue
- Weird 95 5.0 problem ...Please take a look!
- 24lbs. injector problem!!!!!
- where can i find 5.0 stamped rubber pedal covers?
- new rearend
- throttle air bypass valve?
- Delete airbag?
- Vin Number
- 5.0 virginia peeps..look
- how so you make it stop running so rich
- overheating
- adjustable shocks
- fuel pump ???
- Putting gears in this weekend need a lil help
- run stock h-pipe with 1 cat?????
- Cap and Rotor
- Rate My Project Engine For My 88 5.0
- Crate or Rebuild ?
- Sea Foam Users
- best headers for old 5.0
- 79-93 mustang lx 5.0... problem
- Headers Changing Colors
- advice
- just got pulleys ...battery light now on
- 87-93 Mustang hood hardware question
- afr heads- 165 or 185 which one with stock bottom end? valves clear pistons?
- alternator question
- control arms came yesterday
- Starter problems...
- 2 82 mustang gt's T-Top CHeap!
- gauges?
- Fault Dipsticks
- Hiding the wiring in engine compartment
- 3:08 to 3:73 concern
- this is just wierd
- typhoon intakes?
- 95 stalling?
- Need physical help if possible for mass air conv.
- eliminating the EGR
- Intake question
- Some new parts,need alittle info
- where to buy parts
- how much of a project is it to restore a stang? can't decide (long)
- new intake now my car wont run right
- valve cover help
- 331 stroker broken in
- 5.0 in sn95 v6
- 95 GT drop top...how much does it weigh
- Passenger Door Power
- 89 lx rear seats
- Blower or All Motor????
- shock tower brace
- New intake manifold
- Begining stages of my new project....
- trying to get my car to hook begains...
- transmission problem
- thinking about doing intaking ports for who is interested
- 9 inch rear end question
- aod help!!!!!!!!!!!!!
- HEAD ASSEMBLY
- Burning Smell
- hood clearance??
- CAM question
- swapping rear..7.5->8.8
- EGR
- Disappointing price tag with TFS Wedge Heads...
- new clutch
- AOD to T5 ??
- 88 gt whats it worth?
- transmission problems
- NEW (old) CAR
- Contemplating 331 stroker
- limited edition lx converible
- I powerwashed my motor.....help
- anti lock brakes?
- my car won't start??? Please Help me...
- 73mm or 76mm maf??
- Rocker arms
- 4.10 gears
- Wheels and Tires
- stock2 AN fuel lines?
- Cheap Motor
- power steering
- H pipe question
- new computer for 95Gt
- Track Gears
- transmission
- 5.0 Engine Life
- 306 engine block? 750 bucks...is it worth it?
- best plugs
- help on buying a 5.0
- Help with new heads and some terms
- battery relocation made easy....
- PA Valve Body or Stock with Shift Kit
- cracked fire wall
- Help with worn door molding
- Help - AC "cleanout" gummed up?
- wheel changes?
- rpms bounce at 4500
- What should i set my fuel pressure at????
- cobra maf
- sagging problem
- Help Please!!!!!!!
- a/c lines
- Electric mirror problem?
- Better ground wire?
- chemically cooled
- My car is loosing weight
- My hood is finally painted!!
- Question about c&l performance mass air meter
- trouble with mac shorties
- 89 mustang w/92 Gt engine wont start
- AC Problem
- 95 engine w/93 intake
- AMP light
- Which Clutch?
- Changing gears and what else?
- Adding performance to my car
- very happy with shift kit!
- every one reply please need advise want 12,s partslist with pics.
- what should i excpect out of this
- press brakes or clutch and car goes dead
- plug gap for 88 5.0
- Took my car to Byron dragway...
- transmission temp gauges
- Which Fuel Pump
- Radiator Bracket
- The Teardown Started Tonight...
- My 87 5.0 vs 00 GTP?
- Mass air conversion help
- What do you think of this setup???
- need help dtermining which year my motor is.
- Vacuum Nightmare
- STOCK GT40P'S
- mods question for my stang
- Blue Smoke
- System 1 re-usable oil filter?
- Cranks, but won't start . . . Help.
- priming the motor
- cam for supercharger
- quarter window?
- Oil Burning Smell?
- Mod ideas
- Upper and lower intake question/problem
- high flow cats...
- Motorsports b springs?
- lower intake question
- Few Q's
- Which Exhaust?
- TB and MAF
- Dissapointing 0- 60 time
- Ram air question
- 77mm MAF to big?
- e-fan noob
- Rear hood pins on a 89 gt??
- CAr running very rich all the time
- Hooker Headers
- Eibach sportline springs
- Base Timing vs Advance Timing ????
- converter?
- Valve covers
- Valve Covers...Trying to decide
- Adjustable or Nonadjustable Shocks
- Any of you guys interested?
- QUESTION BOUT INTAKE
- 331 Stroker Block Comparison
- Help with my first mod
- Auto Transmission Question
- Car Pops, HELP!!!
- AOD to t5 transmission swap
- High transmission fluid...
- Ways to lose weight...
- torque converter?
- injectors with maf price?
- Building a 347 for offroad applications
- computer upgrade
- 1.7 Roller Rockers
- Automatic to Manual
- Electric water pump and P/S delete questions
- What's a good performance chip
- Still vibrating, frustrated
- A/C Fan Slows down as RPMs increase
- Overheat,no water loss.
- ticking noise from under the car!!!
- aod or aode help
- head casting #'s
- Can't go into 2nd Gear
- how much
- 89 need a pcv baffle
- 94 shifter questions
- Anniversary Mustang
- Headers + H pipe
- help me out
- pistons vrs heads
- AOD to Manual
- Motor Upgrade?
- car is acting stupid
- ignition question
- Shift kit Question
- Driveline issues(frt u-joint)
- The Most hp while staying emsissions legal...
- Need help with brake light switch!!!!!
- why AFR'S?
- Tips on starter mods
- Air Bag Warning Light
- gas gauge problems
- Needs to be fixed
- 95 rearend in an 89?
- Timing to 14 degrees?
- 5th set of header gaskets goin on tonight
- edelbrock intake
- I NEED MY FELLOW 5.0'S BUDS HELP
- 93 Coba parts
- removing intake silencer?
- Trick Flow twisted wedge tech ?
