View Full Version : 5.0 Mustang
  1. bad fuel leak
  2. Fuel pump question???
  3. wanting some advice on a swap
  4. A few questions about 95 mustang GT
  5. Which is Low Pres on A/C?
  6. If you could do it all over again what engine combo would you go with?
  7. Clutch Adjust Question
  8. clutch pedal vibrating??
  9. timing cover 302
  10. Dipstick spewing oil @ high boost
  11. Gas tank sucking air
  12. Starting Problem!
  13. AOD to C4?
  14. How to wire new starter?
  15. Windage tray mounting/oil pump
  16. New Engine Decision Help??
  17. opinions.......
  18. Tuner for 89 GT
  19. Bogging down at wot, please help
  20. Alignment Specs Help-Camber
  21. CT Emissions - Help!
  22. Vibration from 4800+ Rpms
  23. Which gt40 heads do I need to get to clear headers
  24. Stock Tach Doesn't work
  25. Power steering rack
  26. Clutch Linkage....I think
  27. Rear wheel slop.
  28. manual steering rack?
  29. 4.6 Mod into Fox?
  30. Replacing Weatheringstripping
  31. What do you guys think?
  32. 306 vs 331 Price and Performance wise
  33. need opinions about new engine
  34. Junkyard run
  35. Stang not holding a charge
  36. Is this Bumpsteer I feel??????
  37. can you tell me a little something about this manifold?
  38. explorer intake setup
  39. did i just make a big mistake?
  40. I need advice from everybody to let my stang very fast
  41. recipie for 300 whp !! help please ...
  42. Trans questions???
  43. t10 tranny piece of crap?!?!
  44. carb conversion question
  45. best place to get a front bumper
  46. Gas leak
  47. More EFI to Carb Issues
  48. fire problem this afternoon- "Altenator"
  49. what sensors can be cleaned
  50. Turbo 69 Mustang
  51. Can't get scanner to work
  52. What is the largest throtle body size for a cobra intake??
  53. 95 stang cutting out
  54. aod shifter cable
  55. T-5 Fluid Fill Bolt Stuck, Help!?
  56. Motor/head Identification
  57. Guess that sensor!!!
  58. best performance intake manifold ?
  59. Hi Torque Starter
  60. Victor Jr intake
  61. speedometer gear for stock mustang
  62. Electric fan question!!
  63. nitrous kits
  64. 1989 EFI to carburator
  65. Will my 4cylinder springs hold??
  66. Questions on possible Twisted Wedge kit or possible other combos
  67. How to check a u/l intake for any problems
  68. Not Starting! Long story, please help!
  69. aftermarket Fuel Pump question
  70. Radiator prob, or what?
  71. rpm's acting crazy
  72. 1991 /4cyl lx to a gt
  73. 1991 5.0 LX problems??
  74. Starter Bolts Backing Out
  75. installing balancer
  76. x pipe/smog pump connection??
  77. Do all Stangs come Possy??
  78. Is this odd tire wear for drag radials?
  79. timings confusing need help
  80. Power steering cap problem
  81. Summit Ignition Question
  82. fidanza flywheel
  83. EFI to Carb Problems....
  84. cylinder balance test....
  85. How can my engine be over full? drained both plugs!
  86. Tranny Problems need some opinions fast.
  87. 331 with a vortech on stock block?
  88. timing forum
  89. 94 tranny swap C-4 into 94 GT
  90. 1983 GLX 5.0 Mustang
  91. Restoring my Car, where do i start?
  92. NEED Help installing EURO PROJECTOR HEADLIGHT
  93. how big of fuel pump?
  94. Gas Tank
  95. ud pullies and engine heat
  96. New To 5.0
  97. car beeps constantly when lights are on??
  98. killed my coil
  99. Which aftermarket intake will clear strut tower brace?
  100. Ideas for small radiator leak in 91 GT
  101. Gasket question for Trick Flow intake
  102. Couple of questions about my mustang
  103. New wheels/tires on, along with ABS light
  104. Bone Stock 5.0 and nitrous questions !
  105. How to solve this vacuum leak?
  106. modifications and changes to install a cobra intake
  107. carb mani/ wilson adapter
  108. T5 identification
  109. need your help please
  110. testing 2 wires at coil
  111. 393 questions
  112. 5 Speed Problems Please HELP!
  113. A few questions.
  114. o-ring heads. Do you need to machine block?
  115. Where's this plug go?
  116. engine dieseling / sputtering under load etc.
  117. hesitation at slight throttle
  118. aod questions
  119. New heads and cam questions
  120. confused about GAP
  121. Another quick tech question:
  122. Foxbody frame chart
  123. intake manifold removal
  124. smoke while haaard acel! input !
