- new car problem...
- Fuel Everywhere!!
- missfire help
- I put in a different speedometer, now it's not accurate?
- ford racing balancer
- Need help tuning my 5.0 fox please?
- msd helppp
- New Cobra intake manifold
- Roller Rockers, Need answer FAST!!!!
- How much hp/tq do i have!
- new ring and pinion
- no turn over, confused help?
- Heavy Duty OD band for AOD
- Condenser/Evap hose removal?
- cheap cylinder heads?
- what can i do to beat an 04 subaru wrx
- Vacuum hose schematic?
- hesitating when hitting gas
- clutch switch
- pison ?'s.
- Valve Covers
- Collapsed lifter???
- TIMING, PINGING, EXHAUST LEAK, VALETRAIN?
- Difficult to shift after hard launch
- 94 GT Clock goes on and off?
- Popping out of first gear
- Valve Covers for TF TW?
- Dont know what to do need help!
- 1986 Mustang GT Transmission
- clutch/throw out bearing issue
- filling a t5
- How high of a lift can stock springs handle?
- Exterior Door Handle Help!!
- summit injector
- when do you change timing
- notched pistons
- exhaust disaster!!!
- Fuel Pump Diagram
- At what point would you change Cams?
- going to to junkyard
- adjusting ebrake
- Steering rack interchange
- fans coming on late?
- OVER CHARGEING!
- Speedometer gear question????
- mech press test
- injector question
- Starting Problem
- Different carb covers?
- Please Help
- evr testing
- Coolant in oil
- clutch problems help
- JUST PURCHASED
- Heater Core Hoses
- Killer Rust
- Trans problems or rear problems?
- 'Linelock'
- C4 Transmission or C6???
- TF Track Heat Package
- whats my hp/tq
- how much power gain?
- Calling all with GT40Ps and BBK headers
- DO NOT BUY!!
- 347 troubleshooting
- gt40 upper and lower intake
- Track Heat/FPR fitment issues
- 500 hp NA California Smog Legal Combination?
- Roller rockers worth it for stock engine?
- fresh motor install HELP??
- anyone have pics of accessory install?
- do u get that feeling?
- ....clutch....
- Removing windshield/hatch trim
- Were to buy crate motor!!!
- KEEP ON GETTING CODE 34
- Rear end fluid questions
- Idle problem
- gasket quest
- Help! A 93 Cobra is calling.
- my clutch is acting silly help please!
- how to test egr circuit
- Testing for cracks on U/L plenum
- Time for a rebuild. Question about my options.
- gt-40 head ?s
- +++++New Problem- Any idea's?+++++
- 302 cleveland???
- horsepower
- Best Muffler Stock 89 GT Auto No Cats
- Fuel Pump
- no spark help
- exhaust
- 3.73 in a 92 auto? high speeds
- powerflo's by slp!! need/opinions
- Installed different instrument cluster, speedo not working correctly?
- Help! Rear Lower Control Arms!
- Gear drive or chain
- supercharger or turbo charger?
- Thermostat
- no fuel?
- Emissions Testing
- Time for a engine rebuild and Question about my options.
- Headlight chime location on a fox gt?
- replacing half a vert top frame
- Would this Tire Size fit Fox Body GT
- dyno
- Changed out my Instrument cluster, now have a beeping sound?
- will newer egr work for 88
- 1.6 or 1.7 - horsepower difference
- Manifold,Headers?
- ring & pinion install
- Trying to pull codes using flashing CEL? Update
- O2 wiring question
- aftermarket clutch assemblys
- general questions about shocks/struts
- Flex fan to clutch fan
- 185 CC PATROIT HEADS QUESTIONS
- turbo 347 down for the count AGAIN! dang ign box
- Issues After Head and Intake install
- ebay twin turbo headers
- rear bumper install
- Help needed, advice on 88 GT
- I've got a few questions
- alternative trac lok clutch order
- speedo change
- oil problem
- Rear End Questions
- Looking to buy a 5.0L, need al imput!!
- tires?
- H-pipe install
- Hatch Problems
- 88 gt vacuum line help?
- vert top frame?
- Exhaust Leak?
- engine bay
- How Much Oil ?
- Temp Gauge Surges up, then back to normal
- rough idle and smokes
- Vaccum Leaks
- stalling
- 1985 throttle body replacement
- AOD?
- AOD?
- Brake Light Help Needed!!!
- Motor Skipping?
- car lags when returning to idle
- how will bad e.g.r make the car run??????
- BAD gas milage HELP
- MGW Short throw shifter?
- Clutch on its way out?
- ignition problem?? again
- What do you think about what this guy said...
- Clutch Smells But Isn't Slipping
- 8.8 swap, halfway through
- roll cage
- Car starts then dies
- Setting the TPS Voltage?
- 302 questions
- Cobra computer and maf
- rear wheel problems. PLZ HELP!!!!
- Fog lights pigtail harness
- 390 in a fox?
- ebay turbo kit ???
- injector size
- wont start!
- MOVED: powerflo by SLP!!! please respond
- take off backseat
- Speedometer cable question
- gear advice?
- Newbie needs help with a 5.0 top end
- team z upper control arm kit
- Rear Hatchback Seat Delete
- first stang
- performance Parts for sale !!
- good price on an 85
- Little Advice Please
- front a-arms?
- FR Boss
- these questions may sound dumb to you...
- how can you tell if its a 302 or 351 W?
- CRANK NEEDS TO BE TURNED?
- tfs stage 2 cam with stock bottom end
- 2nd new battery and now the car won't start again, please help me>>
- new short block.. any prep?
- Need some wiring help
- Tach rpm reading double?
- All sorts of problems with 95 Mustang GT
- Speedometer fluttering
- Upper Radiator Hose fitment issue
- Wet to dry?
- starter
- Header Question
- Windows Screeching?
- 85 Dizzy Wiring Issue
- Another Speedo Gear Q
- limited slip differential
- Oil Weight
- Good Cam For Supercharger ?
- ported twisted wedge's?
- oil or vaccum line
- Increase TORQUE in generally stock 5.0
- fuel gauge
- belt routing
- car pinging
- New Brake setup/ 5 lug conversion questions?
- some ?'s about my new motor
- Valvetrain Noise . Indication to problem? Normal? Do i need new rockers?
- MOVED: a glimpse into the future (tach porn here, lol)
- MOVED: black chrome/hypercoated/whatever you wanna call it.
- Help! Upper control arm bushings?
- trac lok rebuild
- Loud, repeating, clunking noise
- intake manifold
- Transmission Slipping
- How Do We Break In Our Motor ?
- Problem with OEM clutch?
- Question about ride height after spring install>>
- Door problem
- balancer timing marks again
- tailpipes
- AOD Build
- I have an odd problem
- fuel injection setup?
- 460 in a fox
- synthetic oil
- Please help me get my passenger power window up??
- Passanger Door Problems!
- Fuel pump spraying fuel
- valve tap
- window problem....
- which heads to buy
- what are my options....
- Quick stereo wiring ?
- map light issue
- tranny alignment issues.
- trans crossmember
- EFI to Carb Question
- Gas Gauge / Speedometer problem 87 5.0
- f$$$in codes help me out
- Pushrod Length
- Cruise Control Surge
- installed fan switch now no blinkers
- Question about E7s and GT-40 Iron heads
- misfiring
- What should my timing be set at?? please help me??>>
- quick quesion
