View Full Version : 5.0 Mustang
  1. how exactly do you build a 302 into a 306?
  2. fuel issue
  3. FenderWall Selenoid Question
  4. AC on but No air.
  5. Gauge Lights
  6. can i change oil pan gasket without removing engine?
  7. crazy headlights, need help
  8. CONVERT TOP AND BLOWER MOTOR BOTH LOOSE POWER
  9. mustang gauge cluster
  10. which spark plugs?
  11. front suspension
  12. Aftermarket Brakes
  13. Ford's with 8.8" rear end.
  14. 110K plus on stock suspension
  15. just got tax returns need suggestions
  16. Next mod
  17. Pilot Bearing During Clutch Swap
  18. oil question ?
  19. MOVED: Where To Buy Pony Wheels?
  20. Fog Light Fix - Easy As Pie
  21. Strange stalling issue, Please Help!
  22. cobra vs gt40
  23. replacing my heating core
  24. will my cobra intake match up to afr heads?
  25. Found HEAD leak...Need help
  26. fuel injectors
  27. a/c cooler
  28. Nitrous engine build
  29. MOVED: Selling 83 GT convertable, have some ?'s
  30. 302 motor swap
  31. what oil for motor break in...
  32. 1994 mustang gt door question.
  33. Novi owners
  34. power adder????
  35. X or H
  36. MOVED: good car?
  37. 5.0 electric cooling fan
  38. MOVED: car alarm suggestions.
  39. help with braided lines
  40. Need help, what is this, its a vac line, where does it go?
  41. Shifter Question.
  42. Transmission problems...
  43. My car is running really rich, solutions?
  44. HELP!! What do I need for a 400 mile trip?
  45. Power Steering Pressure Hose Blowoff!?!
  46. 5.0 back on the road!
  47. alternator questions
  48. 1 more POS problem
  49. My car's a POS.
  50. computer question
  51. MOVED: FAVORITE FOX BODY
  52. MOVED: Check out my new wheels
  53. HELP CAR WONT START
  54. scorpian 1.6's
  55. C&L 76MM MAF
  56. HOW TO REMOVE 5.0 WITHOUT TRANS?
  57. do they sell t-top kits for a 93 mustang gt?
  58. Battery cutoff switch
  59. New motorcrafte distributor and now car wont start!!!
  60. Is this a good nitrous kit?
  61. ? on AFR heads
  62. New heads..what else?
  63. MOVED: Kenne Bell Videos Anyone?
  64. X pipe or H pipe.. What makes better power
  65. MOVED: HID Light conversion on a Fox??
  66. shaker hood
  67. stock gt40 valve train w/ trickflow stage 1 cam?
  68. any advice?????
  69. spark plugs on GT40 heads ?
  70. need to prime oil pump...
  71. Help Turbos!!
  72. MOVED: What should I get?
  73. f303 with stock pistons?
  74. rocker rail?
  75. quick smog ?
  76. Squeeeekkkyyyy ?
  77. manual swap?
  78. Line lock/Roll Control
  79. Cobra intake, difference between original and FMS?
  80. Any info on Ford Roush 302 crate motor?
  81. Looking for my old red '91 5.0
  82. MOVED: Kinda new here.. what estimated horse and time should I have?
  83. gt40 heads
  84. need help what heads should i put on my 347
  85. Energy or Prothane (Spring Isolators)
  86. NEW MAF on the market?????
  87. timing question
  88. Cluster Question
  89. my 86 mustang gt wont start
  90. difference between 1983 and 87-93 engines.
  91. New heads assembley.
  92. MOVED: i can get an 85gt with t-tops for $350
  93. MOVED: am i the only one that has a love/hate relationship with my mustang?
  94. engine rebuild information
  95. what tire size?
  96. CONVERTIBLE TOP REPLACEMENT
  97. MOVED: narrowed my head choice down to 2 which ones u prefer?
  98. Summit brand headers? Long Tubes
  99. 5.0's
  100. need a stock crank pulley for a 94 Gt
  101. am i lookin at any huge power gains from an aluminum driveshaft?
  102. just starting
  103. Scat Rotating Assemblies
  104. HELP, car will not start
  105. few 347 questions
  106. compression ratio?
  107. i think my wiper motor just took a crap?
  108. Carb spacer
  109. important lower control arm question
  110. WARNING InDiCaToRs!!!
  111. modular intake
  112. quick simple question...
  113. GT-40 BOX InTaKeS
  114. Electric fan HELP!!!
  115. 347 setup
  116. Looking to confirm Tranny issue
  117. T5 ?'s, for those who have had their tailshaft housing off-
  118. holley fuel pump mounting
  119. summit bottem end
  120. rear main seal
  121. MAF ECU questions
  122. Pulling enigne to swap trans.
  123. EEC-V Programming HELP!
  124. MOVED: New to this 5.0 business
  125. question
  126. some suspension questions...
