PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 [297] 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. difference in 5.o h.o. efi
  2. running without TPS plugged in?
  3. fuel pump relay??? i dont have one
  4. starter solenoid problems
  5. 347 ??
  6. Bearing size?
  7. my goal
  8. Rims and tires
  9. Help on Building N/A for Street/Strip
  10. mustang emblem
  11. Timing sweet spot??
  12. Quadshocks...removing them??
  13. Smaller Pulleys on the Engine?
  14. 351W in!!!
  15. I put the fat girl on a diet
  16. Wheel sizes
  17. body names????
  18. reset the computer...
  19. Low RPM Vibration/clunk on 87 GT MTX
  20. cam install
  21. quad shocks/jumpy tach
  22. I've got a bent rear axle...Where should I get one?
  23. It's official, I hate them
  24. ANy easy way to install a quadrant
  25. HARD TO START WHEN HOT??
  26. 400 rwhp with a 306?
  27. CAR IS HARD TO START..???
  28. CAMSHAFT FOR GT40P AND GT40 INTAKE
  29. Back from the track....did worse than last time!!
  30. do i need a custom chip?
  31. cars dying.
  32. spedometer cable installment
  33. transmission rebuild kit
  34. OMG, no oil pressure!
  35. 1986 capri/mustang 5.0 catalyst tag
  36. timing
  37. gt-40 head fitment question?
  38. What is my car worth?
  39. which year are gt-40 heads?
  40. FORGED crankshafts for $299????
  41. oil problem
  42. rattling
  43. Burning smell under driver side
  44. 347 stoker help
  45. MAF mod better than CAI
  46. curiosity question for those with msd6al
  47. blowing out mufflers?
  48. Need a Alternator
  49. Aftermarket A9L replacement any good?
  50. ok so i finally got to drive first time in 3 weeks
  51. gear grind
  52. Windsor vs Clevaland?
  53. How much is the Speedo off ?
  54. Another friggin belt question
  55. air silencer
  56. Going Stock
  57. Jack question
  58. am i worth?
  59. check engine light
  60. Engine Painting
  61. Rear Main Seal ??
  62. GOTTA CLEAN MAF help
  63. suspension
  64. Fuel pressure setting
  65. losing power
  66. speedo recal gear install
  67. To spool or not to spool
  68. Power Door Lock Actuator Replacement
  69. to look good or not
  70. make it leaan
  71. my new car...
  72. Harmonic Balancer
  73. Block Worries
  74. Coil Problems
  75. What Radiator?
  76. wheels on a 1991 lx stang
  77. trans rebuild...
  78. smog pump
  79. Floor pan
  80. MY NEW 5.0 VERT LX
  81. what do you think your 5.0 is doing?
  82. Help
  83. timing with no pointer
  84. Best 5.0 engine buldups
  85. Tips for installing outside door handle?
  86. GT spoiler fitment
  87. struts and springs or coilovers?
  88. hatchback
  89. question about heads
  90. Head comparison
  91. Adjustable Shocks
  92. synthetic oil
  93. Did a few things tonight...I LIKE!
  94. bring back the 5.0
  95. Need help installing Adjustable clutch cable and quad...
  96. mech or electrical gauge?
  97. torque converters???
  98. 5.0 pics and list of MODS
  99. 1995 5.0 speed sensor
  100. ANYBODY can answer this
  101. tranny ?
  102. fuel pressure regulator
  103. 1995 Cobra speedometer cable gear
  104. torque converter
  105. yes iam getting a jessel
  106. need help somethin happened
  107. o2 sensor replacement options
  108. Changing oil, what kind should I use?
  109. Hey help me out on picking a CAI.
  110. Rods
  111. what is the greastest lift that i can put on my car?
  112. Royal Purple?
  113. what should i run
  114. what psi for tires? going to track tonight
  115. WENT TO COURT TODAY......I GUESS I NEED A MORE QUITE MUFFLER??
  116. throttlebody?
  117. car moves by itself in 1st gear?
  118. strut tower brace?
  119. rim sizes
  120. Emissions on 5.0?? In GA???
  121. Tranny issue
  122. NEED HELP FINDING THE FUEL PUMP RLAY 87 GT
  123. Helix Power Tower WTF????? Does it work?
  124. need help fuel pmp wont turn on
  125. Red leaking fluid and oil leak?
  126. Speedometer gear
  127. Electrical Problem
  128. Car wont idle right till warms up
  129. car still not starting after new injector seals
  130. Experienced Mustang owner's only, Help needed please...
  131. PRO M & Water Pump Q?
  132. Surging at idle
  133. stock internal on 87-92 5.0?
