View Full Version : 5.0 Mustang
  1. factory tach concern
  2. Reverse lights
  3. Help!!!!
  4. C6 Trans help
  5. selecting my cam
  6. megasquirt
  7. Transmission problems
  8. valve springs for my setup
  9. Turn Signals...
  10. PCV Question
  11. computer adaptation
  12. compression test results
  13. idle problems
  14. do i need injectors?
  15. Mexican 302 Block numbers
  16. 1985 gt
  17. a laundry list of problems! plz help!
  18. 31 spine vs. stock spline.
  19. tire sizes
  20. Will a chip fix this?
  21. Tire size
  22. 95 gt,tracklok rebuild ect.
  23. lifter tap
  24. painted or powdercoated?
  25. Where to get a wiring harness.
  26. SLP LM1S
  27. 92 LX runs strong then dies.....
  28. two hoses, where do they go?
  29. Relay
  30. Plans of Buying an O/R H Pipe
  31. I need fuel advice now!!!!!
  32. sputtering?
  33. rear is toast
  34. pressure plate resurface?
  35. hatchback shocks
  36. ported twisted wedge's vs canfield 195cc heads?
  37. thunderbird supercharger on a 5.0
  38. Fuel pump install issue
  39. oil pressure drop
  40. Which BBK H Pipe?
  41. max hp out of a 351
  42. need help with puttin a 351 in a fox
  43. codes?
  44. Tailshaft play
  45. Oil
  46. correct motorcraft spark plug wires number
  47. AOD 'drives' in Park.
  48. 351W Heads on 302
  49. newbie help please
  50. High speed shakes
  51. SLP Loudmouth on a 5.0?
  52. slipped balancer
  53. Horsepower
  54. Porblem Installing Short-Throw
  55. Brake Master Cylinder
  56. tuning my supercharged 5.0....NEED HELP FAST!
  57. new to forums
  58. what color to paint pony?
  59. kind of a weird, mabye ignorant, question
  60. embarrassing
  61. wheel size???
  62. Gripe---->plz read
  63. clutch??? i think it is going out...
  64. gears?
  65. whats a 89 compression
  66. WooooHoooo!
  67. THANKS GUYS!!!!
  68. can't get timing right
  69. Alignment Shop Grinded Out Mounting Holes on Strut Tower, Good or Bad?
  70. anyone
  71. 92 gt
  72. Hey
  73. T-5 fear
  74. intake manifold problems help please
  75. 92 vs 93?
  76. Which control arms for hop?
  77. Computer Program to Change Fuel Injection Sequence
  78. Fresh Stroker Blowing Head Gaskets!?!?!
  79. what am i doing wrong
  80. Switching Steering columns?
  81. how to install a distributor help plz
  82. ANTI LOCK BRAKE LIGHT ON? HELP!!!
  83. Coil overs for KYB
  84. Help with clutch quadrent!
  85. Best placement for jackstands, t5 rebuild
  86. A/C and smog delete ?
  87. Tire Size Advice
  88. brake fluid
  89. Engine bay pic of sensor location
  90. no power
  91. Springs, shocks struts life span?
  92. alignment?
  93. Roller Retrofit
  94. MAF to TB Size
  95. Input bearing retainer Qs
  96. Vibration figured out...
  97. GT to Cobra Motor Swap, Difficulty??
  98. steering problems
  99. Wheel/Tire Problem
  100. valve cover issues
  101. Mass air question
  102. on start up reves to 1500 then pops?
  103. interesting idle ?
  104. NEW 5.0 Owner with high hopes
  105. 86 gt over heats
  106. what internals i need to run nitrous.
  107. Couple Problems
  108. Ford Motorsport header bolts
  109. suspension questions
  110. trick flow intake
  111. new edelbrock intake installed
  112. tran fluid
  113. airbag light flashes
  114. Dust boot & BBK caster/camber plates
  115. Brake upgrade options 4 lug?
  116. Sounds like belt squeal, clutch problem?
  117. Will my stock block handle these upgrades?
  118. Car died when in park
  119. How to get the steering column out?!?!?
  120. Problems starting....starter?
  121. RPM Problems
  122. shaking?!!?!?!?!
  123. 347 Stroker swap Help!!!
