- assembely question.
- ? about tranny
- High revs and chugging
- wire problem
- MOVED: IS THIS A GOOD DEAL!?!? zex dry nitrous kit
- new project
- I'm getting bad vibrations
- so i did the koer test....
- ENGINE STAND
- no idle after startup
- Where to set my timing?
- How many pulses does our engine put out ?
- Sound of LT vs Shorties
- getting koeo code 84
- self test input wire location
- HP/torque; stock 1995 with 5.0
- rear end problem
- dyno
- engine swa k-member
- oil ?
- I know I broke something...
- EFI to Carb Question
- Don't know what to do next
- top pawl gear wont come off
- KOEO wire pics
- explorer rear end swap
- egr?
- bored .060 over
- what starter for 164 tooth 11inch flywheel
- koeo test problem
- sure could use a hand....
- Location of carb model Number?
- fender aprons
- alternator wiring issues???
- fuel pump and regulator
- Breaking up at 4800 RPM
- 5.8 H.O. heads
- going dead &won't start back in stop &go
- struts
- Rear Axle side to side tolerances
- rear end swap
- Flex-a-Lite Fan
- speedo issue?
- ground effects question
- MOVED: any good machine shops in S Jersey?
- MOVED: Striped hatchbacks
- speedometer cable troubles
- 89 LX Convertible Top Replacement
- shocks
- headers for gt40p heads??
- T-5 to C-4 trans swap
- heads
- full throttle hesitation
- rear end drum to disc
- flywheel/starter question
- ported 351 heads vs stock E7's?
- lost power race tommorow HELP!
- MOVED: which hood pins?
- car keeps dying
- 1994 GT 5.0... replacing front clip
- vibration at higher speeds only
- KEEPING A CHARGE alternator battery wiring HELP!
- power locks/windows
- oil leak, killing me
- Can 190 pump flow 42 lb injectors?
- anything wrong with running just one header?
- more header install problems
- 5.0 cam specs
- 3570lb race weight!? WEIGHT REDUCTION HELP!
- 302 Headers on 351
- inspection time draws near....
- Fuel pump wont turn on after swap
- MOVED: my hatch
- MOVED: Goin to look at a Late 80's fox bod HELP
- how much power for stock radiator?
- removing the bumper?
- how does 42lb MAF work ????
- adjusting valve lash
- clutch cable stretched?
- driveshaft to 8.8 rear end question
- Shifter tranny combo
- brand new starter went
- 4bbl intake for 255 (4.2)
- ARP head stud questions
- b303 in stock motor?
- egr diaphram
- headers won't go in
- Cam ?
- Relay wiring for cooling fan.Cooling fan switch terminals corroded.
- altenator
- Shuting A/C off... engine stalls?
- Bad experience with EncoreMustang
- how many mm?
- do you have gt40P's??
- misfire
- need help alternator bracket
- trickflow intake
- Carb Question
- New full exhaust questions?
- water pump replace
- Car dieing, will not start back up please read for symptoms>>
- 93 lx cam???
- Should i just give this guy 3500 out the door!?
- Timing cover gasket replacement
- what a day this is going to cost me.
- do these need to be welded in?
- 3.73 Change, Speedometer fix
- electrical. alternator fuse link keeps blowing
- clutch problem
- its been a sad week
- new motor
- EFI to Carb
- Few misc. Questions
- head question
- bouncing speedometer
- spark plugs
- powersteering pump delete
- E-tron
- computer
- Which direction to take?
- Hard start and rough-no idle
- What color are the turn signal wires in a 94 mustang gt?
- Need help with ring and pinion
- MOVED: BIGGEST Wheels!
- roush carbon fiber interior trim kit for 1995
- Please Help- Want to buy heads!
- looking for quick easy answer
- stock radiator efficiency
- Dowel pins
- Bought a 89 GT. . Need help!
- cam?
- Aftermarket Headlights
- max rpm
- t5 won't shift
- road test
- Would I gain anything by installing cobra upper and lower
- Can the clutch cause vibration?
- Knock Sensor???
- Just Want To Make Sure I Dont Forget Anything...
- Steel rod under intake bolt?
- gt40p heads and pushrods
- Hi, new member to forum- need your help!
- MOVED: Anyone Have HID's?
- FROM EFI TO CARB??
- MOVED: 17X9 RIMS ALL AROUND ON 87 GT??? HELP
- Stock EFI Fuel Filter
- TDC order?
- Need Help Guys !
- rpm drop???
- Serpentine Belt Size w/o smog and w/ A/C
- quick question
- is it possible to put a t-5 from a turbo coupe in a 5.0
- efi 302 to Carbed 302 conversion?
- building a 302 from scratch... questions
- Camber adjustability on a 89' LX?>>
- Where can I get this from for cheap
- H/C/I break in
- AOD Shift Kit
- Air/Fuel Gauge
- Instrument Voltage Regulator
- speedometer problems
- How do I erase codes?
- 351w trans
- southside bars need help
- MOVED: how much hp?
- Notchback specifications
- VIBRATION PROBLEMS
- MOVED: made my own strut tower brace...
- starter ?
- Getting my car from the shop tomorrow
- Tranny Swapping
- checking for codes
- 347 or not?
- Stock AOD power rating
- need to beef up my t5 could use a little advice
- fuel lines,rails question
- SCAT Engine Components
- Still getting code 22 on KOEO
- MOVED: back in the 5.0
- wipers not parking
- Spark Plugs
- MASS AIR FLOW
- Tapping?
- An Irritating issue
- t5 to c4 swap
- getting my stang running
- '88 Tming Chain Cover & Water Pump Bolts
- Speedo gear help on my 86 gt
- Water temp+ oil press
- need help identifying motor
- quick question to the knowledgeable people on here.
- MOVED: center console
- Wiring o2 sensors
- please help bullet wheels on fox
- Anyone used the Fidanza 1.0 clutch kit?
- NO SPARK
- 5.0 carburetor advantages?
- Upper intake gasket question
- Help, Fighting Heat
- What makes a carb'ed car not start??
- need help asap
- Strange problem after TF top end kit install..
- Why can,t I get any codes?
- I'm boxing in my lower control arms
- still need suggestions
- clutch cable just snapped??
- VFiber saleen kit...anyone seen one in person?
- anderson pms question?
- T-5
- 92 GT in need of HELP!!!
- seat suck in position
- Engine backfires and lacks alot of power
- 5.0 what year is the engine?
- ac and smog pump delete
- Looking For Awesome Fox Fox Body Kit ! Need Ideas!
- 92 GT Speedo stopped working!!!
- Anybody put a Saleen S281 spoiler on their 94-98?
- need traction
- 5.0 badges on an sn95
- brake light switch
- Speedometer doesn't work after aftermarket tachometer installed?
- sway bar bushing
- Crankshaft pully
- GT40 head ? plz help
- Can't put my finger on it...and it's driving me nuts!!!
- need help asap
- explorer intake??
- Quick one for ya
- ACT relocation
- auto to 5 speed?
- need some help in deciding what mustang to buy
- need help please
- rear end Swap
- 5.0 starter/wireing problems
- Anybody know?
- head identify
- am i gonna break 350 hp?
- has anyone done this?
- longtube question?
- converting a fuel system
- Fuel filler neck
- msd 6a wiring harness
- heads for a stock 351
- enough is enough
- idle and hesitating problem
- 5.0 ford explorer mass air meter?
- What next then?
- single to dual exhaust
- Fuel level sensor Problem
