- Trans F@cked... How severe is it?
- hmm wats next
- why does my car stay running
- faint smell of antifreeze
- OEM AT shifters?
- Polished Pullies/Rad Hoses
- Torquey Cam
- Upgrading stock pullies
- 5.4' H-beam rods
- TPS
- 92 5.0 EFI buildup
- New carpet question
- Tuning???
- AHHH!! clutch cables problem
- Electrical question
- Damn, I feel stupid
- has anybody used these before?
- Typhoon Intake/Strut Tower Brace
- MOVED: Should I buy this 93 notch $400(read post before voting)
- MOVED: 86 Mustang 5.0.. Looking Into Change
- ECU Removal
- 350 in 92 fastbak
- Blower Install
- flowmaster 40
- What Gears should i get
- adjsting rockers need help???
- AC Delete / Smog Delete Q's
- MOVED: H/C/I combo ?
- 5.0l volvo bbk headers?
- 331 stroker
- need to get tranny in tonight need help please!!!!asap
- fuel float help
- underdrive pulleys and AC
- power steering bracket
- interior question
- MOVED: Should I buy it?
- long tube header question
- Help with a new stang
- HELP NO START !!!!
- Pulled 3 codes...
- MOVED: Whats your thoughts on this 92 LX?
- Best stall speed with F-Cam
- a newbie question
- problem with my header bolt
- engine decoding help
- just a quick question
- Fuel Tank Insert ?
- 42lb injectors or 19s?
- turbocharger
- Just a question
- Vacuum Line Diagrams
- Clutch Pedal
- s transmision
- Main/Rod bearing questions
- '91 302 timing chain, nylon sprockets
- UPR K MEMBER KIT
- quick questions
- need some help
- stuck driveshaft?
- MOVED: What should i go with?
- Engine whine
- A/C and PS removal
- 10 Hole Wheels
- Another overheater...lol
- MOVED: bullitt wheels on foxbody??
- Belt removal - tensioner?
- seems to good, anyone have it?
- how to tell apart? 302/351
- MOVED: anybody have these headlights?
- having pressure plate problems?? NEED HELP ASAP!!
- Really BAD news!
- crank bolt size
- What is needed for a 94-95 to make 350-400 rwhp? Budget?
- UPDATE running ritch
- Brakes
- MOVED: Pro 5.0 shifter for sale
- question
- need help with flywheel dowel pins real quick!
- need to redo my timing
- cant get rear main seal out help please!!!!!!
- springs
- stall or gears?
- Engine Troubles.. What to do? please help
- broken bolt for valve cover
- Pin hole leak in head gasket
- replacing header gasket....
- qustion about rear end
- oxyogen o2 sensor
- tubular front control arms
- Possible car/engine problem!!!!! Help!!!
- do i need full length subframe connectors?
- Nitrous Guys Look Here
- one chamber mufflers?
- What size Torque Conveter for 3300-3500 Stall
- need help pls
- how hard is it too.....
- speedo gears
- upr k member help?
- Nitrous Question
- Speedo cable off cluster?
- IVR and Gauge Questions
- Pressurized Gastank???
- annoying exhaust leak????
- Are all T-5 trannys the same?
- lookin for part
- T56 questions
- Where can I purchase seat support braces?
- HELP!
- Non-power brake kits for Fox mustangs
- rattling / clicking sound from my rearend
- EFI to CARB
- MOVED: where to get installed?
- Rear end on 5.0
- What H Pipe to go w/ Magnaflow
- 03 suspension on a 94
- JUNKYARD PART QUESTIONS
- Battery relocation to trunk question
- Gears: Speed vs. RPM
- MOVED: Finally back
- Exhaust Smoke Question
- MOVED: D&H auto parts
- MOVED: LX tails
- Lower shift boot- 50 resto
- MOVED: 94 cobra first mods
- Help Please! Car won't start.
