- MOVED: What intake do you recommend?
- Oil Pump?????
- GT40 Head Bolts
- Unidentified Wiring Harness
- someone diagnose this
- headlight fuse or relay
- Possible Electrical Short
- Full Throttle
- re:sandblasting headers ?
- Suspension
- cold blooded or....
- overkill on clutch for now?
- American Mus. Code
- Car is running terrible
- belt size with march alt bracket
- Replaced Flywheel?
- coil spring question
- car leaning
- exhaust opinions
- Help! I need a computer for my 93
- Overflow subsitute??
- street/strip/autox?
- fox brake pedal question
- Harmonic Balancer removal/install
- MOVED: what do I need to beat an lt1 trans am?
- car is sluggish, where to start?
- AOD rebuild questions
- RearEnd Experts
- MOVED: what do i need to beat a Z28
- hesitation at heavy acceleration?
- Cool looking LIGHTS?
- Anyone LOWERED their mustang?
- Exaust Question gimme your 2 cents if you have it to spare
- Cracked block or hopefully a head gasket?
- Red Line on Rebuilt 5.0
- auto wiring harness questions??
- Nitrous Question in particular ZEX kits
- throw out bearing
- rpm's wont go down
- Oil-psi, temp, and volt. meter install, help
- speedo cable
- yet another wheel question
- Engine revs
- fuel pump
- t-5 rebuild
- MOVED: Looking for Fox Body 5.0!
- MOVED: glasspack sound clip
- GT40's and HP numbers
- EFI to Carb questions?
- smog pump removal
- fuel pump question
- stuck once again...
- speed density or maf?
- 48 casted on side of head e7te?
- electric fan
- LT headers, off road X pipe, SLP 2 CB.
- wtf problem
- what wire goes to what on my + and - on my ignition coil?
- Removing the rear seat
- Easiest way to rid of old gas?
- Vac Lines
- gears
- rear control arms
- green 8 pin?
- MOVED: 11 dollar paint job
- gradual heat-up
- Need help...clutch/tranny/gear advice needed
- Guys with Weld Drag lites, come on in, we gotta talk!
- question.
- transmission,gears,hci,nitrous
- cam
- Headers????
- NA engine build??
- aod torque converter labeled 2640ls? what does that mean?
- what dizzy
- gt40 heads...need some educating
- heavy duty?
- Cowl vent area repair?
- MSD blaster coil 2
- where can i buy new spider gears??
- turn signal problem
- turn signals stay on
- Ignition Lock Cylinder
- Which thermostat to use
- please help this is killing me!
- MOVED: Looking a little iffy
- Strut Tower Braces
- belt length
- intake install
- Shocks?
- Power steering pump and hose question
- problems.
- header question
- 91 Mustang lx 5.0
- MOVED: 4.6 vs. 5.0
- engine bearings and oil??
- dropped fox
- 351 swap
- MOVED: Help deciding...03Cobra or FR500 Rims?
- Radiator recommendations
- ecu replacement
- Having engine rebuilt while deployed
- troubles again with codes, HELP!
- valve springs
- help me out!
- Dammit, not again
- 302 efi rebuild book
- egr code 33?
- heater core leak
- need some opinions on good parts
- MOVED: Recommendations for alarm system for Fox convertible?
- tune up questions
- steering wheel issue
- ignition coil
- have any one use moates tunning kits
- MOVED: LOUD EXHAUST
- went through a dizzy cap way too fast
- A/C vents
- Cowl Repair
- possible aftermarket engine
- timing help
- Homegrown Turbo Kit. Help me turbo my car!
- PTV on explorer 5.0
- 94 runnimg hot
- Heads
- new "used" shifter
- Did i smoke my clutch
- Just got my motor back in... (clutch)
- 87 GT alternator AMP light HELPPPP
- Replacing the instrument lamps in a '91?
- Subframe connectors
- Stall/mpg
- Fuel Pressure Gauge?
- which one
- only want to buy front lowering springs
- ford strokers or CHP?
- Easy BOLT ON HP!
- need input on an intake....
- Just wanted to say
- PCV location
- sloppy steering colum
- 1988 Heater Core...
- taking off door / fender
- relocate ect?
- 5 speed to AOD swap! Motor wont turn over
- How to tell if lifters are pumping oil?
- Need some opinions pls
- gasket porting questions???
- engine making noise
- Need help engine codes
- IGNITION TUNE UP QUESTION
- Need Some Help
- 351 heads
- Spark Plugs
- need a clutch
- Just Shut Off While Driving Again !!
- porting heads/intake, hp gain?
- Stock Pulleys
- Best Cam For Bolt-On 95 Cobra
- plz help!
- EFI TO CARB HELP
- widest wheel on a fox.
- remove bushing from its shell
- Is a Auto and Manual Computer the Same ?
- MOVED: where do i go about finding a good smog delete kit??
- compression
- New clutch?
- throttle body help PLEASE
- gap on spark plugs? HELP PLEASE
- 3.73 or 4.10
- MOVED: what you think this is worth
- Power window to manual
- 87-93 convertible door panels
- bellhousing alignment
- rear end questions
- puttinga AOD behind a motor that has a pilot bearing in it still?
- MOVED: 1995 5.0 vs. 4.6
- my 89 gt running crappy...
- Alumn Driveshaft ???
- 95 gt mods?
- my 89 gt!!
- cam/heads
- codes again
- Full exhaust with headers or Gears?
- iac valve
- MOVED: Before and After
- cobra intake install procedure
- Motor Oil...
- MSD Digital 6/Nitrous
- carbed mustang question
- car has no accelation till 2800rpm
- real bad spudder
- MOVED: My 1989 Mustang GT project
- Wiper Motor Voltage Anyone??
- no gorund to fuel pump relay?
- 86 gt to 07 gt
- Injector type, Vortec questions
- wiring help
- lookin for the right pistons!!!
- Instrument illumintaion?
- quick ?
- Came up on a 97 Explorer
- used axle
- MOVED: 88 Mustang LX 5.0
- random stalling
- leak on stock upper intake?
- Cobra LIM porting (gasket matching)
- gt40 specs
- Over Heating with AC on
- lunati cam question
- If not a T5 than what?
- 31 spline and carrier change
- Adjusting Throttle Cable ???
- trans bearing retainer
- 351 and headers
- Electric Oil Pressure Gague
- distributor/cam pos. sens. question?
- spark knock
- rack & pinion
- MOVED: What Gears
- ECU question
- broken clutch cable.
- Sudden overheating
- KOER code 33
- replacing front struts...quick question
- Where to start, CAI?
- AOD SWAP HELP! driveshaft and shifter
- MOVED: Saleen style wing ?
- trick flow h/c/i kit illegal for 95 and older.
- Barometric Sensor ? What's its purpose ?
- will an alternator
- torque/ft.pounds on intake
- cobra intake
- buying afr 165
- MAP sensor
- Vacuum canister or Pump?
- solid roller lifters
- underdash wiring
- 95 mustang chip?
- MOVED: Another what will my time be??????
- 347 w/ Main Support and oil dipstick problems
- Paxton SN-93 supercharger..
- Underhood Wiring Project
- Vortech FMU vs Fuel Pressure Regulator
- EGR and explorer intake questions
- Hood Pin Installation Help
- dyno tuning question
- Clutch Question
- car is messed up please help?
- bad sputtering and backfiring problems....
