View Full Version : 5.0 Mustang
  1. pulled head
  2. unusual alternator problem? car was towed
  3. 5.0 or 4cyl conversion?
  4. ps cooler is it needed?
  5. C4 swap
  6. Possible head and RR swap!!!!
  7. Alternator overcharging
  8. Short throw shifter install
  9. New Mufflers
  10. T-5 rebuild, "world-class" and FRUSTRATION
  11. hi flow cats or off road that is the question?
  12. MOVED: Nearly stock 1990 GT vs. a 2003-2004 Mach 1
  13. MOVED: Rim Choice
  14. intake manifold troubles
  15. 24lb injectors
  16. dashboard swap how hard?
  17. difference between transgo shift kit and lentech manual valve body?
  18. hypertech work?
  19. Does the combustion size change compression?
  20. fuel pressure HELPPP
  21. Possible Cause of a Creaking noise driving me INSANE
  22. subframe connectors question
  23. Brake upgrade?
  24. torque spec on pinion nut
  25. sputtering?
  26. Bolt pattern for fox bodies
  27. MOVED: 88 5.0 smoked by 2000 Z28
  28. 9" rear in a fox
  29. which one to rebuild?
  30. Recognize this spring?
  31. transmission
  32. building a 347
  33. exhaust valve or rocker?
  34. Short Throw Shifter Install
  35. ACT sensor
  36. loose steering, yet another problem
  37. Trans Fluid?
  38. Rear end noise
  39. ?
  40. 5.0 swap from v6
  41. engine setup
  42. 86 302
  43. What mods can i do to my 5.0 CARB?
  44. rolling the fenders
  45. Crankshaftt pulley bolt size
  46. Quick tranny hELP!
  47. Fitting issues...I'm stumped.
  48. clutch cable
  49. Stupid Question
  50. Help Please I don't know what to do...
  51. gt-40 intake vs. stock
  52. alternator??????
  53. camber/caster junkyard?
  54. 4.10 gearing question for 89 lx 5.0
  55. PLEASE READ! ENGINE SPUTTERING at 3500rpms
  56. suspension
  57. Water Pump Direction
  58. It's Alive
  59. Need help with Rim and tire question
  60. Magnapacks and a fox
  61. HELP ON 89 LX MUSTANG
  62. a different kind of fan problem
  63. Hi Flow Cats Question
  64. turbo oil lines
  65. cobra grille install
  66. timing
  67. torque box
  68. rear wheel bearings bad?
  69. Which Throttle Body?
  70. Is anyone here using RHS heads?
  71. cats are going back on
  72. 302 swap in 4cyl.
  73. headers for yates
  74. going to be doing the rings....
  75. Smog pump delete
  76. Edition Lombardi 87 GT ????
  77. valve spring question for people with E303
  78. MOVED: $4 gas? HELP Design fuel efficient hot rod ford engine
  79. TFS R series Intake VS Holley Systemax
  80. Help with tranny mounts
  81. brakelines
  82. Kirban fuel pressure regulator
  83. exhaust question
  84. Brake upgrade
  85. MOVED: Looking to buy a 94GT, but need so Info..
  86. distributor wont turn
  87. 347 stroker build-up question
  88. 2.3 to 302 vert
  89. high idle after warm up.
  90. aod to t5 swap?
  91. electric fan
  92. MOVED: whats next question
  93. Building a stroked motor?
  94. new mustang
  95. brakes
  96. when to weld frame rails?
  97. door locks
  98. piston ring
  99. harmonic balancer?
  100. fox body hydraulic clutch
  101. speedo gear
  102. hard starts/stalls
  103. Egr elimination resistors??
  104. install of a 5spd pedals
  105. Help pulling a 5sp tranny out of a 92 lx 5.0
  106. Mass air computer C1A1
  107. sometimes she starts, sometimes she doesnt...
  108. vibrations/semi soggy brakes...
  109. Coil Overs
  110. MOVED: Which Mufflers to go with?
  111. whining sound from rear or driveshaft?
  112. bbk fuel pressure regulator is leaking
  113. Slipping Auto Transmission
  114. anyone got pics of eibach pro kit installed?
  115. MOVED: Tires/stance
  116. How do you confirm an SSP car?
  117. MOVED: how low should i lower my car
  118. cat smoking.
  119. MOVED: Ford Racing 9mm plug wires
  120. subframes
  121. HELP PLEASE! MAJOR PROBLEM
  122. coils spring isolator !!! HELP!!!
  123. Fuel Rails
  124. MOVED: H Pipe or X pipe on a 94 GT
  125. Battery charging problems...
  126. mustang v6 to v8 ??
