View Full Version : 5.0 Mustang
  1. New to the 5.0 perf. world.....Looking to build some power
  2. whats causing my stang to catch the grass on fire?
  3. edelbrock performers rpm's ???
  4. Replacing Head gasket question. Help!
  5. heads/headers
  6. Another h pipe question
  7. Pushrod length ????
  8. Rear Gear ?
  9. Clutch Problems
  10. guide plate problems.
  11. Firing Order
  12. surging problem
  13. ported e7's
  14. new Idea
  15. steering colomn
  16. project stang :D
  17. injector question
  18. MOVED: Craigslist 347 good deal?
  19. MOVED: im looking for some good springs for a good price
  20. front end noise on a 94 gt
  21. New tubular and car wont stay running!
  22. clutch and tranny question
  23. MAF problems
  24. 90 gt oil leak
  25. What Can I pull a T-5 from?
  26. brakes upgrade
  27. axle splines?
  28. Tachometer screwy
  29. 94-95 AODE
  30. wanting 2 buy motor thats been siting should i
  31. Muffler choice?
  32. Need some direction on picking non-adjustable struts/shocks
  33. 331 stroker and twisted wedge?
  34. Cold Air Intake for 95 mustang...Which One???
  35. pretty sure clutch is fried just need someone to confirm it?
  36. cam shaft upgrade!!?
  37. What causes a miss at same rpm? *VIDEO*
  38. suspension problem fox body
  39. Fuel injector?
  40. Strange timing problem
  41. nabigator motor in a fox???
  42. Flywheel help!!
  43. help me with some info on this....PICS..
  44. BBK SI INTAKE
  45. BRONCE 302
  46. question, will take 2 seconds
  47. LONG TUBE HEADERS
  48. drag tires
  49. electric choke adjustments....
  50. anyone ever run a 5 gas machine?
  51. 5 lug Disk Brake rear end ON A FOX?
  52. clutch cable problems
  53. transmission help asap
  54. torque spec
  55. WTF UPDATE on Idle/TPS sensor/butterfly idle screw HELP
  56. REAR VIEW MIRROR DETACHMENT
  57. FALLS FLAT AFTER 5K
  58. Gas smell problem
  59. KOER code 66 & 98
  60. Stock Forged Pistons 4 the 93 cobra
  61. For a SN95 351W C4's????
  62. Cobra
  63. altenator/starter questions....
  64. wheels 5 or 4 lug
  65. idle control....again Rough Idle
  66. Roller Rockers
  67. Car won't start after installing headers
  68. Speaker Upgrade Fox
  69. 351W Heads
  70. nitto nt555r
  71. fuel pressure
  72. problem with my lights
  73. stock LX pipes and GT pipes?and other exhaust questions
  74. HELP WITH ENGINE SWAP PLEASE
  75. Lakewood Traction action lift bars
  76. are these traction bars even for a fox? and another susp. question.
  77. which upgrade?
  78. HELP...with header bolts
  79. AOD Troubles
  80. is this.. really that slow???
  81. Help with my pwr windows/doors
  82. Cyl Heads
  83. distributor
  84. ENGINE STALL
  85. 86Mustang Tranny and motor the same as a 87?
  86. Mustang won't start
  87. BRAKE UPGRADE
  88. floor pan install
  89. Cobra Intake
  90. cars back togehter....but got some bugs?
  91. How did this happen?
  92. For those that installed aftermarket dash gauges i need help asap *****
  93. god do i hate urathane bushings need some help!
  94. 5.0 MAF question please fellow mustangers help
  95. wondow molding question and strut tower brace?
  96. throttle body
  97. Help me make a list for t-top conversion on a fox mustang.
  98. Wire help
  99. Where can I find...
  100. cross drilled rotors
  101. How hard is it to replace the Brake Booster?
  102. LTs KILLING low end
  103. KB pistons
  104. Forged Internal help..
  105. 347 stroker
  106. Need Help On Engine Overhaul
  107. replacing camshaft
  108. Dash Swap
  109. 351W Setup
  110. ARP head studs...which ones?
  111. ? about alternator tensioning rod
  112. buildin 306? questions
  113. hood bolts...
  114. Noisey Reman PS pump
  115. IS THIS POSSIBLE?
  116. MOVED: Seats
  117. single turbo kit help
  118. engine rebuild ?
