- blew out my rear main seal
- need some help
- head gaskets?
- Spun A Bearing
- finally picked up some heads...
- HELP! ASAP! REAR TRANNY SEAL!!!
- vacum leaks
- timing question
- friend says 347 is too big on a stock block?
- need help with performer rpm heads
- electric fan
- might happen
- MOVED: tips anyone?
- buildin a 331
- Mass air sensor?
- 347 power gain?
- MOVED: I have a 88 mustang GT that i want to part out
- buying a 347 need help with head choice?
- MSD coil? stalling problem?
- Headlight Assembly Removal
- 89 lx Hatch & 90 LX Vert Door Glass the same?
- MOVED: buyer tips for fox gt vert
- GT40 Thunderbird
- a/c elimination
- subframe
- ignition
- can i just use 30lbers?
- Line lock??
- Flowmaster Hanger Keepers
- best block
- torque converter advise
- Transmission Cooler
- starting problem
- gears
- trickflow question
- loud squealing coming from flywheel/bellhousing area
- 5.0 to 351 windsor
- speedometer
- Recipie for a 350-375hp 5.0?
- MOVED: Off topic taillight question
- MOVED: shipping my 95 GT
- Floor Pan Replacement
- Need help car won't idle right!
- MOVED: subframe connectors
- Shift kits?
- maf ?
- Need help with water pump...
- upgrade ideas...
- MASS AIR FLOW problems any ideas
- Fuel guage stuck past full...
- how to hook up the elecric cooling fan to a on/off toggle switch?
- wont start when warm
- Thermostat in stock 86GT
- flat tops
- dome light
- blacking out tailights...
- SN-95 upper body frame specs
- TRANSGO AOD HP SHIFT KIT
- wont start when at runing temp
- Performance ignition box
- MOVED: which cam?
- MOVED: rims on a whitte 94 gt vert
- Some H/C/I questions
- Clutch Advice needed
- QUICK RESPONSE NEEDED!!!
- what next? (upgrade fuel system)
- clutch safety switch?
- coolant leak, somewhere
- exhaust leak!!
- Power loss? or how its is?
- Throttle giving out between 2 to 2.5 rpms
- MOVED: who has a 4 inch cowl hood? pictures?
- speed density
- MOVED: Racing stripes?
- MOVED: paint!
- hose from tb to valve cover
- Help . . .
- how tall of a valve cover can i use?
- EEC question
- did my tune up and nothing still!
- Planning engine build soon!
- Cubic Inches toL iters
- fuel line issues
- 94 GT Steering Rack - A few ?'s RE: Replacment
- spark plug reading
- idle and driving problems!!!! please help!!!!
- shocks/struts
- voltage question and FPR question
- rev limiter
- MSD 6AL
- fuse box
- readable directions
- exhaust/brake line clearance on '79
- 'nothing works' problems
- Car feels sluggish
- engine tarnish/deterioration
- tie rod question
- WTF! WHAT FUSE IS BLOOWING OUT WHAT FUSE
- S/C fuel mileage
- PCV valve
- Intermittant miss
- What to Spray on Vac Leak
- stock control arm difference??
- wiring gauges
- Belt Size
- ac control???
- What are these holeS??????
- fuel gauge install?
- Brake/clutch pedal removal
- Hesitation/CEL
- 550+ On Nitrous
- Are all 351w from 93-95 Roller motors
- umm...i hope yall can help...
- 302 rebuilt hi
- auto meter tach install
- AMSOIL ATF
- what belt do i need to bipass smog pump
- E303
- I found a possible cause of my vibration...need help.
- flat top pistons
- Putting Front end together!
- MOVED: Best Websites?
- Lower control arms for 95 GT
- King cobra clutch?
- 2 inch drop too much how can I get a 1/2 inch back
- Cai or Air filter
- 1988 gt wont start when it is warmed up help!
- Speedo Gear ----> New Tranny???
- subframe connecting question
- sn95 spindles on fox/wheels
- gt40e question
- Taurus Fan Wiring question
- Whats wrong with it?
- Open trunk from inside?
- HELP!
- Gearbox woes
- GT40 intake and stock heads
- installing rockers
- removed rocker arms with out bumping motor
- Injector help
- Fog Lights wiring
- 2.73 to 4.10 speedo help
- Flowmasters New Fit?
- BEnT PUSHRODS TICK??
- whats the difference
- What Intake To Get???
- Best transmission
- here we go again
- PIN HOLE LEAK
- Mass air conversion kit
- Air Silencer
- Removing stock A-Arm bushings
- any staten island members
- quadrant?
- stock fox vc's, clear rr's?
- Trick Flow A/C Detele?
- new injectors cheep.
- who all has the edelbrock performer rpm 2 intake?
- Bronco?
- Tremec trans tag
- Nitrous Window Switch
- MOVED: just a suggestion!
- rods on stock 5.0?
- another clutch question
- running serpentine belt
- how do i know if i have rear end gears
- Intake question, kind of.....
- BRAKE ISSUE
- new acquired 5.0 maintance questions
- 351W/ GT40 heads on a 5.0
- Please Ignore Wrong forum
- 86 GT gauges
- bad bad mileage update
- got noticible gains
- 99 5.0 motor mount question
- ??? about harmonic balancer
- Input shaft question.
- oil all over spark plug .. and engine tick
- Will installing 24 pound injectors help
- havin problems installing new headlights???
- 351? or rebuild?
- Interior problems...
- Mass Air Need help!!!!!!
- MSD box help
- quick question about fuel injector
- injectors?
- Drive shaft for C5 aod??
- 93 LX wont start no trans???
- idle probleme
- MOVED: flowmaster
- fuel pump not priming
- act sensor
- Fuel pump question
- engine question
- 1992 mustang special advise
- intake leak
- heater core
- block question.
- belt on a 94-95 stang GT
- Clutch question
- New Mustang Owner and some questions
- Engine Revs itself?
- Trans problem
- Water pump question
- 1700rpm stumble!....help
- Distributor coil
- need some help plz
- installed clutch.Now have loud squeaking
- can a spark plug tick
- How much power?
- Rear Suspansion Panhard bar?
- What do you guys think of this combo??
- Radiator questions
- belt
- new to the ponys
- C4 shifter
- question about starter and air comp/impact
- Confirm 8.8"
- battey/allternator
- 87 GT project.. Need suggestions..
- Flat Tops
- Need Advice
- Temp guage out of order?
- still tickin......WTF!?!?!?
- 331 install prep, emissions question
- Gauges are going crazy!!
- Engine Grinding?
- Tranny swap
- OMG water leak help
- how to clean T5 parts for prep?
- headerleak
- Prochamber question HELP!
- Putting together my LX
- To all chicago and Il 5.0 members
- Intake For Sale
- belt tensioner
- looking for v-1 vortech kit?
- Rear End
- MOVED: C4 price????
- MOVED: supercharger or turbo
- 5 lug & rear disc conversion question..
- powersteering pressure line
- Not running
- auto tranny question
- Temp Problem Please Help!
- Backspacing for 17x8 Centerline Scorpions on Stock 1993 GT
- oil pan gasket
- carb vs. fuel inj
