View Full Version : 5.0 Mustang
  1. Bad oil pressure gauge or sender hopefully?
  2. Overkill?
  3. will 03 cobra rims fit on fox
  4. 8.8 Rear end Qs
  5. Fuel Problem
  6. Oil Pump bad? Bad sending unit?
  7. Stamp on valve covers...
  8. 8.8 Rebuild
  9. Few Questions
  10. Is it difficult to replace wheel studs?
  11. 3.73's......What else.... Bearings, seals etc.
  12. MAF Question?
  13. Life of a 5.0? Miles?
  14. A/C unhooked?
  15. heads/smog!!!
  16. Replacing alternator?
  17. Exhaust
  18. Ceramic clutch
  19. Seat Fitment
  20. my afr 165 wont clear my speed pro piston
  21. T5 to C4 swap
  22. Help with rear end.
  23. high speed vibration
  24. re:stock 302 motor with explorer intake
  25. Early upshifting
  26. AOD Q's
  27. 302 engine overhaul
  28. car wont start
  29. rear windows convertible won't go down
  30. GT 40's
  31. SN95 transmission
  32. MOVED: here are some pics
  33. going from t5 to aod
  34. rear end
  35. What to do with small tear in convertible top...?
  36. Whats a good cam for my set up?
  37. need performance shop?
  38. HB hitting Water pump
  39. Fuel Filter Change
  40. Injector selection
  41. distrubutor
  42. MOVED: post dyno/w 347 and AODE trans!!! compare...
  43. Little AC help needed
  44. spicen up my AODE?
  45. how to remove egr properly
  46. fix for dreaded ashtray cover door ?
  47. DSO 13
  48. over heating problem
  49. Help With New Speedometer Cable
  50. Cam Question
  51. car dying after driving for 5 mins
  52. cam swap on 1995 mustang???????
  53. lets talk nitrous
  54. 5.0 oil and windshield wiper question
  55. oil change
  56. Need advise on T5 rebuild kit --Link--
  57. hypereutectic piston rings?
  58. stock crank
  59. rpm gauge reading incorrect
  60. blinker
  61. battery relocation question
  62. gt40/gt40p
  63. T Tops
  64. popping noise
  65. BBK H-pipe doesnt line up with BBK longtubes
  66. MORE POWER! vs NEW TRANNY?!
  67. brake line help
  68. 4.10 or 4.56 gearing?
  69. Quickie
  70. Quick MAF ?
  71. Best gearing for nitrous or forced induction
  72. help plz any sugestions
  73. need help afr heads install?
  74. Flaming River manual steering Question
  75. Fog light support bar
  76. replaceing fuseable links
  77. MOVED: Attn: Northern New Jersey members
  78. 24LB INJECTORS
  79. misfiring
  80. Rocker Arm movement
  81. clutch ??
  82. Vibration even worse on deceleration
  83. MOVED: I may be getting a shifter for the 5.0
  84. I am thinknig of getting an off road h or x pipe. ?
  85. 95 front wheel bearings.need some info plz
  86. re:5.0 dont start
  87. replacing belt?
  88. what size rockers and pushrods for gt40 heads
  89. Front end conversion and trans conversion
  90. Tremec 3550 equipped SN95. Should I buy?
  91. electric fan
  92. what was here
  93. quick ? need for sure answer fast
  94. Pressure Plate Bolt Torque
  95. Mark VII 5 lug rotor and American Muscle
  96. shift light
  97. PLEASE HELP!
  98. hp #'s ?
  99. driveshaft counterweight?
  100. accessory wire "power when is on position"
  101. pro max module
  102. MOVED: exhaust
  103. Another trans question!
  104. 85 radio
  105. EGR spacer
  106. auto adjusting rockers???
  107. MOVED: How much is this worth?
  108. MOVED: what exhaust
  109. clutch pedal slow coming up
  110. msd problem
  111. spark plug gap
  112. Intake Manifold question?
  113. Thank You El Hombre for Your Base Idle Resest Post
  114. First inexpensive mod
  115. spec stage 1 or centerforce stage 1 clutch?
  116. firing order
  117. can you guys help
  118. Mustang Clubs in san bernardino or Los angeles
  119. Got Headers?
  120. h/c/i questions
  121. probs after charger install
  122. starting problems
  123. AFR HEADS!
  124. starting problem
  125. Installed new suspension now my car is leaning help
  126. Headers!
  127. C4 trouble! Please help!!!
  128. 5.0 emblem question
  129. car will not start need help PLEASE!!
