- GT-40P
- Need help Pilot bearing issue
- need help asap
- Hard Start & Sometimes No Start when Hot! - HELP!
- Converting a 4 banger to 5.0
- Valve cover gasket replacement on an 86gt
- MOVED: Finally added 4 more lugnuts
- 5.0 Hesitation and complete loss of power
- MOVED: What's this 5.0 worth?
- Troubled
- rear suspension suck!!!!
- which cam?
- 10 pin connector question
- '87 shakes
- couple questions
- what does this thing do? blocking my vacuum
- will i notice power?
- 3000 rpm idle
- Roller Rocker Question.
- Help me fix my gauges.
- Transmission Cooler thread size
- adjustable fan control? help
- maf sensor question
- MAF/TPS
- Upgrading heads on a high mileage block
- school me on cams please
- flex fan?
- injector size
- Need new clutch
- Suggestions on water pump replacement
- installing bbk long tubes any tips??
- headers for 351W and gt40P heads?
- Stock ride height
- valvetrain geometry
- Firewall adjuster
- Mi caro no starto...help!
- injectors leaking!!!
- Engine casting numbers
- Egr Delete or Egr Back off plate
- Tuning questions
- oil pan BOLTS,HELP PLEASE
- AC questions
- intake manifold fitment
- 1986 Fender and Bumper question
- air intake silencer removal.is it worth it?
- electric fan?
- EGR?
- im back fellers! and buyin a new mustang, have questions!
- messed up clutch???
- Engine Help?? somewhat overheating
- Clutch cable install, help, fast!
- replace water temp gage in instrument cluster
- installing oil pump
- suspension fit
- hp rating(changed therad
- eagle rods and crank
- Can anyone determine my rear end.
- Sick and tired of my f***ing T5
- I'm sorry, I can't read forum rules
- Long tubes or shorties?
- a different gear question
- MOVED: Interior Paint
- oil question
- 5L Grand Marquis Engine + Nitrous?
- Idle air controller / maf
- Stock Turbo 1985 5.0... how much?
- got a ?
- Help be build 400 + hp/tq in a 347
- What Transmission
- Stang Won't Start
- what kind of distributor?
- eibach drag springs CUT EM?
- Just installed Headers and O/R H pipe...quick ?
- trickflow 1in spacer
- battery issues!!!
- 255/40/17 on 1988 GT
- Vents
- Stock Pulleys
- a/c question
- Body replacement question
- CAM QUESTIONS
- Bracket for Dial Indicator
- r15/325/50s
- mustang 5.0
- 94-97 Wheels on a 87-93 Car???
- 4cyl to 8 conversion... Q's
- new spec clutch= problems
- 1.7's, stock cam?
- Alternator Bracket Troubles 94-95
- i have a ?
- ther anyone any
- Drop Spindle Help
- trans
- block and internals question.....
- stock pony
- Auto to manual swap?
- converting sd to mass air help!!!!!!!!!!!!
- Coolant leaking into OIL Please help!!!
- AOD shift cable help
- setting tps help
- Speedo gear size
- Need some advice
- orange wire coming out of salt& pepper shakers
- stock size rear
- 5 lug convertion ?
- THR 347 in my 94 GT
- car hesitates after shifting into gear
- 408 question
- no start after changing computer and wiring harness
- anyone running 17X10 deep dish rims on their fox
- Couple Questions
- BBK header gaskets...which way to install?
- Ignition control module(TFI) question......
- Injector Swap with Speed Density
- 89 lx 5.0 fuel problem?
- '94 3.8 V6 to fox 5.0?
- Cats or No Cats
- idle issue on start-up
- exhaust air supply tube gasket
- hood pin opinion- which pins?
- I blew up my clutch tonight and need a new one
- cam in stock 5.0?
- fuel gauge
- nitrous on a stock fox DD
- clutch is going
- reinstalled trans now bad idle
- storing it for college
- mechanical genious's
- pcv valve keeps blowing out
- gt40 upper/lower intake?
