- x-pipe question
- unique problem?
- sn95 and explorer?
- Should I buy this engine?
- 4 speed swap
- New To The Site, Have A Few Questions and not sure where to post them!
- Need new plugs+wires suggest some!!!!!
- question bout lentech valvebody?
- Crazy miss
- MAF
- Braking motor in, what oil should i use
- bad luck with fuel injectors
- 1989 LX Hatch for sale - MODS please dont move
- How much should i ask for ?
- Lagging when revved ( VID! )
- Need some help w/a vibration
- Good Deal???
- what belt do i need??
- Delta force single chamber
- Help?
- gt40 heads
- 1989 mustang hlp needed
- 5.0 EXPERTS NEEDED
- Powerdyne charger on Superchargersonline.com
- 5.O EXPERIENCE NEEDED
- 90 headlights
- Rear seatbelt recievers.
- How long does the 5.0 really last?
- USED GT40P PREP
- Rear Seat Delete for 86
- Brake Light?
- Denso Iridium Plugs?
- Gears?
- Running Hot
- 4.10 explorer gears?????????
- how to get around smog...
- 4/25 Build week.What's your status
- What should i do?
- Purchasing rear end gears???
- carpet
- undercoat
- rear end gears
- My mustang pictures finally!!!!
- Eliminating the EGR system
- problems with A/C
- explorer gt40 intake????
- so i have an exhaust leak...
- Spark Plugs
- is this a deal or what....
- 4.10s or 3.73s
- Road to 13's
- t56
- 95 cobra seats
- 1995 cobra egr header plug
- where to find?
- black spray
- H-PIPE n Exhaust?
- machine work estimate
- 5.0 tork boxes/plates
- Picked up my mustang....got a few problems need help!!
- EGR Simulator
- 95 mustang egr blockoff
- Can't solve rattle
- Best Throttle Body for NA?
- smog pump bypass
- E-Brake help
- looking for a new motor
- Fuel pump going bad?
- Header wrap/blankets
- 5.0 up and running
- Fuel Pump Question
- Chip Chip and nothing but the Chip
- 289 vs 351 heads
- chirping brakes
- Suspension Question
- Weight Saving's?
- 87-93GT body kit on 86 GT
- Input on possible 331 combo?
- 4TO5 CHANGE
- What are these for?
- AOD shifting 1?DDNRP (B&M? give you 2nd?)
- Intake manifold shoot out....
- Throttle body wearing out...
- How much HP...
- weres the backuplight harness located?
- lookin for hurst shifter
- Header and Piping combo...help
- Changing cylinder heads = changing pushrods?
- reset my TPS tonight...
- 351 swap
- fox 351w swap or 460 need help
- Body kit
- Over heating
- cold idle adjustment
- 1994 fog lights
- Posi rebuild kits?
- Distributor installed right?
- mass air meter?
- Holley Systemax II or Trickflow Twisted Wedge Kit
- Transmission problems
- 93 cobra rear bumper
- Installed exhaust now questions
- need some help
- largest tire with no rub?
- Keith Craft Crate Engines
- Conv Top Parts?
- Easy 300 HP?
- Car won't move
- mac prochamber
- which one
- where are all the Explorer intakes?
- Draining radiator fluid
- HELP: Oil pressure very low
- head casting #s
- Port and Polish Stock Cylinder Heads?
- transmission fluid!
- porting intake manifold?
- Intake manifold Questions
- How man CFM's
- Lx Vs. Gt
- 8.8 questions
- Electric fan wiring
- Could someone please run a Carfax?!?!?
- Edelbrock Perf. vs. typhoon
- Starting problem
- Timing advance problem
- Cleveland heads on 302
- Fuel System Switch
- X2C or DSS 331?
- ABS brakes
- Is this an OK tranny???
- back from the shop
- Fuel Cell
- new carb. or not
- advance timing
- Installed Stuff Today
- MAGNA OR FLOW
- TIRES
- chips which one are they worth it
- Oil breather cap?
- bolt ons and improvement order?
- Phenolic spacers
- 5.0 For sale, need help!
- X Vs. H
- Is this speed density or mass air flow?
- problem with idie
- lifting belt tensioner...
- this may get annoying but....
- Good deal on 5.0?
- TRANNY HELP PLEASE
- hesitation problem.
- Biggest Rear tire on 16x7 pony?
- How to remove throttle body?
- need an electric fan
- 79 hood scoop on a 90? anyone?
- Stalls Out
- Alternator amp up after Underdrive Pulleys
- Installing new MAC Headers!!!!!!!!!
- Where did my posts go???
- I am changing distributor and need some help !!!!
- Got some Seafoam, have some quaetions.
- underdrive pulleys????
- Raising CR?
- Intake question
- Performance AOD
- reverse lights
- cobra intake
- 331 Combo help
- problem
- Throttle Settings
- Update and Question
- oil in intake manifold?
- rear main seal 2 peice or one ??
- fans
- T-5 question
- Junkyard finds...
- electric fan coversion 30 amp?
- Edlebrock Performer Vs. Trick flow street heat
- Car Bucks when cruising
- rough idle backfire when hot and starting
- Dynomax Super Turbo Mufflers
- speed density to maf
- shifter acting up!!
- 93 Cobra
- heads vs. cam, 1.7RR, intake...
- More horses without a/c and smog pump?
- CAI worth it???????
- Who here has
- Belt Help Please
- mil eliminators
- Check this out
- Smog pump removal
- Ram Air Hood & C&L Intake....do they work?
- Crate engine problems!!!
- Will this work on a 1988??
- Ram Clutch vs King Cobra Clutch
- Install Cam, or rebuild Engine first?
- 5.0L or 4.6? or what?
- measured my t/b and mass air, still confused
- Jumpy Tach
- Things to check?
- Aluminum driveshaft
- 9mm wire holders
- Twin Turbos... $250 bucks...
- 95 cobra mechanical water temp gauge
- 1985 v6 mustang
- best cams
- MSD box mounting location
- Free HP??
- Rebuild supercharger $410????????
- My mustang is wierd!
- 302 & C4 Break in.
- 429 in a 95 Gt? possible?
- Spinning in tranny after shutoff
- OPinion on Fuel pressure regulator!
- smog pump removal
- fuel pump continues to run
- wiring harness install
- my pony is sick
- injectors
- 93 Cobra Computer
- How to change front rotors?
- Performance question!!!
- which fuel pump is enough?
- Cam Question
- Loud Fuel Pump
- What do TPS and MAF stand for and where are they located?
- max you can port a stock maf...
- idle jumpy
- 454 in my 95 GT 5-speed ;) check it out
- 5.0 questions injectors and mass air, superchip?
- difference in 5.0l cranks?
- EXHAUST HELP !
- If you can change 4 lug to 5 why not 5 to 4??
- OK WHICH TIRES THEN??
- Cold Air
- New Radiator
- msd wire prob
- over heating problems
- Spark Plug Wires
- black interior
- SHORT SHIFT
- Engine bogs down in first, and dies.. Help
- tourque converter
- Air Bag light blinking
- where is a good place to buy a tranny at?
- Mustang gods help me big problem
- SPEEDOMETER IS LOUD?
- CAR LOPES AT IDLE...ONLY SOMETIMES.
- Your opinion on my next mod?