  130. T-5 Fluid change
  131. just for clarification
  132. con rod/piston assembly ?
  133. Opinions on a setup
  134. whiney fuel pump?
  135. MOVED: Exhaust Q's and soundclip req.
  136. HOW MUCH OIL
  137. Clutch fan is loud. I think????????
  138. MOVED: Shifter and lights CHEAP?
  139. ok cats are getting done
  140. balancer removal
  141. MOVED: saleen windshield decal
  142. t5 rebuild manual
  143. quick question
  144. 50 Boyz!!
  145. What to look for before taking it out?
  146. MAF ?
  147. cracked head?
  148. low amps, new battery, new cables
  149. stang runs funny when cold
  150. Any reason to reset the computer...
  151. what weight oil?
  152. 94/95 5.0 bell housing Question
  153. battery check light
  154. Combination Help
  155. When to change Power Steering Fuild
  156. MOVED: Ohio mustangs
  157. gas mileage
  158. Sufficient CFM on Electric Fan for H/C/I
  159. Master Cylinder Question
  160. k-member dilemma
  161. isolators
  162. little shake to the motor
  163. american muscles wheel spacers
  164. torque converter
  165. 1987 Mustang GT
  166. Heads/Cam Opinion????????????????
  167. Longtubes, which to get?
  168. MOVED: just did armrest delete
  169. MOVED: NEW BURNOUT VID!!
  170. HUGE PROBLEM
  171. Explorer TB
  172. Neeed Hellppp!
  173. AFR165 ON A STOCK LOWER
  174. quick ? so i can finish my car
  175. MOVED: Motorvation
  176. moving power steering pump
  177. it never ends..help!!
  178. Mass Air
  179. cant get rear seat out of 92 vert!
  180. 94-95 Computer for a 351
  181. MOVED: wanting Mustang- what do you think
  182. aod to t5 swap
  183. noise in engine
  184. Quick advice question
  185. a9l & a9p
  186. engine rebuild questions
  187. rear seat removal-fox body convertible
  188. HELP! Overheated
  189. Mr. Gasket 5.0 pulley
  190. Air/Fuel Ratio Guage
  191. Confused can you help????
  192. want to build a high comp n/a 331?!?
  193. remove air intake silencer on '90 5.0
  194. sea foam?
  195. Guys with Fuel Cells
  196. Decode my axle ID
  197. New Rims New Vibrations HELP
  198. What is the stock belt size for 94 GT???????
  199. engine rebuild
  200. HELP!! headers!!
  201. E303
  202. E303
  203. AOD Transmission Broke?
  204. electrical issue?
  205. air cleaner
  206. Engine won't stay on
  207. MOVED: what do you think my car will run in the 1/4 mile
  208. K-Member Help
  209. oil pressure question
  210. just performed koeo and koer tests need answers
  211. Trick Flow Kit install, now problems. TwEECer?
  212. Help me with my intake. Yes I do know there are a ton of these threads
  213. Did the 140 swap on my 86
  214. MOVED: Calling All verts..
  215. Starting issues!! Help :-(
  216. Will aod trannys from other cars work in our 5.0's?
  217. Did i buy the wrong X pipe?
  218. Whats A Good Range
  219. 95' v-6 to 5.0 motor swap questions
  220. longtube question
  221. electrical help!!!!
  222. C&L Meter Question
  223. speedometer reading is wrong?
  224. 347 stroker motor any good?
  225. Smell after clutch install
  226. Replacing inner tie rod
  227. 1995 fuse diagram
  228. New fox project plans...
  229. Need advice on injectors......quick
  230. Bosch 02 sensor for my 66
  231. can rear end weight/pad be removed?
  232. colant leak
  233. Differential going??????
  234. Need help!!
  235. C4 tranny ?
  236. Water in oil and driving :(
  237. 3.55 or 3.73
  238. experienced help
  239. blew out my rear main seal
  240. need some help
  241. head gaskets?
  242. Spun A Bearing
  243. finally picked up some heads...
  244. HELP! ASAP! REAR TRANNY SEAL!!!
  245. vacum leaks
  246. timing question
  247. friend says 347 is too big on a stock block?
  248. need help with performer rpm heads
  249. electric fan
  250. might happen
