- front control arms
- ? about seat track compatibilty
- starting problem
- car just dies
- can a bad egr valve cause car to run lean?
- car feels like its going to die at idle? pulled codes
- c4 ? !!! help
- 1987 LX Fender/Bumper Cover issue
- best spark plugs for gt40 heads?
- bumper lettering inserts??
- two questions after 5 lug conversion
- MSD BTM?..........
- No center point in steering..car wanders
- Turn signals dont blink?
- vibration
- what sn95 3.8 parts will fit fox
- a little worried here my car seems to be whining
- finish upgrade can't get it stater, Koer results Help
- engine casting numbers, help quick plz
- runs fine then won't, stomp gas to start again?
- just installed springs
- Rear end help!!!!!
- A few questions about my new fox- 90 lx hatch
- Stud Mount Rockers without machining
- cobra rear brakes
- Speedo gear questions...
- Speedometer is drifting
- clarification
- little help with codes
- car leaking oil.
- supercharging
- Clutch Cables 0 : Mustang 2
- Tweecer rt or Anderson pms
- Coolant Smell
- Major shake\vibration
- 5.0 problem, need help!
- Still have questions?? Throttle body/Mass Air
- slight ticking and popping noise from intake?
- INTAKE QUESTION
- engine just shuts off
- H/C/I choice
- Breaking Dizzy Rotors?
- 5 lug axle ?
- code 96, but car runs?
- Flowtech headers
- 1995 Mustang GT Shocks
- thermostat for 5.0 swap
- breather box?
- removing driver side long tube header
- SN95 brake booster and master cylinder...rod length
- Help with code 22 Barometric sensor
- 98 cobra drive shaft
- msd?
- Difference Between Gt40 & Gt40p?
- new engine break in procedure?
- KOEO, KOER, Cylinder Balance Test results
- my main bearing is going out
- Wouldn't start, now will....confused
- Exhaust smell?
- Going to attempt a clutch change..
- Quarter windows
- will my grand merc 5.0L EFI fit in an 88 mustang body with out mods>?>?>?
- How do I get my fuel door open!!!??
- it just dont feelr right!
- Really wierd timing
- Wierd idle issues
- Blower Motor Working...No Heat!
- Need Advice
- tranny fluid pouring out.....
- 3.4 inch stroke
- Car vibrations at all speeds, Know i have a bent wheel plus..
- Fuel level gauge..
- fuel pressure?
- what is the problemm????
- Best build for stock block
- Brake upgrade!
- 89 gt
- 5.0l upgrade
- So, what is fried?
- NEW HEADS CAM INTAKE PROBLEMS
- no spacer
- 41/91 and cant find vacum leaks now what
- T5 shift fork replacment ? are they all the same?
- Vortech Supercharger
- 93 lx 4 cylindar to 5.0? need help
- motor breathing
- Where did my coolant go?
- how do i get this on?
- need help with masss air problems!
- Help, me with...
- i have a problem and some??
- FMU MANIFOLDVACUUM/PRESSURE SOURCE
- 1995 Performance Chip
- gas tanks
- FYI codes 41 and 91
- car dies out around 170 180 dagress
- trying to loosen distributor
- Car wont turn off
- T5 to AOD swap ??s
- time for the swap
- Putting in a new clutch
- 3000 rpm Misfire?
- 73mm Caliper upgrade w/Hawk pads question
- Rebuilt t5 jumps out of 2nd gear.....help!!
- Exhaust system
- Fuel pump problems?
- 3g alternator & intake gasket
- ok so is this my alternator
- what kind spark plugs?
- Coil wire
- 94 5.0 engine pinging
- a/c delete kit
- Rear window on vert will not go up.
- My 351 build ideas...
- Battery died while driving, won't fully start with new
- advice on Motor and Trans swap in foxbody?
- I don't know what the problem is now. Help!!!
- What Size Push Rods
- temp questions
- transmission problem
- Alt Pulley
- 5.0L turbo kit
- Problems with 5.0
- 302 Cam selection?
- bellhousing size and thread
- 95 GT running rough
- Timing Chain
- no pressure?
- fuel pressure possibly?
- Overheating problems, help pleaze!!
- finish my upgrade but doesn't start need input!
- Reverse is gone?
- is it the alternator
- help wont start
- long tubes+coilovers..too low?
- Floor pan instal
- pulled koeo codes 172 556 need a thought on them
- need help
- what work needs to be done before supercharger install on my 5.0 notchback
- Diagnostic Codes Pulled NEED HELP!
- vacuum gauge install....HELP!!!!
- check engine light question
- Non-mass air intake options
- Header Bolts - Power Loss?
- before I start her up after the mod in 1/2 hour
- 3 quarts in T5???
- subframe connectors in a 87 convertible
- Hood problems
- 302 rebuild
- HELP...filled up AOD and is leaking...
- Yet another issue
- Heater Core
- Man o war block??
- air?
- Is my alternator dying?
- Breather?
- Are Idling and Cooling connected?
- ok so can u slove this?
- Blocks, machining, cams
- tps question?
- Exhaust resonance
- replaced endlinks, and still have squeaking
- buzzing noise
- Weird noise when put into park AOD.
- grey smoke!!!!!
- Heater will not blow hot air.
- Good Fuses, NO dash lights
- battery help!!!!
- Won't stay running
- 89 vert L/R window help.
- will not hold idle, runs too lean
- gear oil
- a little smoke???
- Wich position K.Y.B shocks
- ticking noise
- PtV clearance
- what size plugs??
- vapor canister removal
- High idle.....need advice
- 1983 Mustang Wiper Problems
- Problems with 5.0
- vacuum lines????
- Supercharging My Mustang Help????
- Installing new Gauge face
- cleaning gt-40/explorer stuff?
- T-Tops on a 92 LX?
- Supercharger type help
- Vortech Crank Pulley Question
- difference in spindles
- Front spring install.
- will it fit?
- how to run the belt
- Steering Help
- Need help with heads and cam.
- air pump hose is split. quick fix?
- what is a good aftermarket fan to use for the 94-95 GT?
- Elecetrical Problems 89 Mustang Lx
- flog lights
- 91 Tensioner Bolt
- checked for power and switch still doesnt work
- smog pump removal guys
- flexplate for 95 5.0 with c-6 trans
- fender?
- Fuel Cell Gauge?
- Rocker question
- ATF IN T5??
- clutch problems
- Ideas???
- switch on top front of 5 speed tranny
- I am stumped
- will an e cam work with my setup?
- any have this problem before
- Got spark, smell fuel but still won't start.
- alternator problems-- connector broke off
- Summitt Mass Air Problems
- Broke 3 valve springs in 3 months!!??
- Reverse shifting pattern?
- Got problems. Need help!!! May be walking home today!
- MAF question
- A/C PROBLEM
- How do I fix it
- CODE 33
- Help! New Starter Still Sticking
- feul pump kill switch
- ride adjustment
- keeps dying at idle...plz help
- issues when running hot
- Push Buttom on Our 5.0
- vacuume with cams?
- T5 gear noise!!
- engine POPPING!!!!
- Clutch Problems. Please help!!!
- InFormation
- car wont start.
- questions on cams that will pass smog in CA
- Swapping engines
- dipstick
- valve cover gasket, and dead cylinder?
- '94 Cobra mods, part one and part two
- Weird squealing/whistling sound
- Rear Main Question
- Car is over heating!
- HELP!
- cai install problems
- alternator arcing inside
- front wheel bearings
- Block color help please?????
- Por15
- First 5-0, need some help/advice
- Blinky lights
