View Full Version : 5.0 Mustang
  1. Need Help with rear hatch
  2. Injected to Carb Question
  3. Super Coupe 5 spd?
  4. Plug Wire Sets
  5. Buying Suspension package
  6. coolant drain plug location
  7. dumb question about oil change
  8. i need help with my fuel pump.
  9. can i use this intake
  10. Broken crank?
  11. MOVED: GAS STATION OVERFLOW!!!
  12. Trouble Starting
  13. Front end tires rub
  14. Replacing power lock actuator on '89 LX 5.0
  15. heads
  16. MOVED: HOW MUCH???
  17. Sparkplugs/TFS heads
  18. Broken Bolt > What would U do?
  19. Axel dampner
  20. spring compressor
  21. Engine ID problems
  22. question about battery being dead?
  23. Frustrating Temp Gauge Proplem
  24. Typhoon
  25. 94 Stang Cobra intake
  26. What does it take....
  27. Underpullies Tips > About to start
  28. Headers for a 347?
  29. what does wet gas on the spark plugs mean?
  30. MOVED: carfax anyone?
  31. MOVED: Vert Question
  32. Anyone have Typhoon/Edelbrock intake with strut tower brace???
  33. how much timing?
  34. (PICS) Any adjustment in the front bumper cover?
  35. Problem when Driving
  36. Cam question
  37. 1983 transmission..
  38. MOVED: wondering?
  39. need help please
  40. Speedo Gear
  41. MOVED: Help me choose a color!
  42. Girdles
  43. 1983 Coupe T-Tops
  44. maximum compression with 97-98 octane gas?
  45. strange foglight problem, very irritating...
  46. opinion on rebuild kit using explorer heads
  47. MOVED: are these intakes any good ? pics
  48. Can the alphabet cams go in without mods rollers, etc. ??
  49. Running Too Rich???
  50. the 4 to 5 lug adapters on ebay
  51. 10.5 inch rim fitment probs on a 94'
  52. exhaust dump question
  53. Trickflow top end kit done, just one slight problem...
  54. rear is leaning
  55. wiring question
  56. valva problem
  57. MOVED: sounds ok
  58. MOVED: Dyno Numbers
  59. Tach help
  60. Wiring Question
  61. MOVED: does anyone have carfax?
  62. Carb style intake
  63. ground question ??
  64. problem finding part 1995 cobra alluminum radiator
  65. projected tip or non-projected tip spark plugs
  66. wiring short.
  67. battery in the trunk
  68. Hot intake manifold?
  69. 5 point harness install
  70. pinks 5.0 notchback
  71. when hoisting up the engine should i....
  72. Symtoms of a blown head gasket please
  73. cam
  74. Everyone HELP
  75. tubes from headers smoking
  76. wheel offsets and backspacing?
  77. adjusting roller rockers
  78. justa few q's
  79. getting a 97 explorer block got some questions
  80. Turn Signal Problem HELP!
  81. Tremec 3550
  82. TORQUE BOX
  83. TPS sensor compatibility
  84. MOVED: Fiberglass front clip
  85. MOVED: headlights
  86. 94-98 rear on 93
  87. adjustable push rod checker HELP!!!!!
  88. Water pump bolts
  89. how bad is it to drive?
  90. injector size
  91. what RR and Springs??
  92. Bumblebee Cruise January 26 Saleen HQ Irvine, CA
  93. MAF conversion
  94. GT40X and stock rockers...
  95. roller rockers!!
  96. hows it connected?
  97. HOLY SH*T no lights > Need help ASAP
  98. 88 GT custom tuning?
  99. timing issue help!
  100. How to delete my foglights?
  101. NO WAY $$$$
  102. Nedd help with 302 ID...
  103. BOOST GAUGE
  104. throttle body
  105. Turbo Kit?
  106. Stock Block?
  107. Fuel pressure problem
  108. Not exactly a mustang, 1986 Towncar w/ 5.0, no start
  109. Battery relocation question
  110. ROLLAR BLOCK
  111. HELP coolant leak
  112. AOD Tranny Fluid
  113. MOVED: Looking to get COLD AIR INTAKE
  114. V6 to V8 Engine swap
  115. torque on headers?
  116. i am half way there
  117. Putting a 302 in my 1994
  118. 16 pony wheel tires
  119. Rear main seal '93 GT
  120. Radiator leaking, AC not working now
  121. wiper motor relay location
  122. Installing Baer front brakes
  123. Cobra clutch help!!!
  124. 93 5.0 swapout
  125. MOVED: intake manifold
  126. Stroker Kit
  127. Tranny Locking up
  128. How Many Wires Do You Really Need?
  129. MOVED: Best Price For Polished Tyhphoon Intake???
  130. T-5 Trans Fluid
  131. BBK/MAC Strut Tower Brace??
  132. jack up engine safely
  133. my tranny is making noise
  134. automatic trans noise
  135. 5.0 carburated and emissions
  136. injectors causing idle issues???
