View Full Version : 5.0L (1979-1995) Mustang
- 95 GT top speed
- "88 drop top roll bar
- Updated: I need help
- Bent Valves, Bent Pushrods I h
- 5.8L Swap
- any pics of sexy females o
- Gears = -HP / WRX tuneability
- Ford Racing Performance P
- turbo swap
- Intakes
- Wanting gears? check this!
- Headlights
- side exhaust
- Drop top frame connectors
- 1989 5.0 trans
- Gear speeds
- power numbers
- Ignition Coil
- new ford forums
- convertor help
- hi flo water pump
- Weird brakes
- Will i feel a diffrence?
- depressurize fuel system...
- Pullies or TB
- 302 carbd
- New to Forum
- tps gasket
- Water Pump or not...
- 5.0 sounds sick
- Shift light trouble.../ coolin
- Tach Trouble
- money to burn
- any info for changing head gas
- High volume fuel pumps
- Monster tach installati
- What stall size should i get?
- what special tools do i need t
- Need Help...Been everywhere.
- Please Help!-Bad Engine Proble
- Will i feel the power in pedal
- vfast, professional produ
- COUPLE Questions - clutch
- T5 4cyl ripe off??
- k&n filters
- what hp to expect at the wheel
- help me identify this charger
- 5.0 taking longer and l
- What’s the best clutch for the
- 5.0 Header Questions
- acceleration
- Explorer Intake
- Need help with Nitrous
- Largest MAF w/o fuel change
- any one in fla
- Most possible horsepower from
- question about 347
- Running Too Rich 88LX5.0
- Notchback = Mustang LX?
- Port MAF?
- 347 why so slow?
- Help! Backfiring and loss of p
- Car takes a long time to
- Anyone ever used this ?
- Fuel Tank Size
- cat back question?
- I increased the timing, but lo
- stroker kit
- New alternator for electric fa
- what times should i run with t
- interior
- HEY,do i have gears?
- what size injectors should i h
- looking for a 5.0, i know noth
- any canadians out there.......
- 88 gt aod
- Stock mustang 1/4 mile and 1/8
- stuff for my computer
- transmission and geaar he
- Pro 5.0 shifter
- DRIVESHAFT
- Heat soak with equall length h
- Gonna get heads and intak
- BBK subframes on con
- Gettin a new clutch
- Mustang interior Color Codes?
- s**t,speedometer is jacked up
- Does anyone know how to b
- Intake manifold problems HELP!
- what internals to use in 92 re
- BUILDING A FRANKENSTIEN. ANY
- Monster tach
- fox body mods
- driving 86 GT in winter
- Pulleys
- please help im going crazy
- Starter Clutch Pedal Positi
- what would you pay?
- cylinders 7&8 misfiring
- Child Safety Seat
- AOD ECC O.K with 5 speed??
- z28
- Vfast, help me
- Bent pushrods ? Car not runing
- stupid freakin cd player!!!!!!
- Timing Advance
- flowmaster
- Race
- NO TRACTION
- Plastic clips, fuel tank to fi
- Mounting the rear end!
- Oil Pan Gasket
- t56 swap from aod
- what horse power do i have?
- gears, headers, x-pipe
- Cam - Piston Interference
- EGR
- rack and pinion rebuild k
- Can LX Front bumper go
- Fuel Regulator
- Speedo Gear ??
- Best small block mustang V8
- Any guess on this car
- my stang too slow
- 87 GT question
- i hate f**kin single tire burn
- Gears?
- 88 speed density with crane ca
- no posi
- old Hurst T-5 shifter
- Roller Rockers
- trick tach
- msd
- Blown Tranny Aode
- getting into the 13s
- Upgrading a bone stock 19
- 5.0 vert
- went to track
- Tires
- Irratic Idle
- going to a carb. on a 95?
- best clutch kit
- 5.0 Motor experts what you thi
- pulleys on 94 cobra?
- Ford Badging
- 3.55s or 3.73s?
- 94 GT Stall at Idle?
- poor idle
- cleaners
- Best Break upgrade
- Which CAI?
- H-Pipe crapped out
- Bad Vibrations
- Loose Rear Wheel Bearings
- in need of a rebuild?
- Alarm System keeps going off!
- will tranny hold?
- Mustang injectors: low or high
- cheap rear disc brake con
- Compression ratio
- 18 inch wheels on 91 foxb
- Best spark plug gap for 5.0?
- air bag code??
- 300 to 350
- 86 mustang head rests
- why no power
- how to adjust a ram power grip
- 23-24 MPG
- Carb replacement
- Top Speed
- Stock Ring Gear Diameter
- Springs
- Shorty Headers
- gas mileage
- throwout bearing
- fast idle/red hot headers
- Throttle Body Spacer??
- NEW CLUTCH!!
- dead turbo motor
- intake not sitting right......
- dead turbo motor
- new gears and gas mileage
- Md? Anyone?
- horsepower
- burnig up o2 sensors
- Questions about 91
- tire size
- AOD problem
- HELP!!!
- desktop dyno....
- blowing steam all day..
- engine loses power and dies
- Tires
- Why is my car stalling???
- Stock HP and Torque ????
- 4 wheel disc conversi
- Tach installation
- Pic of my car
- slipping clutch
- To Horatio102
- aod to T-5
- intake problems...
- Disc brakes and suspensio
- EGR valve chugga chugga
- wow what a small timing change
- just installed a trick flow...
- power
- Good Deal or not?
- NOW ITS MORE THAN A Bad Mis
- Tachometer/Speedometer Problem
- Fixed o2 problem...
- idle speed adjustment
- school
- rims
- fuse location on 84
- wheels and tires
- TPS = More Power??!!!
- Signal flasher location
- Light bar, styling bar or roll
- computer choices
- Whats the best fuel injector c
- CHANGED INJECTOR, NOW LOW RPM
- gas mileage part 2
- gas mileage
- Dumping the cats on my 94
- oil burning, please help
- mac parts
- Running Rich..
- mass air
- Tricks of the Trade
- Oil Pan Part 3
- Ticking
- 5.0 HAS A DEAD MISS ON #7
- LX Vs. GT
- Mysterious Problem
- looking to buy a 5.0
- Computer
- 93 GT Headliner- How to Fix
- Suspension
- question about pulleys
- Magnaflow
- Off Road X-Pipe With What Muff
- No power
- Suspension
- Break Question
- 91 lx 5.0
- What tranny are you runnig?
- What type of intake are you ru
- What exhaust are you running?
- T5 or T45??
