View Full Version : 5.0 Mustang
  1. TFS streetburner intake clearance?
  2. crankin up fuel psi..
  3. Can't figure it out...
  4. 90 Notch AOD
  5. trying to find a leak
  6. My 5.0 accelerates it self when i turn it on. What is wrong??
  7. Ideas on tucking and hiding wiring
  8. Tranny grinds into reverse. Help?
  9. notched ideas
  10. since there's alot of tranny swap questions...
  11. New carpet ?
  12. Decisions HELP Windsor or Boss 302
  13. MOVED: Parting out 1994 Cobra. Good, new engine!
  14. Building a stronger Borg Warner?
  15. emissions
  16. notching the pistons?
  17. rebuilding the heads?
  18. NO SPARK?!?!
  19. Wiring Harnesses Interchange??
  20. Charcoal cannister purge solenoid and idle
  21. MOVED: good deal on gt40's
  22. GT40 Charcoal Cannister Line Input / Idle Issue
  23. smog delete
  24. MOVED: 10 Second Mustang For $1000
  25. What year is my engine?
  26. Brakes
  27. F/S 79-93 Mustang Saleen Wing Hatch! CHEAP!!!
  28. Trick FLow or Cobra Intake
  29. 5 Speed Identification? With Pics!
  30. Junkyard Hunting for Gt-40's
  31. Are BBK lowering springs staggered?
  32. Ram Air Vs Cold air
  33. How do I tell if I have the H.O or not?
  34. ULTIMATE EEC AND TROUBLE SHOOTING SITES.
  35. MOVED: What is the weight of a 1987 Mustang GT Vert???
  36. Need some opinions on a Tranny swap on a '90 Fox
  37. engine knock
  38. 4 lug rear disc
  39. headlight
  40. Seat Belts
  41. Tranny noise
  42. Another tranny problem.
  43. eibach springs question
  44. MOVED: stupid Question
  45. 89 5.0 motor build ??s
  46. bolt stuck
  47. Oil pump question
  48. control arms
  49. 94 Valve covers
  50. MOVED: Does anyone have....
  51. plugging air injection holes
  52. O2 Sensors on 1990 5.0
  53. MSD Problems Still
  54. INJECTORS NOT WORKING HELP!!!!!
  55. got a lean miss-fire
  56. Eibach Drag launch springs....
  57. Car runs bad
  58. 70'S 306 SHORTBLOCK
  59. Ford Crate Engine
  60. Need some suspension Help
  61. Looking to do a full service
  62. timing for dummies
  63. need help choosing lca
  64. '88 GT stock block capability
  65. intake
  66. how long do you have to wait
  67. c-4 swap need help fast !!!!
  68. cam
  69. 03 GT Axles in a 94 GT?
  70. Tailpipes, I need some help
  71. performance ? just for laughs
  72. Are Brodix ST 5.0 Cylinder Heads any good?
  73. Proper Clutch Adjustment?
  74. dont understand this....
  75. 94 GT Fuel system
  76. MOVED: HOLY SH*T 21LBS OF BOOST
  77. STEERING SUPER TIGHT,WHAT HAVE I DONE WRONG?!
  78. MOVED: All original 94 GT Convertible - Thoughts
  79. What are gt-40 power bands like?
  80. 351 with stock hood
  81. mega squirt?
  82. injector ?s
  83. Baer Brakes do you have them?
  84. FlowTech Headers 12104FLT
  85. MSD Box Question..
  86. MOVED: Zero to 60 & 1/4 Miles Times
  87. Idle issue help
  88. starter wiring
  89. Windshield trim and leak?
  90. gas smell from intake
  91. 351w heads question
  92. GT 500 Steering Wheel
  93. Installing a Steeda #19 cam?
  94. Project ready to start, gimme your thoughts
  95. SN-95 rear end
  96. Scat Rods???
  97. breather system or pcv with oil seperator
  98. Battle Boxes
  99. Breathers continued
  100. ingnition coil problem
  101. Halp with distributor install!!!!
  102. Will I get more lope from a steeda #19 cam or an ABC cam?
  103. installation of shorty headers on 94 GT
  104. couple questons about roller lifters
  105. C4 Swap
  106. New here, got some questions bout auto transmissions in a '90 Fox
  107. T5 Tranny
  108. 95 Mustang Cobra Brakes
  109. Need help to figure out vibration!!
  110. Lost on my next step
  111. Just bought a 302
  112. Valley Girdle?
  113. fouled plugs
  114. MOVED: my new project
  115. Connectors: HELP!!!
  116. 24 lbs injectors
  117. T-5 Trans HORROR!!!!!!!!!
  118. gt40 intake
  119. looking at buying a cold air intake....