  125. speedo and gas gagues dnt work ..
  126. have a slight miss, could really use some help...
  127. 88 GT no spark, not gettin power to the coil
  128. c4 transmission installed
  129. Got a new stang today!
  130. installing pistons
  131. I'm gonna lose my mind
  132. left hand sensor would be driver side right??
  133. oil coming out of dipstick tube after h/c/i install
  134. AC troubleshooting help
  135. need a clutch .. stiff preferd...
  136. 94 gt wishlist....dont know a ton about it all.
  137. Explorer or Mustang engine?
  138. hey guys need a little help with a newish car
  139. link to correct wiring diagram
  140. When should i replace my distributor
  141. 89 vert GT 5.0 jerking while driving
  142. strut tower rust
  143. if i dident have bad luck......... blown head gasket maybe?
  144. is there a differance in H pipes on a manual and a auto car?
  145. Header Gaskets?
  146. code 92 and 42
  147. cam ?
  148. Paint Colors and Codes
  149. bad clutch fork??
  150. 95 Mustang GT Help! Cutting Out
  151. Will this supercharger fit on my 93?
  152. Torque converter
  153. Advice on a rebuild
  154. AOD Valve body...
  155. 5 lug conversion???
  156. 95gt Track Time
  157. Painting my car
  158. Tranny Trouble?
  159. Better or worse?
  160. sputtering problem
  161. Getting out the hole....
  162. HELP with buying 5.0
  163. wheres the computer!!!!!!???
  164. need a little help and advice on subframe connectors and rear seat delete
  165. nicest 95 on the net
  166. removing 94 gt airbag steering wheel
  167. Snapping sound on accel??? Stumped.
  168. fox body doors
  169. My taurus fan
  170. No start with key
  171. X-pipe vs H-pipe
  172. speedometer correction
  173. aod to 6 spd
  174. new injectors
  175. 5.0 Gurus come in
  176. Problems after 130 amp alternator upgrade.
  177. Buckin', Boggin', N Dyin'..
  178. Which Supercharger
  179. Is this supposed 2 be like this...
  180. eibach springs and suspension
  181. Checking Timing cover/chain
  182. spark plug gap
  183. timing for 408?
  184. Alternator?
  185. Orange notch pic
  186. e-303 cam with ported stock heads
  187. stock intake manifold and cylinder head porting
  188. Chrome Thermostat Housing Q
  189. front sway bar removal worth it
  190. Heads for a turbo 5.0
  191. 93 cobra intake on a 95
  192. Need Help With Idle
  193. front rotor is loose
  194. carfax /....
  195. valve cover breather (347)
  196. tranny swap
  197. piston question
  198. figured out why i didnt have spark
  199. suspension help
  200. E Brake??
  201. 94 Mustang Gt Problem
  202. bad tps?
  203. Question about HP
  204. buying a 95 gt
  205. Professional Products Typhoon Intake Mani Help
  206. stock throtle body size
  207. PCV Catch Can
  208. Estimate on tranny rebuild?
  209. Best transmission for upgraded hp your opionon
  210. EGR passageway in heads
  211. Backfire/Pop After NEW Power-flo Exhaust System
  212. gt40 heads and intake info
  213. Part needed!!
  214. need to pass emissions
  215. Hard starting after driving>>please read for symptoms>>
  216. 1st Post: Advice On Buying A 1979 Gt Mustang
  217. Headlight Issues
  218. New to the site...Just got my first Stang!
  219. Checking TPS Voltage on a 94 5.0
  220. 1995 Cobra... Weird noise... help!
  221. Engine Compression Q
  222. Idle Issue
  223. high pressure
  224. stalling no idle please help
  225. bought my first mustang .. performance help !
  226. Notch Back Seat
  227. 347 tune question
  228. Driveshaft Help
  229. new car problem...
  230. Fuel Everywhere!!
  231. missfire help
  232. I put in a different speedometer, now it's not accurate?
  233. ford racing balancer
  234. Need help tuning my 5.0 fox please?
  235. Need help tuning my 5.0 fox please?
  236. Need help tuning my 5.0 fox please?
  237. msd helppp
  238. New Cobra intake manifold
  239. Roller Rockers, Need answer FAST!!!!
  240. How much hp/tq do i have!
  241. new ring and pinion
  242. new ring and pinion
  243. no turn over, confused help?
  244. Heavy Duty OD band for AOD
  245. Condenser/Evap hose removal?
  246. cheap cylinder heads?
  247. what can i do to beat an 04 subaru wrx
  248. Vacuum hose schematic?
  249. hesitating when hitting gas
  250. clutch switch