- safe power levels for a 351w factory block?
- i need hel with getting rid of my smog pump on a 89 5.0
- mmmm... weird noise
- accelerator release
- where to buy interior paint
- muncie 4 in a 84 Mustang?
- I think my Clutch Cable broke
- 5.0 Rebuild question
- Expectations??
- gears?
- E303Cam with a Carb????
- MOVED: What is a good 302 setup?
- Gap spark plugs to .050" or .054"?
- any one used the 5lug svo convertion???
- MOVED: CRYSTAL BALL ET ANYONE???
- 600 hp and fuel
- recommended shifter for C4 in Fox
- Schreder Valve Size for FP guage
- Summit Ignition box
- Where is the Starter Relay???
- Gear install....how difficult?
- Smoke...?
- TRACK RULES FOR CONVERT.
- fluidyne rad leak
- drive shaft to diff seal name
- engine work in New York
- clamshell spring compressor?
- reverse lights
- Power Mirror Question
- problem solved weird flywheel issue
- HP seems low for mods
- maf? EGR? and TB?
- Need help selecting parts for AOD auto for build up
- pro 5.0 shifter owners
- fuel pressure
- opening it up?
- MOVED: 90LX 5.0 For Sale
- Rocker noise
- can i remove the cats on my stock 89 lx without a problem?
- ford or crane rockers?
- rocker arm install question
- Throttle Body/Intake Combo???
- need some bolt sizes for my 5.0
- 1989 Mustang 5.0HO with high-performance after-market parts
- wiring harness
- wireing harness
- back firing through carb
- Could this be the root of my problem?
- Rough Idle?
- fuel pressure
- Aftermarket radio and dash. Need help
- rims fitting on an 85
- 92 Mustang windshield wiper motor
- replace Stock Cam for MPG
- Clutch Cable Question
- MOVED: SHOULD I RUN SYNTHETIC
- Weird issue, help me out here.
- venom 400, any good?
- more power from a rebuild
- STALL CONVERTER QUESTION...
- Vac Leak Cause Overheating?
- X pipe question
- Gas Gauge HELP!
- getting a bit of smoke?
- finally some fox pics
- 5.0 Mustang Pictures Needed.
- 289head on 302block
- auto to manual
- header exhaust question.
- Passenger window gremlins?!?
- help plz
- Anyone install a oil pressure switch??
- Dead Fuel Pump
- GT-40 up and low
- stupid longtubes
- Underdrive pulleys
- quick timing set question
- What to do with 2000 dollars?
- 4th gear and 5th
- Please Help, I think i really messed something up. Near waterpump.
- need advice plz!!!
- DO NOT POST THIS CRAP IN MY TECH SECTION
- BBK 5008 Intake Manifold
- scorpion rocker arm question
- Fuel Filter?
- Procharger powerpipe
- 92 Mustang with some, well issues
- will a 4cylnder t-5 fit on a v8?
- what blows on the 4 lug
- Cam Specs
- top end install..
- Dumb stock exhaust question
- posi trak question
- Airbag Light
- MOVED: pic request: Quadrant installed on 5spd pedals & F.W.A.
- MORE POWER?
- supercharger problems
- Elderbrock Perfomer EFI intake
- Radiator and trans cooler upgrade!
- slippage and check engine light
- 88 GT For Sale Lots of Mods
- Installing underdrive pulleys on 87 GT
- Trick flow twisted wedge heads questions
- SN95 cam question
- oil leak on my 5.0
- Fox disc size?
- summit radiator question
- Turbo Setup Question
- Need Help Automatic to Manual Swap
- engine banging ...like midgets with hammers inside of valve covers
- Strange clunk noise in rear???
- 93 5.0 crank
- fuel line question
- 93 5.0 with high miles
- Saleen Supercharger / Vacuum problem HELP
- spark plug question
- expl-lower cobra upper intake
- Door Panel Stand Off
- 95 GT stock dyno whp
