View Full Version : 5.0 Mustang
  1. Electrical Nightmare
  2. Tranny Fluid?
  3. finding a computer
  4. New Website for American Muscle Appreciation
  5. Evac System
  6. harness vs. 4 wire for mass air conversion
  7. heating issue again
  8. gt40p head question
  9. HELP with H.I.Ds in a 5.0
  10. Tubular GT-40 intake
  11. stock 5.0, can i go nitrous?
  12. What size gears are stock in an 85gt
  13. 5.0 swap help
  14. MADE A STUPID MISTAKE (SPARKS AND SMOKE) HELP PLEASE!
  15. Steeda #19
  16. 3.73 Vs. 3.55
  17. lose weight..
  18. MOVED: chrome dipped
  19. rocker stud girdles
  20. MOVED: so, who wants to hear my II running?
  21. I need someone who knows axle seals,
  22. minimum to reach 600 rwhp
  23. Longtubes and emissions
  24. 1.5 inch lower exhaust question
  25. Best shocks for all around
  26. T5 2 AOD?
  27. how to care for a 95 with 182.000
  28. Heater core how to?
  29. speed density how to's wanted
  30. upr k-member kit
  31. rattle clunking sound clutch
  32. fuse help please
  33. how much nitrous can stang take????
  34. real quick question 3g alt install
  35. Anyone using GT40-X heads...
  36. clutch pressure again?!!!
  37. MOVED: Tis a Sad Day in the 5.0 world.....
  38. door lock
  39. What is this?
  40. Weird problem
  41. whats wrong with my ponny!!!!!!!!!
  42. longtube headers and automatic?
  43. 1990 5.0 Problem at Low Idle.
  44. Cold Air Intake
  45. help installing window motor
  46. how much stronger is a mexican block?
  47. SN-95 Brake Question
  48. 88 GT T-Top running (rich)?
  49. soft brakes !
  50. Help with MAF and air tube for EFI swap
  51. Newbie Here...With A Swap Question
  52. Heads- Holley or Trickflow Or Edelbrock
  53. need some help please**updated with pics*
  54. Stuck throttle body to intake suggestions?
  55. thinking of doing a 4 eye conversion
  56. cmputer swap????
  57. wheel sizes
  58. how do i make my clutch cable adjustable?
  59. Head Gasket
  60. Header install gasket matching ?'s
  61. 89 gt gears
  62. knocking sound
  63. quick harmonic balancer question
  64. 1990 Rear Quarter Panel
  65. Harmonic Balancer Install
  66. frame strength???
  67. New Rack and Pinion Steering Boots leaking
  68. Starting Issues
  69. thread for rocker and pushrod install
  70. venom 400?
  71. Engine swap.
  72. bad sounding noise
  73. AFR pushrod length with 1.7 pedestal RR
  74. HAVE THIS HAPPEN TO ANYONE BEFORE?
  75. whole floor replacement
  76. rear (not a gear ?)
  77. random problems, suggestions??
  78. Somethings F***ed up!
  79. are these intake, head, cam, etc. combos worth it?
  80. suspension questions
  81. Best Budget combo
  82. E303 pass smog?
  83. pedestal or stud rockers
  84. MOVED: Is this worth $3k?
  85. whats needed to install an electric fan
  86. How in the sweet jesus do I get at these bolts?
  87. MOVED: Dress up!
  88. clutch and cable recomendations??
  89. Rocker Arm Studs
  90. MOVED: My '91 Convertible project for $450
  91. MOVED: Help with picking Exhaust
  92. Automatic Trans.
  93. stroking my 5.0 questions
  94. 69 ford 302 power limitations......
  95. can i put 4bbl on fuel inj/blk and keep cam
  96. Need help on picking between Control Arms
  97. exhaust smoke is too white
  98. ebay twin turbo kit (good or no good)?
  99. what intake to use
  100. Front Subframe Bolts
  101. wideband o2's
  102. more horsepower.
  103. idle problems
  104. BBK SSI Numbers
  105. id number on rear end
  106. Dimming Lights/batt gauge...
  107. car starts in reverse not in park??why
  108. E303....problems?
  109. neeed advice on upgrades
  110. MOVED: park the 5.0 in the rain and get a Subaru WRX? How do these compare?
  111. Alternator Gague Question
  112. engine question
  113. 331 or 408
  114. what size TB is stock on a 95 5.0?
