View Full Version : 5.0 Mustang
  1. Headlight Positioning
  2. Will not Rev
  3. 87 5.0 gt
  4. upgrade question?
  5. MOVED: BIG WHEELS!!
  6. t-56
  7. carb vs fuel injection
  8. STOCK COMPUTER SETTINGS FOR A 95 COBRA
  9. This is weird
  10. Finished fuel pump - New Problem..
  11. NEED HELP ADJUSTIN ROCKERS
  12. EGR tube from heads, what bolt fits hole?
  13. Cast iron heads #'s
  14. Flywheel de coding question
  15. Engine shuts off and then dosn't start up
  16. Please help
  17. are 1 3/4" LT's worth it?
  18. Coolant leak from firewall
  19. ignition problem?
  20. Passenger Window Problems
  21. transmission slippage ???
  22. Weight reduction
  23. question
  24. Eibach Pro Kit
  25. What rockers for my heads
  26. Rear suspension questions
  27. MOVED: hp question ???
  28. Idle problem after intalling MAF sensor
  29. Ford Torque Specs.
  30. Battery relocation ground help
  31. Question on check engine light???
  32. idle problem at startup
  33. clutch cable snapping
  34. clutch problem
  35. 89 w/diablo question
  36. saleen wing
  37. Displacement
  38. is this good or bad?
  39. 210cc heads with 205 valves, what motor to put on
  40. Stock 5.0 Intake Manifold
  41. will not idle!
  42. Finishing up the build...
  43. roller to flat tappet cam
  44. Question concerning my engine
  45. MOVED: Summit wheels vs Weld draglites???
  46. 5 in.-Hg vacuum at idle
  47. Cheap Manual crossmember
  48. Bleeding Air Out of Cooling System
  49. 93 COBRA COMPUTER CONVERSION KIT
  50. Want a Turbo....but on a budget
  51. stabbing the dizzy question
  52. What is this noise?
  53. Foxbody Fenders
  54. Cementing Block
  55. MOVED: Hello new guy with questions
  56. Jumping Tachometer in 95 GT
  57. EGR Valve
  58. sluggish starting
  59. clutch or cone diff
  60. MOVED: looking for 95 roush sideskirts
  61. My GTS ..still isn't starting right.
  62. MOVED: Has anybody ever changed the air filter here?
  63. Can't find Coolant leak
  64. Whats the difference on a v8 five speed and a 4 cylinder 5 speed???
  65. Fuel/Exhaust help
  66. tko in a 331 stroker
  67. newbe ??? 96 stang
  68. MOVED: Power steering pump replacement?
  69. MOVED: Hoods
  70. EGR valve....85 GT...?
  71. stroker kit?
  72. 93 gt heads on a 95 gt?
  73. Will i need camber plates??
  74. smog pump
  75. exhaust ?
  76. What involved in balancing
  77. BBK Fuel Pressure Regulator
  78. C/C Plates
  79. oil pump question
  80. spun lifter, and cam question
  81. Hurst 1/4 stick install in 91 Fox? Need help
  82. Hows This Sound???
  83. Wider tires!!!!
  84. buzzing noise exhaust ?
  85. which tranny?
  86. throttle body
  87. Rear brake hoses for disc brakes
  88. Driveshaft rub: problem caused by eibach sportline springs
  89. 3.90 or 4.10 gears?
  90. Gears
  91. Lost the Tranny
  92. MOVED: need more power
  93. factory tightening sequence for heads...
  94. MOVED: i know this shouldnt go here
  95. AOD Shifting
  96. HELP!!!!! smog delete belt size
  97. 89 LX 5.0; T-5 "whizzing/vibration" at rpm
  98. Heat only comes out of the defroster no matter where i turn the knob...
  99. REAR END..!!!
  100. AOD dead??
  101. 91 5.0 alternator upgrade question
  102. 91 5.0 engine code
  103. popping noise back fire? help
  104. Super Easy Dent Fix?
  105. How are is it really?
  106. 4 lug to 5 lug
  107. damn rust
  108. smoke under spark plug boot
  109. loose rocker arm
  110. Help me understand Alum Head CC's
  111. PCV location
  112. Something is not right
  113. fuel pump and regulator
  114. 5.0l truck engine parts??