  124. First time installing intake, TB, MAF... advice?
  125. 85 GT rearend
  126. vac line help
  127. Quick hatch help
  128. 2.5' or 3' for a deployed Hubbys, Stang
  129. transmission problem
  130. Help, Removing Tint!
  131. shift light problem
  132. pop noise..again
  133. random starting issue
  134. 2000 mustang gear shifting auto v6
  135. difficulty level, replacing intake man gasket
  136. low fuel light out
  137. installing BOOST gauge
  138. rebuilt engine
  139. 94 mustang cutting out/off
  140. 5 speed fluid change
  141. what do u guys think?
  142. E7TE heads
  143. Dash lights out.
  144. head question
  145. IM PISSED ABOUT MY MOTOR
  146. my fuel meter is broke help plz lol
  147. msd6a ????
  148. Block/other parts, setup
  149. MOVED: lOOKING FOR SOME PARTS
  150. what internals...
  151. 95 driveability problems. HELP PLEASE!!!
  152. edelbrock heads
  153. 351w pistons
  154. take a look at these heads what ya think?
  155. Estimated Gas Mileage
  156. starter grinding
  157. getting things done
  158. Temp guage
  159. clutch for 1990 5.0
  160. Why Prime The Oil Filter
  161. Clutch and Pilot Bearing questions
  162. What is the max bore on a 5.0 cylinders
  163. weird sound coming out of a/c vent
  164. Bassani Side Exit Exhaust?
  165. pistons
  166. struts shocks
  167. Upper intake Plenum??
  168. Ignition question
  169. m/t drag slick
  170. dash noise driving me crazy someone help please
  171. B-cam question
  172. Vibration
  173. sparkplug change on passenger side
  174. Trying to Decide.......
  175. Computer code Disaster
  176. That sucks
  177. MOVED: what do you think car is worth?
  178. trany switch (aod to stick) help
  179. SCT Tuner problem? HElP?
  180. bleeding brakes...
  181. re:how to check compressioon on a 5.0
  182. best, cheap place to buy a built bottom end(302, 306)?
  183. Air Bag light blinking. Need help with code!
  184. California Legal Cat Converters? HELP!
  185. Will this exhaust be overkill?
  186. Meh carpet
  187. Rebuilding a t5
  188. what do i need with dual friction clutch?
  189. firewall adjuster help!!!
  190. Hydraulic slave cylinder conversion t-5, possible? How?
  191. U joint
  192. boss 302?
  193. TOO MUCH OIL NOT SURE
  194. detonation
  195. Engine missing When accelerating!!
  196. Installing Linelock
  197. autometer boost gauge
  198. Do I need to use OD in the 1/4
  199. Hesitation when its running cold, maybe air filter?
  200. new radiator
  201. Throttle body question
  202. Quick Help Please!
  203. Which is better?
  204. new oil pan
  205. can someone tell me what this goes to?
  206. question about AOD in 1/4 mile?
  207. Coolant leak
  208. a/c compressor/clutch problems???
  209. Header options
  210. Opinions on this 351 short block
  211. Horsepower Scenario
  212. EFI To Carb fuel question
  213. Strait Pipe Vs. X/H
  214. general tune up 5.0
  215. Pulling the motor, what should I upgrade/replace?
  216. EFI SETUP ON 347?? WHAT SHOULD I USE?
  217. Rubber trim
  218. For anybody with longtubes
  219. GMS coilover
  220. Rebuild cost$$
  221. smog stuff
  222. New Radiator? Car getting to hot for comfort! Help!
  223. MOVED: What is this Mustang worth
  224. What TB / MAF / Injectors with light bolt ons?
  225. electric fan help yet again
  226. help with maf sensor and injectors
  227. long block
  228. Truck 302 the same as mustang 302?
  229. Idle problem... again
  230. 347 Kit vs 347 Block
  231. AOD with no 3rd and 4th gear
  232. car will start sometimes
  233. re:engine computer help
  234. PLEASE HELP!
  235. NEED HELP how do i take off the wiper arms?
  236. struts help!!!!!!!
  237. length of upper control arms??
  238. 1986 Mustang Hood.
  239. engine idea. hp #
  240. Headlight Help!!
  241. my exhaust!!! help with the cat's
  242. oil recomendation
  243. hatch
  244. Bad oil pressure gauge or sender hopefully?
  245. Overkill?
  246. will 03 cobra rims fit on fox
  247. 8.8 Rear end Qs
  248. Fuel Problem
  249. Oil Pump bad? Bad sending unit?
  250. Stamp on valve covers...