  115. 65mm and 70mm difference
  116. When it comes to headers..
  117. 95 induction which is better
  118. Victor 5.0L Intake
  119. MOVED: pics and a vid of cam swap in 93 lx
  120. MOVED: I need a Cold air intake?
  121. Fox Headers on a SN-95
  122. T5 input shaft play
  123. Lincoln mark 7 rear end question
  124. Speed Density
  125. MOVED: fox fender extensions
  126. MOVED: im new to sn95's
  127. MOVED: 182,000?
  128. shift kit for auto
  129. trans question
  130. anyone head this issue?
  131. Kenne Bell SC Question?
  132. bearing clearance
  133. MOVED: CANT believe my car is CRACKED I got CHEATED??? help what can I do
  134. MOVED: found a 84 5.0 for 800
  135. Locked out of trunk
  136. IS THIS POSSIBLE??
  137. vortech question
  138. 1987 Mustang Gt
  139. Spindles swap ?
  140. MOVED: bought another fox!!
  141. MOVED: which charger?
  142. MOVED: 1984 5.0L GT vs non-GT
  143. new exhaust parts - need answers
  144. MOVED: Best way to spend 5,000
  145. MOVED: astro performance
  146. Engine performance problem
  147. coolant problem
  148. Belt Size
  149. Anyone With a 2-step
  150. gas smell:::
  151. thermostat tidbit
  152. What's my cam?
  153. please help auto tran wont shift to drive
  154. Another "will this tap the piston" question
  155. what can go wrong in the bottom end...
  156. Pulley Help!
  157. distributor
  158. engine help
  159. clutch pressure is gone
  160. MOVED: need help! cant decide
  161. MOVED: WELL I am HAPPY!!!
  162. MOVED: NEED PIC OF YOUR ENGINE BAY.
  163. cam bearing
  164. MOVED: A new 5.0 mustang from saleen
  165. Vibration...Hmm
  166. can anyone help on rpm problems?
  167. Header bolt length
  168. how to tell which lifter
  169. RE: one thing after another
  170. fast xfi vs. Accel dfi
  171. Tranny Crossmember
  172. emission question
  173. Look at these heads and Rockers "pics"
  174. timing gear set
  175. still no spark. cannot figure it out.
  176. Offset rack question
  177. g-force
  178. which valve stem seals???
  179. Weird Idle
  180. Mac Products & Trufiber Hood GP!
  181. valve spring keepers won't budge
  182. need to find a p/s cooler
  183. Question???
  184. Drag spool vs Locker
  185. whats the best timing for 90 5.0L?
  186. Finding a Clockspring
  187. supercharger help
  188. Springs and shocks on a fox
  189. water pump problems
  190. gauge needles
  191. Compression Ratio questions
  192. Timing set points?
  193. Proportioning Valve
  194. cam help
  195. IGNITION COIL
  196. first time doing a clutch help!
  197. 70mm egr plate to stock intake?
  198. MOVED: wheel size
  199. MOVED: 275s and foxes
  200. Bad Clutch????
  201. MOVED: pro 5.0 question
  202. TRANNY and IGNITION problem!!!
  203. MOVED: TIRE SIZE QUESTION
  204. Can you clean up Fouled plugs from Gas?
  205. trouble shifting in and out of gear
  206. how to convert to mechanical Roller cam
  207. RIM SIZE QUESTION
  208. C-6 or AOD
  209. tried to tune the timing and cut out
  210. How much do these cars weigh?
  211. Rust problem, Any suggestions?
  212. tach wireing
  213. biggest lift cam on stock springs?
  214. Throttle body choice?
  215. 5.0 gt to 5.8
  216. E-303 question
  217. help with 302
  218. help with 302
  219. bad wiring??
  220. power steering pump question (adder you might know)
  221. new edge seats
  222. what should i do?
  223. Bad Vibrations- HELP
  224. Rattling noise/problem
  225. Rear End Drum Brake Swap Question
  226. engine help...need some help
  227. Timing cover gasket
  228. Flywheel
  229. Shifter
  230. 2 choices and another ?
  231. rings?
  232. What is this for?
  233. inncorrect fuel level
  234. Pushrod length???
  235. fan connector q
  236. Rear end Question
  237. MOVED: Smog Pump Delete in Arizona?
  238. MOVED: what brand of wheel is that
  239. bad wiring?
  240. motor not warming up?
  241. 331 question
  242. tire question
  243. control arms
  244. Smog tests and more bolt-ons...
  245. throttle body ?
  246. just put heads on....few simple questions...
  247. 1991 GT Conv won't start
  248. MOVED: Gears
  249. MOVED: i need pics of red 5.0's with gunmetal rims
  250. vacuum diagram???