  127. Car won't idle
  128. emitting black/grey smoke when at high rpm
  129. wiring questions
  130. Dead battery issue
  131. 89 mustang 5.0 lx
  132. check it out... remember the days
  133. backfire
  134. 94-95 gt or cobra
  135. Wheel hop after susp mods ? ?
  136. Timing cover differences
  137. Nuetral saftey switch bypass
  138. electric fan retrofit
  139. Help needed fast on intake manifold on 1988 mustang gt??
  140. chipped combustion chamber
  141. volts gauge bouncing at idle ?
  142. bench bleeding a master cylinder
  143. MOVED: Well, my new wishlist
  144. what do i do now
  145. Opinions & Help on my First 5.0 ENGINE BUILD
  146. MOVED: 87 to 93 GT fog light question
  147. intake manifold swap
  148. MOVED: '93 cobra parts
  149. MOVED: Broken Back.
  150. air pump check valve
  151. 89 notch with AOD problems
  152. search broken injector questions
  153. Core Support Damage
  154. engine rebuild
  155. benefits of EGR delete?
  156. Roll Cage
  157. oil pressure
  158. off set/ back spacing wheels???
  159. How do you wire a Altenator
  160. MOVED: anyone take off their power steering? i need the ps return line the metal part
  161. power steering metal return line
  162. getting supercharger
  163. Engine Overhaul
  164. MOVED: GT Taillights
  165. Vert top pump
  166. AODE problem?
  167. car died....need some help...
  168. MOVED: vettes
  169. Fox body with 5 lug, ball joint and front end ?'s
  170. shift linkage and gear ?
  171. Starter relay/solenoid- wiring help
  172. how do you get a drivebelt to tension
  173. NEED HELP WITH THERMOSTAT!!
  174. Rearend Question
  175. 93 Cobra intake on a 94 GT
  176. Borgeson aluminum steering shafts
  177. GT40 and stocker.
  178. oil leak
  179. pcv valve
  180. need help please
  181. That little steering shaft collar that attaches to box
  182. csr water pump
  183. trw L2490 in a 302
  184. efi to carb
  185. MOVED: bullit rims of fox
  186. Help needed on Harmonic Balancer and Flywheel.
  187. what is a gt-40
  188. 2.3 to 5.0
  189. MOVED: 88-89 Convertible Front & Rear Speakers ???
  190. upper tq boxes
  191. melling products
  192. Rocker Q
  193. 347 stroke?
  194. sn95 full front suspension
  195. Best Bolt Ons 5.0 ???
  196. 65mm throttle body Up grade??
  197. kinda pissed (kinda not)
  198. Listen to this GUYS!!!!
  199. exhaust
  200. Alum Rad, Electric fan, and Alternator setup?
  201. 347 clutch help
  202. i did search, help with idle issues
  203. Electric Water Pump on a real DD
  204. Mac Prochamber onto FlowTech LTs?
  205. 5.0HO mods... help
  206. puck style racing clutch's any good?
  207. paxton sn 89?
  208. Torque Arms? Are they worth it?
  209. Can you make struts work on 79-86 mustangs?
  210. TF Twisted Wedge top-end kit vs. RHS 200cc SB Cylinder Heads
  211. any1 have TNT Imma gonna blow it up
  212. 351 on 302?
  213. MAF and Idle questions
  214. water from tailpipes?
  215. Head Qs? Not the normal Qs.
  216. high idle problem
  217. weatherstripping/molding question
  218. Idle problem
  219. bad news
  220. Torque converter advice?
  221. 89 5.0 LX, 7.5 or 8.8?
  222. MOVED: MGW or Steeda Tri-Ax
  223. MOVED: ET?
  224. turbo question
  225. Do I need to upgrade my intake?
  226. what should i add?
  227. 93 GT: propper TB size, equal vs. non equal header Q's
  228. Fox parts interchange?
  229. Tranny question
  230. Good cam for GT-40ps?
  231. noob 5.0 ?
  232. Coolant problem
  233. MOVED: What do you think about ebay???
  234. Rear coil spring spacers
  235. control arms
  236. ok what the hell? need some help quick!
  237. o2 sensor wiring (megasquirt)
  238. AOD Question
  239. Electrical Nightmare
  240. Tranny Fluid?
  241. finding a computer
  242. New Website for American Muscle Appreciation
  243. Evac System
  244. harness vs. 4 wire for mass air conversion
  245. heating issue again
  246. gt40p head question
  247. HELP with H.I.Ds in a 5.0
  248. Tubular GT-40 intake
  249. stock 5.0, can i go nitrous?
  250. What size gears are stock in an 85gt