  120. Question about t-top doors. Again.........
  121. coolant leak help
  122. MAF Sensor Question
  123. Taking the T handle shifter off?
  124. Intake manifold installation
  125. flaming river manual rack
  126. axle help
  127. throttle body
  128. New fuel level guage
  129. installing headers... help!
  130. help.....suspension knock
  131. 1995 GT Transmisson T-5
  132. MOVED: Looking for a Good Dyno shop PA
  133. 1994 GT brake calipers
  134. H/C/I for speed density 5.0
  135. 347 crank with stock heads
  136. How mush power will a 75mm MAF handel?
  137. Fuel pump for fuel cell
  138. too much injector
  139. do i need guide plates?
  140. Best Suspension for Money
  141. optimal S/C for mild build
  142. Porting on GT-40
  143. Trick Flow underdrive pullies
  144. Air/fuel question
  145. QUick head identification
  146. MOVED: BBK Intake
  147. Computer question
  148. Oil Pan Gasket??
  149. accel dfi thruster?
  150. tranny help
  151. Timing belt or chain
  152. need your help screwed um my tires bad tonight!!!!
  153. help plz... electric fan questions
  154. OBD
  155. PUSHRODS
  156. Can I just yank my A/C?
  157. evaporator removal???
  158. MOVED: Camaro Owner tryna to convert to 5.0
  159. fuel pump help (dont want to explode)
  160. Heater Core?
  161. MOVED: Whats your engine bay look like?
  162. E-303 w/ 1.7 rockers or F-303 w/ 1.6's?
  163. MOVED: how much money do u think i could get out of this hood?
  164. Hatch Striker Bolt
  165. Changing the Transmission mount
  166. Backfire from intake
  167. 86 gt temp.
  168. Are 19# inj. enough?
  169. how hard do yall think this would be to do?
  170. Distributor Tooth Off
  171. clutch problem
  172. what is this
  173. starter wire
  174. MOVED: Tragic accident in Birmingham, Alabama
  175. pulled some codes
  176. Cam ?
  177. Starting Problem
  178. MOVED: Anyone with Heders for GT-40's or any 94-95 Mustang
  179. MOVED: 1987 GT Conv 5spd PRICING???
  180. Alternator Install Help
  181. trans question need help
  182. gt40p's and bbk long tubes
  183. clutch pretty hard to push in
  184. Best way to clean Cylinder Heads?
  185. need some major help with aod to t5 conversion PLEASE!!
  186. swapping heads
  187. h/c/i problem
  188. hellpp check engine light
  189. 351 Heads on a 5.0
  190. Door weatherstripping
  191. sorry i didnt know where to put this but im looking for toggles switches
  192. MOVED: stupid quick lube shops... who pays, me or the shop?
  193. REAR WINDOW LOUVERs
  194. svo with a 5.0 motor question
  195. MOVED: do i have a chance to beat....?
  196. paint for headers...
  197. Best headers?
  198. New gauge
  199. Removing front wheel well liners ?
  200. fuel pressure advice needed
  201. new headlights ? UPDATE W/ PICS
  202. Timing Question
  203. another timming question... sorry..
  204. MAF is messed up
  205. AOD shift problem
  206. NEED HELP!!!!
  207. 86 5.0 clutch
  208. air silencer question
  209. NEED HELP WITH SPEEDOMETER CAHBLE
  210. rear end
  211. 1986 to 5.0 LX notch....
  212. Clutches???????
  213. Is my rotor of 180?
  214. Air Bag Light
  215. Size bit for seatbelt latch?
  216. brake problem help!!!!
  217. Changing the Harmonic Balanacer
  218. removing rear bumper cover...
  219. One last question about the brakes
  220. Oil
  221. Just did a KOEO test
  222. agrevating power steering leak need help asap
  223. what is needed for a mass air conversion?????
  224. a few questions
  225. NEED HELP!!!! Someone who knows turbo kits!!
  226. 5 lug conversion questions
  227. Lowering springs question
  228. MOVED: anyone need some headlights
  229. Idle reset question man
  230. MOVED: track times
  231. MOVED: does this track time sound reasonable?
  232. Gear Drive Timing..
  233. m-90 supercharger.
  234. engine setup
  235. 95 302 cam?
  236. Breathers
  237. KOEO Decoding help
  238. best quality rebuild kit
  239. MOVED: 99/01 Cobra or Fox?
  240. problem with my 302
  241. cant figure the cause of the problem out
  242. help! INSTALLED NEW AFRs but....
  243. Timing Question
  244. spark plugs
  245. Bad Computer?
  246. AOD Problem
  247. heater core/evaporater replacement
  248. Coolant Leaking
  249. Newbie engine builder - Refreshing a stock short block (machine work?)
  250. Never flushed an engine this way...
