- transmission
- intake
- Switch to Mobil 1???
- water pump pulley explodes!!
- INJECTOR CHIOCES
- experienced MUSTANG owners ???????
- master cylinder...
- Stock Intake manifold.
- arrrgggghhhhhhh...............
- Spark Plug Gaps
- 5.4 triton heads on a 5.0
- Oil clean up...
- What is the best year of 5.0 LX to get?
- Cam information
- opps
- Diferences with the 87-93 LX 5.0 Coupe?
- Throttle body...
- fuel pump
- Can i beat this Prelude?
- Pulleys, bad volt problem?
- GT40-P Heads
- CAR NOT RUNNING RIGHT
- 89 GT convertible
- Help! No fuel?
- underdrive pulleys and timing?
- Heads or SC?
- Brakes...
- running with spout off....
- AC help
- New Transmission
- timing?
- Looking at an 86 Stang any advice..
- engine kit upgrades
- Typhoon Intake
- starting problems
- HELP!! car running rough all of a sudden
- Estimated HP and ET??
- Stock Q/M times for a 1989 GT?
- Should i be using fuel rails And what fuel Pump
- My car!
- you do body work look hear.
- adv. / ret. cam
- what mufflers sound good behind L/Ts dumped?
- Sweet Smell
- [Deleted]
- backfire...backpressure?
- upper and lower Intakes ?
- Mustang posi in lincoln rear disk setup?
- project car mounts
- Ignition systems
- problem with 93 5.0!!!!! plese help!!!!!
- 331 info
- how much horsepower?
- 351 heads???
- Which Supercharger is better?
- maf ??
- does any one have any pics of an 88 5.0
- Flush coolant (black radiator.. etc)
- mileage
- Overheating, Please help.
- Intake Manifold Came In!!
- what should i do first?
- Fuel Problem????
- To cat or not to cat???
- Will bushings be enough?
- Ideal exhaust system setup !
- air/fuel ratio gauge install
- Used Ignition
- throttle body
- 88 140mph gauge
- 2 Questions
- Underdrive Pulley Mayhem HELP!
- Need some Quick help
- engine pull
- Mustang Goal 10s...
- Antifreeze in intake/TB
- Tire pressure
- Timing my car....please help!!
- fuel pump power
- were to get 82 parts
- My 5.Slow
- How to run codes??
- HELP
- Timing/fuel problem.HELP!!!
- need toqure specs 351w mains
- Pulley Installation. Help ASAP.
- 4.6 potential
- How much does a mustang weigh?
- Egr plate question
- Last year of the LX Coupe?
- headers / smog
- o2 gone bad
- Fixed my Idle Problem...8$ Miracle
- 5.0 Convertible Problem
- Check Engine Light and Bad MPG
- Gears and ABS
- Oil In upper Intake.
- 1985 T5 in a 1995
- Will I gain power with this and is it worth it.
- how hard is this to do??
- Water Punmp?
- ANYONE BUY RACE ENGINE FROM COAST HIGH PERFORMANC OR DSS OR BENNET RACING?
- sucking in water
- Oil Pressure
- Pulleys
- 1983 Boss
- Stuck O2 sensor.
- ram air question
- What does my stang need to fly?
- Problems after header change. Sorry, long.
- your daily drivers
- Help! have question re: 2001 Mustang Cobra
- No air cleaner or losing hood bracing?
- New Rotors/Pads
- PMS Computer programmer
- Hooking UP AUTOMETER TACH
- Interior electircal problems
- Summit "Leather" Seats
- Backfiring
- HELP PLEASE!!!!
- Messed up headers?
- Starting Problem HELP!!
- Another clutch question
- couple questions after a couple mods :)
- 5.0 to 351W block
- clutch problem??
- Did a few Mods...now a few questions...
- injector question... anybody ever heard this situation?
- White Smoke?
- What to do with stock 5.0 and little cash???
- h-pipe vs. x-pipe
- ignition problem
- i have yet to see a GT'd coupe...
- 5.0 dipstick location
- 94 cobra overheating
- Rattling 5.0 when hot.
- No directions!
- Is the Dealer a smart option??
- aod
- 95 5.0 pings
- Intake Gaskets
- Check engine and off road H Pipe
- 95 5.0 Fuel Pressure
- HELP...what belt do I use???
- Timing is out?
- LongTube Headers=Impossible
- 408 in a 95
- Identifying my block?
- Would the real killer please read this...or anyone
- how much hp?
- when looking for bubbles in the coolant...
- PARTS WANTED 1985 mustang gt PARTS WANTED
- oil pressure help
- Spark Plug Gap
- Hoses on a 1995 Cobra
- Cam and Lifter Set
- Cobra Intakes
- stock internals
- Where'd this thing come from?
- how hard is it to install a cam?
- Question On A Custom Hatch
- NEED HELP!!!!!!!PLEASE
- 5.0 block
- gauges
- fuel or electrical?
- Time for new tires
- sputter under hard acceleration
- 94-95 dyno
- Filter in Side?
- TB stud bolts on new Intake...
- An old post that I can't remember..
- Tweecer
- road map for my motor....need constructive opinions<---note :D
- Timing in a 95 Cobra
- 1995 Cobra single wire by the coil
- Everyones opinion please!!!!!!!!!!!
- possible fuel pump????
- Automatic to Manual Conversion
- Underdrive pulley opinions please!
- car running lean or rich??
- what a dummy!!
- Buying a 5.0...
- Front Brakes
- rear end
- rear end shaking
- just got my pony's needs new shoes
- NEW GUY TO THESE BOARDS
- Computer re-programmer
- Occassional hesitation and pop
- Help with universal joints
- GT getting warm
- Almost automatic clutch adjustment
- allright guys...need help so I can join ya at the track!
- 18" wheels on 88" GT?
- 88gt ho
- Water Pump Impeller?
- HELP w/AODE '94 Trans not going into D, 2, or 1, but will go into R
- car wont start???
- tps question
- E-brake light
- Eliminating smog pump
- does anyone have 95 5.0 COBRA
- just wondering?
- HELLLLLLLLLLLLLLLP!!!!!!!!
- Sunroof
- my sad ass dyno numbers are in
- Stock Tach question-PROBLEM SOLVED!!
- 88gt shop manual
- Engine Shacking alot!!!
- Painting my car...
- Great Deal on Tires!
- PICS of the ride
- Man, Lincoln LS's are quick
- Manual Fan Switch?
- Vibration in pedals
- O2 sensor in aftermarket exhust
- 5.0L into a 99 V6????
- Rev Limiter/Power
- Intake Setup
- 4 BBL Intake?
- not lifters thank god, i think lol
- mph gauge
- rear bearing
- shift kit question, please help
- Very inexpensive CAI
- Dynamic Racing Products
- Adjusted timing
- Jackin up my car
- Coolant temp valve
- What headers for Gt40-p heads??
- timing clockwise or counter?
- 306?
- best place to get a rebuilt T-5
- Aluminum Flywheel
- Everything needed to put in a 331 stroker
- The Right Fuel Pressure?????
- Your opinions please?
- Sending Unit Question
- power steering pump switchout
- Push rods keep bending
- Losing Oil Pressure
- New pistons
- E-Brake Line
- Clutch cable adjustable?
- HELP... Head gasket or not?
- New Brakes
- transmission fluid
- new stang?
- Timing Advance....How Much?
- timing help?
