- anyone have problems w/ bushings on UCA's
- Axle is hitting my exhaust...
- lincoln rear disc brakes...
- Please Help...car keeps dying
- brake question
- transmission change
- turn signals stoped working please help!!!
- loss of power
- how do i tell how the flywheel goes back in?
- good launch RPM
- EGR?
- fuel injectors
- How do I check the level of Gear Oil?
- HOW TO CHECK FOR REAR MAIN SEAL LEAK? AND HOW TO REPLACE?
- engine rebuild... tips for a newb
- rear end ?
- exhaust questions?
- Gasoline Stabilizer success story
- anyone whos got mm caster camber plates?
- cobra rocker parts, HELP!!!
- Frustrated! I need ideas~
- Suspension $??
- body molding
- Head swap
- intake gasket
- Just Wanted to say Thanks
- GT-40 HEAD SWAP
- car wont start
- trick flow twisted wedge
- What kind of hp will I be getting out of my 357w?
- how do i remove a stuck pilot bearing?!! help!
- kooks long tube headers?
- Twin Turbo setup - Need advice?
- Quick Question
- idle issue
- Power steering Q
- Windshield Wipers
- trick flow gaskets????
- 3.55's or 3.73's?
- rear window louvers...help!
- Heli-Coil in flywheel. Bad idea?
- exhaust swap hp gain
- Intake shenanigans (choosing parts)
- Is it true?
- Will a '93 speedo work in my '88 gt?
- Nos Timing and Plugs
- 93 COBRA ?
- sway bar/frame issue
- Tire size question on fox body
- How much vacuum with stock cam and gt40 heads/intake
- STARTING PROBLEMS! plz help
- Electric Fan Wiring
- summit headers?
- 95 gt, automatic to manual
- more clutch woes
- B&M hammer shifter
- Has anyone replaced the AC blower motor?
- intake
- Thermostat questions
- las vegas
- 347 very lean!!!
- before i upgrade- domestic test
- tips for taking the dash apart
- MOVED: whats it worth?
- Axle Splines Good or Bad????
- rear sway bar
- speedo
- Steering issue... great
- Would it be better?
- gt40P header question
- stalling after mass air converson
- 5spd computer on automatic car ???
- Did I get ripped off or good deal?
- valve cover clearance?
- Help with re-routing belt
- |||Please help..wont shift into 4th gear|||
- clutch pedal feels firmer after installing quadrant and cable
- tranny problem
- side mirror
- 1 fast question
- Heat lukewarm after new radiator, heater core, thermostat...etc.
- Oil Pressure
- Piston To Valve Clearnace issues possibly
- 94-95 GT Linelock?
- 347 scat rotating assembly
- bogging out
- suspension overhall, missing anything
- Quick ?
- cant get my car to idle
- Valve cover and oil pan gasket replacement
- Steeda Adjustable FPR
- any ideas?
- And so it begins 87 gt
- Update
- what sould i do next?
- Will my setup still run right, now??
- Transmission Rebuild kit
- Suspension and Traction Q's
- What do you make of this.
- Center console.
- Huge K-Member Problem
- question on exhaust
- brake lights wont come on?
- Airbag light stays on?
- DASH LIGHTS WORK SOMETIMES
- **** you guys!!!
- air bag light now on
- need new clutch
- 351cleveland 4v lack of power help please
- Idle problems. Not the usual!!
- pressure gauge
- Grinding Noises
- Fuel pressure readings
- Rust in Bad location!! Need help!!
- S/Ced my car oil out dipstick
- 347 Stroker Carbed instead of EFI
- water pump pulley belt issue
- Advice on 5.0s
- clutch pedal has mushy, spongy feel
- some stupid questions
- b/c im lazy
- How the **** do I tighten down my Rockers!!!
- Check Engine Light
- IS THIS A GOOD PRICE?
- W.....T.....F????
- driveshaft to rearend bolt question
- Bad EGR
- cam numbers question.
- Rack and Pinion Replacement Questions...
- new clutch kit stuff whats the quality of this brand? AND LOOK AT THIS T5 :p
- best engine and tranni oil and anti freeze for high performance engines?
- 1.7 rocker question
- 5.0 paxton supercharged Need help!
- Best OTS Camshaft???
- 289 heads
- Air Conditioning
- stock(A9L) vs. Cobra (x3z) computer
- 5.0 swap need wiring help!!!
- Rack & Pinion question.
- best handeling
- tranny and drive shaft question...need help bad!
- 94 gt wont idle right
- just bought a new tfs stage 1 cam and edelbrock intake
- Shocks and Springs?
- bbk tb still whining?
- GT40 Heads
- Pulling motor
- Speedo Cable
- timing on 94 gt
- radiator
- rims with suspension
- question about pushrods
- LOOK!!!!!!!!
- F*****' S*** !!! NOW WHAT ????
- idle waiving on 5.0 aod
- thermoactuator ?
- Turn Signals(which ones)
- quick tire question?
- How hard is it?
- Comparison between my Cam only LS1 and my old Mustang 347
- 5.0 plenum cover removal
- Interesting...
- 5.0 rod strength
- Smog Delete Belt Size
- Shocks/Suspension?
- dazed and confused, need help
- Long or equal headers for stroker?
- Oil in PCV hose
- AOD trans in which models it comes in?
- 88 GT project
- Valve cover breather cap issues!!
- How do I put a picture in my sig.?
- door handle ?
- If I don't get a cam...
- remove sway bar?
- MSD 6A. Confused
- oil fouled plug
- quick and easy question!
- Engine temp
- MOVED: Dyno'd My Stang Finally. Could Not believe it.
- tensioner pulley rattles
- simple wheel n tire question for yall
- exhaust question
- MOVED: convertibles......
- piston to valve ?
- Front End Wheel Bearings?
- Speedo cable ??
- quick timing question...
- best heads for my combo
- TPS adjustment question
- coolant issue
- whats the best?engine swap
- electrical problems still about to give UP!
- Manual rack Convert???
- lower intake manifold options
- Turbo?
- MOVED: Track
- Computer Controlled Compatible???
- Smog Pump Delete
- Need help for 347 stroker??????????
- Timing Cover Option
- MOVED: Couple pics of my car
- would it be possible to run a older style coil?
- how much harder will long tubes be to install?
- differance between my 88 & 95
- cutting out
- Seat Swap
- New to the Fox body world and need some info
- will my crankshaft break?
- 140 mph speedo
- Will these fit?
- nooby help
- Quick Computer question
- overheating problem: NEED HELP
- please help
- Dyno tune questions
- Scary experience! And q's on wiring
- suspension
- Explorer GT40 intake question
- gear help please
- tires on pony rims help
- serpentine belt change
- little orange in antifreeze
- roush control arms
- No start, AGAIN...HELP
- 0-60mph
- 5.0 overheating
- 1 3/4 inch headers?
- Line Loc
- Best head gaskets for supercharged....
- Belt Driven Acessories
- Need help PLEASE!!!!
- hey fellas quick question
- t-stat installation
- Fluid leaking from T-5??
- m/t slick
- maf????
- brakes locked up
- Driveshaft
- MOVED: Just thought you guys should see this...
- Filter
- 1994 5.0 GT Temp/Cooling Issue
- a
- mods with $2000????
- Yet an other rough idle.
- Rear end
- aod question