  115. major ignition problems.... help
  116. Sensor ranges??
  117. Starter Troubles
  118. too much pressure radiator
  119. 8.8 Reaend Has Play..... Need Help
  120. help with some pulleys
  121. bad idle
  122. Strange Brake?
  123. Are my heat vents supposed to make a weird noise?
  124. MK vii interchange
  125. ARP studs... rod and main bores?
  126. About to replace Harmonic Balancer
  127. Spoiler brake light
  128. 8.8 rear end bearing caps
  129. quick answer needed about headgasket/cam
  130. Trick flow roller rockers
  131. Anyone have a pic of their coil cover?
  132. firing order for a 86 5.0
  133. need advice on 95 mustang
  134. another exhaust question...
  135. is this a 289 or 302 block???
  136. ah! help.
  137. T5 main shaft help
  138. Engine noise right after ignition
  139. supercharging my 95 GTS
  140. Carb secondary adj.
  141. where does the speedo cable go?
  142. How do you know if your heater core is gone?
  143. Manual brake conversion
  144. 5.0 HO question
  145. what is this?
  146. whats stronger
  147. MOVED: Skinnies
  148. Gap less ring vs Normal rings
  149. Back Pressure?
  150. Emmission Check Valve won't come off
  151. 8.8" or 7.5" rear
  152. Quarter panel repair/replacement on a hatchback
  153. MOVED: skinny tire size(yes another one)
  154. MOVED: Added a new 'stang to the family
  155. how would your car feel..
  156. Ignition Problems
  157. intake question and porting question
  158. negative battery cable
  159. gt40 cast iron heads
  160. how bad is no mufflers
  161. C/C Plates
  162. Shifter Paddle Kit for Automatic
  163. 94-04 pedal swap
  164. I got new Codes today.. Whats the fix?
  165. Mustang Turbo
  166. 5 lug conversion
  167. possible driveshaft problem
  168. what's going on?
  169. solid trans mount or poly?
  170. Idle probs
  171. BBK o/r x pipe wont match up to BBK long tubes?
  172. Bassani cat back
  173. Do I need larger injectors?
  174. Need some help 95->88?
  175. Can't find valve covers for my motor!!
  176. Gotta big shimmy...
  177. Fixing rusty Floor pans?
  178. 5.0 1990 (7 up) shimmy at 65
  179. Valve seals - oops!
  180. Water pump problem?
  181. Stumped on these codes
  182. all i have is 1st gear...
  183. 351w heads??
  184. steering issue
  185. Headlight trouble please help!!
  186. E fans - Are they worth it?
  187. how to tell what size injectors are
  188. Transmission Problems.
  189. are these worth it
  190. power steering pump queston
  191. I want to take out the backseats
  192. Factory 351w Alum heads
  193. 2.5 exhaust
  194. NEW DOOR??
  195. t5 inspection, going to sell
  196. Clutch advice
  197. Suspension
  198. not sure what to do
  199. Will Aluminum fix this?
  200. subframes
  201. gear question
  202. any feedback on a procharger p600b
  203. Rear/Wheel/Axle Question
  204. 3 angle valve job worth it?
  205. Oil pressure gauge all the way at bottom at idle?
  206. 347 stroker question
  207. Push Rod Length
  208. Question on pulleys...........
  209. finally getting an 8.8 rear
  210. MOVED: Pictures of my Stang 92 vibrant red convertible
  211. shifting issues
  212. crank/machining help
  213. How do you take the windsheild trim off a foxbody
  214. How do you take them friggin electrical clips apart?
  215. T-56 Questions
  216. Supercharger? or Turbocharger?
  217. No Idle
  218. Why Won't it Run?
  219. TRX Wheels
  220. Need some Mustang perspective...
  221. MOVED: Craigslist 302- worth it?
  222. Fuel System (Dual or Single Feed ?)
  223. Idle is getting worse
  224. Suspension advice
  225. Air Bypass Valve???
  226. 83 5.0 exhaust help
  227. Clutch and Engine Temp Questions
  228. Need Help on what cam??? LOST
  229. Repair Floorboard???
  230. which size draglites???
  231. what does this part do?
  232. Electric fan switch
  233. 94-95 GT MC quesiton...5-lug swap ?
  234. Rearend noises.... Help
  235. Mustang Flooding Itself
  236. Aluminum driveshaft install
  237. Rings for a 347
  238. Long tube headers
  239. quick h/c/i question
  240. Idle problem
  241. MOVED: Newbie Bastard with Pics...
  242. She blows but I don't get any
  243. Firing Order
  244. Rack Limiters/Control arm rubbing
  245. timing marks off??? possibility
  246. c4 flexplate question
  247. Heres what Im thinking.....
  248. how to choose a cam
  249. Supercharger
  250. What would cause my car to smoke?