- Can a sn95 5.0 engine go into a 76 mach 1 fastback?
- MOVED: 351w Engine Combo ?
- 4.6 heads on 5.0
- valvetrain / cam help
- Review: Unisteer Manual Fox Body Steering Rack
- EEC Code: 89 – AXOD lockup solenoid ??
- 94 mustang brakes
- tremec t56
- adjustable FPR install
- v6 to 5.0
- bullet wheels 315 tire!!!!!
- rod bolts
- Tach wire location
- electric fan controler
- power lock actuator removal?
- gt40p valve springs ok?
- Fox SC on an SN95?
- couple of questions regarding clutch install?
- hose on top of radiator cover?
- Headlight Switch
- High idle?
- harmonic balancer
- Swaping Ingition Switch
- cold air intake
- MOVED: 1967 v8 vs 1989 v8
- need help !!
- MOVED: 93 saleen?
- MOVED: 1989-92 Mustang Plans (look good?)
- belt setup
- Where is the door trigger wire????
- water leak
- roller rockers
- Stock Brake Upgrades
- AT problems
- What is this?
- MOVED: Where to find 83 convert seatbelt bezel
- MOVED: what cam?
- Car dies after driving
- MOVED: what to buy ?
- MOVED: NT1320's
- Are GT-40P's smog legal
- What MANUAL 5 speed tranny can I use?
- MSD???
- just bought this not sure where it goes??
- MOVED: motor suggestions
- 331
- do I need a harmonic balancer spacer?
- MOVED: h/c/i
- Performance Automatic Racing Transmissions
- F'n idle!!!
- how much would this help?
- Frozen Door Handles
- Check engine light?
- GT40P head swap / q's
- reset base idle question
- Heater core question
- speedometer gear question.
- 85Gt Intake
- Smog pump bypass
- Two questions (possibly more..)
- Speed density - 87 GT...MYSTERY PARTS!!
- Driver and Passenger seats
- Oily Spark Plug
- headlight switch
- 87 5.0 horsepower question.
- Trans Swap
- Advanced Timing and Gas
- Quick question
- Dizzy Cracked? Should I worry??
- little question....
- Fog lights
- MAF sensor question.
- 3:73 gears question
- throw out bearing
- 5th gear probs and tranny rattle
- Fuel lines and pressure regulator
- Question for SN-95 owners
- help! ticking noise from stud mount roller rockers?
- Suspected noise, WTF
- need an answer now!!
- can worn rear end cause a vibration?
- Misfiring
- Megasquirt and Fast Idle Valve
- MOVED: ==> Every Automotive Calculator You Will Ever Need!!!
- Tie Rod Interchangability
- problems with transmission or clutch
- clutch petal vibration/noise
- speedo issues
- Broken wire connector, need help
- Crane hi-6 problem
- jet chip or hypertech
- 80mm maf question???
- just wanted to know
- advice wanted (repainting my foxbody gt)
- Air Filter.
- 3ag alternator - which one??
- Lifters
- Throttle body
- Fill me in on these turbos...?
- taking out the axle
- Need some advice
- 86 valve clearance
- Alternator Issues?? Bad wires?
- poss. msd 6a bad or tfi?
- Just started smelling gas!
- Ignition for EFI to Carb conversion
- CLUTCH PEDAL WIRING????
- TRICKFLOW TRACK HEAT AND STOCK MOTOR???
- Electronic fan temp controller kit\ Worth it?
- Big question...kinda
- Frustrated with explorer intake
- Intermittent miss in rev's
- some advice
- 95 cobra rear in a fox body
- Spool, c-clip questions
- no spark but car is turning over
- sn95 ?
- rear end question
- No power to cigaret outlet
- fanless
- Subframe Install Question
- MOVED: H/C/I on a stock block and telling actual mileage on car
- MOVED: Tire Size
- Cobra intake install
- MOVED: 285 on a 10inch rim??
