- 347 vs 351. Patience/Assistance Requested.
- 5.0 identification questions/help..
- Got a problem...
- help with valvetrain set up, **pics inside**
- stage two idle problem
- Help with R & P replacement
- Need a quick answer on Trick Flow Twisted Wedge heads
- Budget options for e-fans
- Been Gone for awhile,butnow I am back
- Where can I get one of these?
- 17x9 Cobra R's hitting strut ?
- starting very hard, cannot find problem
- question on heads
- powerdyne blower
- Vibration Damper
- Fox Body Rear Spring Length
- Questions of T-Top mustangs
- what gears?
- Exhaust/ Back pressure question
- Cold idle surge, gone when @ operating temp
- low sensor alerts
- auto trans ?
- Attempting Diagnosis on Shifting Issue
- Need Help Please
- weird fan problem
- torque specs and sequence for heads?
- idle problems!!! help
- Trouble with 1988 5.0 GT, Gas and Oil
- T5 3-4 Slider question
- Advice on 90 lx 5L
- Advice on engine rebuild
- shaking after 75.
- New to the game
- 1984 mustang gt
- Long Rod 302
- weird power stearing mount?!?!
- Timing help...
- Gears with 24inch tires.
- unusual AOD issue
- motors tired
- Adjust belt tensioner?
- rear disc 5 lug conversion questions
- Clutch Cable Help
- Tire Wear...Quad Shock??
- H/C/I
- open end lug nut's for OEM rim's?!
- 347 HEATING UP
- Need help with dieing then no start
- start up and prolonged idleing problem
- lager capacity fuel tank
- tire problem
- the update on my 302>i still need help
- Any 1995 Mustang GT-S experts out there?
- GT-40 vs. GT-40P???
- Another what next question
- waterpump change?
- crank NO SPARK!!!
- Overpriced 91 GT?
- overheating
- Need some help/advice
- what are good highs for 92
- Fluttering RPMs while accelerating, and backfiring after 4k
- best power adder
- where can i find this? im desprate
- next step for performance
- snapped cluctch cable!! is this cluch piece included?
- Cats or no cats
- how to?
- replace remote key fob?
- door hinge & bushing repair options
- Another Elect Waterpump question
- will they match up
- Couple Questions I couldn't solve with Search..
- jack point
- fuel pump question
- best way to line up rack with column/steering wheel?
- headlight cleaning
- Who has installed anti-roll bar's
- Heads and Cam??
- Removing Fuel lines help please
- bassani x pipe ?? looks like a fake??
- ??? quick question
- Oil pan
- 4" X pipe for a 92 Fox
- stock mass air sensor with bbk cold air??
- needing some knowledge
- check this out!!!!
- major overhaul
- Rear end noise?
- intermittent white smoke?
- 160 t-stat??
- Why is my car shaking?
- Where can I find an e-brake cable
- 94 5.0 Flowmaster Super Flow 44 or Orig. 40?
- Will This Rear End Bolt Up and Work?
- Systemax lower with Ford logal in casting??
- stupid clutch cable ?
- question on blower
- Aerospace Brake inztallation
- how much???
- wire harness
- little or no brakes on 88 5.0
- how do i- 98GT to 5.0 swap???
- hey im new here and i need some help
- help no start 87 5.0
- How hot should she be running?
- TS torque converter with AOD
- Fighting to Stay Alive.
- injector size vs. rear wheel horsepower question
- mod for new use: GT fog light switch, Convert top switch
- Engine HELP PLEASE!!!
- oil pump relief valve
- tranny problems
- i didnt read the rules at all
- Hey Guys! Looking to buy a short throw shifter?
- suspension advise for 95 GT
- oil pressure issue on new motor
- egr smog delete questions
- Cleaning an intake manifold
- header bolt size?
- where does this vacume hose go
- Coolant rail leak!?
- WTF boys?!?!?!
- Coolant Boiling, But Only When The Engine Is Off???
- throttle body
- Power loss, hesitatation, sputter, chug
- TFI MODULE?