  134. TIRE SIZE
  135. what guage battery wire
  136. mass airflow how important???
  137. Holley red or blue fuel pump?
  138. E7TE heads
  139. 5 speed to C4 Help?
  140. I was just wondering.
  141. I was just wondering.
  142. Removing upper intake
  143. oil pressure low?
  144. spark pugs
  145. WTF timing is WAY off!
  146. Length of power steering hose
  147. overheat Q's
  148. piston selection
  149. wheel and tire setup
  150. 87-93 5.0s
  151. 1.6 roller rockers or 1.7??
  152. Clearance concerns
  153. Whats the stock exhast on a 95 GT look like?
  154. Stock 5.0 times
  155. shopping spree
  156. Where can i find door molding for fox body
  157. how to clean egr valve on motor
  158. issues.please help
  159. looking for a cam
  160. aode/4r70w
  161. Vehicle speed sensor
  162. best year and worst year.
  163. Edelbrock
  164. AOD to C-4
  165. Rumble in the Jungle
  166. Is a mulit-spark ignition box worth any power?
  167. Newbie 5.0 Owner problem/question????
  168. couple of quick stupid questions
  169. OMG oil smoke everywheres!!!!
  170. is it possible to get 600hp from stroker.
  171. car lowering
  172. Car length of 87-93 5.0 Hatch???
  173. Rear Quarter Window Swap
  174. Help deciding first Mustang?
  175. 94 smog pump elimination
  176. gears went in today...a bit dissapointed
  177. a little help
  178. OH NO!!! METAL SHAVINGS!!!!!
  179. OOOsss NOOsss
  180. where do i hook up my mechanical oil pressure gauge?
  181. got tips????
  182. Automatic trans fluid
  183. High Idle
  184. help with T-5 swap
  185. Shifts
  186. Computer
  187. Question for 86hogt
  188. 95 GT Strut Tower Brace needed?
  189. Electric Fan question
  190. how much to pay for 96 explorer heads 5.0
  191. Stick motor to aod transmission
  192. PAW
  193. M/T vs. BFG
  194. GEAR INFO
  195. How much can my stock clutch hold
  196. Fuse Panel (Need info) '90
  197. which gears ?
  198. 5.0l upgrades
  199. 2.73 to 3.55 Worth it?
  200. REAR END SIZE?
  201. Cam question
  202. what is the difference
  203. flowmaster 40 series vs. new super 40
  204. flowmaster 40 series kit
  205. Hankook tires...
  206. door molding
  207. got money! wooohooo
  208. what is the exact meaning of 3.73, or 3.55, or 4.10?
  209. GT-40P heads
  210. EXHAUST FOR 1994 5.O
  211. Good engine block for 500hp N/A
  212. gauge install
  213. 1994 Mustang GT 5.0 - What To Mod?
  214. NEED HELP QUICK
  215. King Cobra or Ram?
  216. idle problem still
  217. Install adjustable clutch cable?
  218. Forged Crank, Pistons, Rods....
  219. Bad computers in 95 GTs?
  220. Fuel pressure guage fitting!!!!!!!
  221. 94' 5.O: No Brake Lights
  222. 94 Cobra Intake Specs?
  223. Venom Programmer
  224. Frame differences?
  225. Mass Air info
  226. 5.0 lx or 4cyl conversion?
  227. TPS related to gas mileage?
  228. going to have 300$ by this weekend...
  229. Hey Dbeck002
  230. Hawks Racing
  231. Book to help pull the motor?!
  232. Best way to change the PCV valve?
  233. throttle body linkage?
  234. How to identify an HO 302
  235. can you adjust the door glass
  236. Leaking Freeze Plug
  237. CARFAX ON MY 5.0 PLEASE
  238. Car actin Funny...
  239. clutch and flywheel size
  240. I have a bent rear axle...Where should I get one?
  241. what are the best bolt on mods
  242. 302 or 351W
  243. Mass air flow sensor
  244. FICNALLY GOT ALL MY PARTS
  245. 308 anybody ?
  246. well i'm looking into buying a 5.0
  247. good plan?
  248. under driver pullys
  249. Fox Body Seat Belt Question
  250. Widest 17" tire or any tire you have put or seen on the rear of a FOX?