  127. crane rocker-identify?
  128. another battery problem..HELP PLEASE!
  129. performance rebuild question
  130. MOVED: zex nitrous kit for $250, good deal?
  131. exhaust question
  132. Strange starting problem?
  133. Probable Error in a 'Setting the TPS' thread
  134. aftermarket car alarm
  135. Warning lights not working?
  136. which would b a better option
  137. holley heads
  138. problem with oil light.
  139. power drain...
  140. passing Ca. smog/which exhaust?
  141. OBDI Now I get it!!!
  142. good intake mani yes/no!
  143. ??? on 84 5.0
  144. hatch for my 88
  145. OBDII Explained
  146. 17x9 up front?
  147. Heads compatible w/ pistons?
  148. bumpsteer ?
  149. 5.0 Toggle Switch , CONTROLS!
  150. H/C/I lookin for 300rwhp
  151. bbk smog tube and thermactor plug problems
  152. Fuel Pressure Gauge
  153. Nitrous help?
  154. edelbrock performer heads?
  155. is the Trickflow top end kit as good as it adverise
  156. tps helpp
  157. manual steering or power steering?
  158. 331 Build Low HP #'s
  159. Subframe Connectors
  160. need some opinions on fuel pressure.
  161. Battery Still Draining?!?
  162. 92 mustang rebuild
  163. Fuel Pressure Regulator
  164. 73mm Single Piston Caliper Question
  165. idle
  166. My car sucks... here's the reason
  167. will these springs lower my car too?
  168. drum brakes
  169. need help! blown rear
  170. BBK Header Gaskets...good or bad?
  171. ALTERNATER LEAD QUESTION
  172. manual steering options
  173. Wiring Harness Question
  174. What cam from ebay quick...!
  175. Dash lights not working
  176. lookin for decent tq... lets talk boost...
  177. can anyone?
  178. Distributer 180 out?
  179. NEED HELP!!!!!
  180. why is it that i can find twin turbo kits cheaper than a single turbo?
  181. computer and harness
  182. whats better? lower lift bars or aftermarket lower control arms?
  183. need idea on chip
  184. questions about my headlight wiring
  185. tps on 95
  186. CAM Shim Question
  187. rebuild kit
  188. Trunk Realse Button Help!!
  189. 87 gt mt stock ring and pinion ratio
  190. dumb ass question but need answer!
  191. Need Some Help
  192. Puttin in power steering?
  193. how do i change out the P.I.P.????
  194. sn95 t-5
  195. Resonator Install
  196. MOVED: 18x10 rear on a fox?
  197. nitrous
  198. porting
  199. 24 pounds injectors question
  200. Performance chip?
  201. How can i gain Cheap horsepower?
  202. Shifting problems
  203. GT40 Exhaust ports-Header ports Question
  204. Can anyone help me!!
  205. Truetrac or Eaton Posi
  206. long tubes on an sn95
  207. ?s about MAF
  208. are gt40 heads reversible?
  209. aluminum radiator question
  210. MOVED: what drag radials to use?
  211. head stud and girld questions
  212. MOVED: The mustang is no more..
  213. c4 with hci setup?
  214. are lower lift bars just supposed to replace lower control arms?
  215. question about the two pipes running along my lower manifold
  216. Summit Racing Ignition
  217. Gaining 60 hp's
  218. A wierd sounds and vibrations
  219. Overflow cans
  220. installed my lower control arms today now its squeaking?!
  221. Calling all Supercharger experts.
  222. steering wheel parts
  223. F303 cam with gt-40 heads and intake
  224. high 12's low 13's
  225. header fitment
  226. Exhaust Opinions...
  227. intake swap, questions
  228. Leaking Coolant
  229. how far can i lower my car before i need camber plates?
  230. Q's/opinions on build
  231. Underdrive pulley Rubbing
  232. 5.0 internal geometry #2
  233. Cats for emmisions ???
  234. clutch adjustments
  235. carb CAI
  236. jegs Max air box?
  237. mustang almost ready to come out of storage
  238. Bad idle
  239. Short throw shifter
  240. question about MAP sensor
  241. Removing Antenna Base from Fender
  242. Hook Up Tach......PLEASE LOOK
  243. Big Problems keeping my car running.
  244. FPR, Which one?
  245. Tire Size and Speedo Accuracy??
  246. 80mm MAF on 94GT
  247. APR bolt kits
  248. Spring crossover question
  249. exaust pipe sizing
  250. blocking off the riser?