  137. 89 LX rear seatbelt retro fit to a 90+model
  138. Aftermarket computers
  139. upgrades
  140. O/R Pipes and Emissions
  141. bad vibratoins!
  142. 331 VS. 347 Which is better?
  143. 94-95 GT questions
  144. Trans/First gear question
  145. MOVED: you guys with dumps help me
  146. Different Smog Question
  147. MOVED: Ok had the car 2 weeks now...PICS
  148. Need help with aod trans
  149. MOVED: Windsor Dart JR Heads
  150. Stock alt in 89 5.0
  151. MOVED: 95 Mustang gt Vs. 02 Trans Am
  152. MOVED: The end all of Top end threads (mine at least)
  153. Springs Walkthrough...
  154. how to lean the car out.
  155. 93 4cyl to 89 5.0 swap question
  156. Mac Longtubes
  157. 87 5.0. Trying to figure out what these lose wires go to..
  158. MOVED: 306 to 331 347???
  159. Help me find a 12v Key on source.
  160. Will a Cougar fan shroud work?? 5.0
  161. Clutch question
  162. Restoring Compression for a 94 gt 5.0 h.o.
  163. MOVED: My 14000 mile no option notch
  164. MOVED: Anyone running the Crane HI-6s???
  165. MOVED: HOW TO BEAT AN LS1
  166. torque specs
  167. MOVED: mickey thompson street radial
  168. problem with clutch cable after aod to t5 conversion help!!
  169. rolling fenders
  170. Head Specs?
  171. finding a short
  172. Advice for tuning my stock 5.0
  173. Transmission upgrade
  174. gt40 rr machining.
  175. Dipstick
  176. do sealants really work??
  177. BOV for my powerdyne supercharger
  178. 351 vrs ls1
  179. tranny Q
  180. ENGINE SWAP
  181. Floor Pan and Torque box reinforcement or battle boxes?
  182. 90 Rear Hatch on a 87
  183. anyone heard of d&d motors?
  184. 94 gt 5.0 Brake Proportion Valve
  185. low profle intake question?
  186. oil pump problem
  187. god i hate to ask here.... but no other choice.
  188. H-H-H-Holla
  189. Shorty headers
  190. 2.3 to 306 Project... I need your help!!
  191. fuel gauge in fox mustang
  192. explorer motor rebuild kit
  193. gt-40 head ?
  194. which coilovers for the rear?
  195. BOSS Wing install
  196. 95 gt backfire???
  197. Please educate me on cams...
  198. Thermostat Replacement
  199. Push Rod measurement
  200. Panel Dimmer Switch
  201. 2.3 to 5.0l help?
  202. MOVED: how much does she weigh
  203. JUST INSTALL MY MM STRUT TOWER BRACE.
  204. MOVED: lx vs gt..
  205. problem
  206. Coolant Leak Guidance
  207. kenne bell supercharger on a 5.0 fox
  208. PATRIOT HEADS
  209. What do you think about these heads?
  210. Can you identify this part ?
  211. how does this work?
  212. What fuel pump to purchase?
  213. Cam in a 94 GT
  214. COBRA INTAKE,EDELBROCK OR TRICK FLOW,OPINIONS NEEDED,TIA
  215. what gears are in the car?
  216. Fuel Pressure
  217. Rocker Clearance
  218. alternator question
  219. crappy cold idle
  220. ignition coil upgrade question???
  221. stock port size on heads
  222. any good tuning devices for my 89 stang
  223. ignition coil
  224. gt wont start
  225. have my heads been worked?
  226. Serpentine belt trying to slide off of water pump?
  227. Coolant drain plugs on block - location?
  228. Guage cluster question....
  229. 5.0 out of a thunderbird
  230. Trans F@cked... How severe is it?
  231. hmm wats next
  232. why does my car stay running
  233. faint smell of antifreeze
  234. OEM AT shifters?
  235. Polished Pullies/Rad Hoses
  236. Torquey Cam
  237. Upgrading stock pullies
  238. 5.4' H-beam rods
  239. TPS
  240. 92 5.0 EFI buildup
  241. New carpet question
  242. Tuning???
  243. AHHH!! clutch cables problem
  244. Electrical question
  245. Damn, I feel stupid
  246. has anybody used these before?
  247. Typhoon Intake/Strut Tower Brace
  248. MOVED: Should I buy this 93 notch $400(read post before voting)
  249. MOVED: 86 Mustang 5.0.. Looking Into Change
  250. ECU Removal