- Tuning with bigger injectors
- What do you think of these roller rockers
- Rearend HELP
- headlights/taillights
- trans brake question
- electrical power problem?
- 88 Mustang GT Question
- wont pass smog
- Sputters after warming up
- Distributor housing
- Excessive Fuel Consumption Help!!!!
- fried piston ring at the track =(
- 1994 Mustang GT questions
- lowering
- And boom went the expansion tank!
- *HELP* Bad Vibration
- 2 1/2" exhaust reducers
- Equal Length vs Unequal Length Headers
- Starter problem!..
- a/c through defrosters only. need to know where vac line goes
- Idle problem. Just a question.
- Manual Trans Issue
- New Member Needs some Help Please?
- Alternator Went Out, Help With An Upgrade?
- EFI TO CARB CONVERSION???
- 88 vert lx
- Power/Shift problem
- plzz help
- What's this part
- 3g Help....amp light.
- advice about suspension
- First 5.0 Engine dropin HELP
- Alternator Not Charging Battery
- Fuse box diagram? HELP! Turn signals wont work!
- stall/skip @ 3-4k rpm???
- SMOKE
- 86 stang idle prob...tried everything
- White smoke related to short?
- WEIRD AC problem...
- Got her started...need some help
- Core Support
- Car Turns Over, Wont Start
- Hatch Release add-on
- Edelbrock victor jr intake
- shifter shake
- DAMN!!.. flywheel bolt overtighten!!
- Ignition Problems Please Help
- Quick Head Question
- need a 17 inch cobra rim
- T-5 Fluid
- moded 5.0 surging/ jerking
- PEDAL ASSEMBLY QUESTION
- Bad EGR?
- Is it easy installing a t-5 trans? What needs to be done?
- Battery Relocation
- missing oil pan bolt
- Aftermarket Front Suspension Adjustment Question...
- help with tire size. about to order some.
- Cylinder Head Temp/Motor Temp Question?
- Where to buy just an upper Systemax 2
- ***HELP!!! problems with 302 oil shafts twisting!!!***
- surging oil pressure and high hydrocarbons
- Summit brand rear control arms
- Stupid c4 transmission question
- help - loss of all throttle at anything over idle.
- turbine tires
- Installing stock rocker arms
- Need Help, Grinding!
- fuel pump trouble
- Will this mustang pass emissions.
- narrow band help
- narrow band help
- starting my 95 gt project
- oil pan gasket
- Bumping Timing Question
- 5.0 trouble!!!
- MM Roll Bar, Installed!
- Convertible Top goes down but not up; WTF??!!
- what electric fan setup for my car
- Did I blow my motor??? :-(
- Gt-40 heads or better
- Header bolts
- runs like crap after cobra intake install
- Figuring out the puzzle
- What backspace and offset?
- 94 gt rear end sway bar question
- Upper intake manifold
- Please help, My car won't pass smog in California!!!!
- Need Pics of 94-98 Mustang Stripes!
- no spark from coil
- power distribution box
- Ford Mustang 302 Oilpan
- So Im getting gears installed and have a quick Q
- 1995 Convertible Seat compatibility
- Wont start sometimes
- T-5?? OR Overhauled AOD??
- Performance issue
- New to the automotive game...fox body 5.0
- Want more git up and GO!!
- Where does this rubber thing go for the radiator support
- trans going out?
- Stalling 1991 Mustang
- Hard to Get into 1st Gear
- starter problems
- t5 swap brake problems
- door wont open
- help after H/C/I
- mass air conversion
- Cloud if smoke from tail pipe when I floor my car
- 3.55's are in,What tire should I run?
- map light size?
- scraping noise when I accelerate
- Power valve block off???
- Knock Issue-Flexplate?
- Reverse grinding hlp plz.
- Stainless Steel Headers
- Tie rod replacement
- Cable route any tips: Battery Relocation to trunk
- can someone tell me what goes here?
- 351w front sump oil pan clearance?
- loud sqeeling noise then -dead Help plz
- Charging Issue in my '89 GT 5.0
- wiring question reverse glow guages*pics*