  119. 94 AODE help
  120. subframe connecters
  121. Cooling Problems
  122. making my auto into a 5speed
  123. Need help to identify this?
  124. need to relieve weight
  125. bump steer kit.
  126. Car won't start!
  127. new heads!!
  128. MOVED: Exhuast opinion help!?!?!?!?!?!?!
  129. Electric Fan
  130. Cobra intake/GT40 tubular
  131. tuning
  132. bad idle and smoke
  133. h/c/i question
  134. Can't get 'er into gear! - help?
  135. Question about Cam hp
  136. one last issue...please help
  137. 1984 Mustang
  138. 93 thunderbird 5.0 question/??
  139. How much weight did we get rid of?
  140. did i just make a mistake?
  141. Nitrous Questions
  142. gears
  143. clutch goes pop?
  144. fuel systems
  145. SMOG gear and Trouble code question
  146. holley systemax
  147. 94 GT heavy engine mods, stock everywhere else. What upgrades first?
  148. '72 302 Rebuild
  149. MOVED: Estimated power
  150. turbo 5.0 tips
  151. eaton rear end
  152. Fuel Inj to Carb
  153. Vortech V1 S-Trim Kit. Any opinions?
  154. Electrical problem?
  155. ARP headbolt part number...
  156. FIXED....new question arrises though...
  157. BBK clutch cable
  158. Hey carb guys
  159. Hoods
  160. MAF suggestion
  161. Idle problem
  162. MOVED: insurance ?
  163. MOVED: new 5.0 owner...
  164. manual swap help
  165. Diablo chip help
  166. for those thinking of purchasing patriot heads...
  167. converting a 5-speed to an auto
  168. schrader guage
  169. oil issues
  170. Timing problems
  171. MOVED: Flowmaster VS Magnaflow
  172. 94 cobra upper intake manifold gasket?
  173. Rocker Arm shim Q.
  174. Stock heads Q.
  175. cam..
  176. more electrical probs. need help
  177. 93 gt pricing
  178. duel tank with F150 gas tank swich, just a thought
  179. Door window molding
  180. Ordered more parts still need Vacumm info
  181. where can i get this?
  182. is it possible?
  183. Water Pump Bolts ??
  184. Thermo Housing Leaking??
  185. Thermo Housing Leaking??
  186. proffesional products intake? good or not
  187. COOLANT LEAK FIRST WINTER STARTUP.HELP!
  188. lowering my stang
  189. Leather Seats 87 Mustang GT T-top
  190. rebuilding 302. help?
  191. 24# maf with 19# injectors
  192. brakes general
  193. Quick brakes question
  194. MOVED: Want input from ALL mustang enthusiests...
  195. These rotors
  196. exhaust under axles
  197. E303 cam in stock motor
  198. Mustang won't start....
  199. AOD T-5 Speedometer gear same?
  200. Gasket sets?
  201. question?
  202. mustang seats ??
  203. rust in block
  204. HELP-94 GT Vert won't start
  205. Exhuast
  206. surging idle... yes ive done searches...
  207. Car smoking HELP
  208. slick size
  209. Quick 5.0 improvements
  210. fuel pump powerless
  211. SN95 questions
  212. head gasket ?
  213. 68stang for 88stang
  214. internals replacements for stock 302
  215. MOVED: how much could i get for my stang???
  216. clutch is slippin i think?
  217. should i?
  218. Can you drill through fiberglass hood?
  219. axles?
  220. Park Does NOT Mean Roll **update**
  221. What kind of power would this combo make?
  222. hypertech power module
  223. oil pump shaft
  224. AOD to T5 swap (wire question)
  225. timming question
  226. MOVED: I got her
  227. MOVED: Whats this car worh 88 gt conv.
  228. MOVED: 351 swap in progress
  229. I need info please...yes I am a neube
  230. swapping carb float bowls
  231. Painting Engine Parts
  232. AOD shifts like my grandma
  233. misfire?
  234. MOVED: REPAINT FINISHED! Pics of my Mustang
  235. Tire Pressure 245/45/17
  236. heatercore
  237. GT40 Part Numbers
  238. procaharger with AtoA intercooler
  239. egr drama
  240. alternator problem
  241. Idle Problem
  242. tremec trans
  243. Smooth Engine Compartment
  244. EGR Delete
  245. gt40 heads
  246. just lost here
  247. Which March Belt Rod for 302 and what belt? Help
  248. best cam to run
  249. Exhaust help
  250. Better rear axles???
