View Full Version : 5.0 Mustang
  1. check engine light
  2. MOVED: Synthetic or non?
  3. quick question, see who can fill in the blank
  4. drag spring install
  5. iat sensor
  6. smog pump
  7. AOD to C4
  8. tweecer opinions
  9. MOVED: Buddy just built a 92 sluggo
  10. MOVED: What rims should I get?
  11. c-clip elims and disk brakes question
  12. 90/10 or 70/30's
  13. MOVED: Ooops....
  14. new pistons
  15. Cap and rotor...
  16. Clarify...99+ calipers on 88
  17. stock valve covers
  18. Megasquirt
  19. MOVED: Lots of new mods, when to upgrade fuel? (i searched)
  20. MOVED: Can anyone show me?
  21. chirping
  22. MOVED: New goal
  23. I read the codes on my 5.0 and got these...
  24. MOVED: TORN BETWEEN TWO PONIES
  25. would you trust this part
  26. Vacuum leak, got me stumped
  27. Need everyone's help on this one....
  28. harmonic balancer question
  29. 86 bronco part?
  30. Explorer Heads
  31. ?? for people with 5 speed swaps
  32. Purchasing a 5.0 fox.
  33. 225/50/16 ok?
  34. Deep Dish 17x10.5 bullitts
  35. cam ?
  36. MOVED: Can this run a 10.99
  37. programer for 90 fox
  38. what is so good about using 4cyl front springs?
  39. Battery relocatin help
  40. anyone running this fan controller?
  41. what cam
  42. MOVED: Rims, Dubs, D's
  43. MOVED: stangs in northern virginia
  44. T5 QUESTION?
  45. A/C & Heater delete question.
  46. Do I need a new fuel level sending unit?
  47. 92 mustang interior help?!?!
  48. are hoods interchangeable?
  49. what size tires can i fit on the rear of a 91 lx?
  50. Replacing valve in head
  51. Two questions prostar / smoke
  52. car wont hold a charge....
  53. Astro Performance T-5 opinions, 408 with 11:1 comp making power to 7200 rpm
  54. PMAS GOOD BAD UGLY?
  55. Need help w/ 94 Mustang 5.0 conversion
  56. Speedo cable woes...need help asap
  57. MOVED: Just bought a 94GT
  58. 88 LX mods
  59. map light woes...
  60. Driveshaft length question/help!
  61. supercharger intake hose
  62. Cam comparison - e303 vs cs1085r
  63. Flywheel part numbers
  64. im stoked! got my setup now......
  65. Do hedman headers always fit like crap?
  66. electric fan
  67. rear end
  68. Upgrade fuel pump? Simple yes or no.
  69. MOVED: n-21 cam sound clips?
  70. what kinda gears do i have?
  71. Pony Dash Emblem Help
  72. need help
  73. engine hoist help
  74. distributor help please
  75. 3.8 to 5.0 Engine Mount
  76. Urgent water pump problem
  77. GT-40P headers question
  78. anyone know if 99-04 seat covers will fit my 95?
  79. new mustang owner question
  80. Dipstick!!!!!
  81. header bolts ?
  82. upper intake connections
  83. QA1 Coil-over vs. Other
  84. H-Pipe Question
  85. what the hell?
  86. Trickflow H/C/I with Speed Density
  87. Help with vacuum reading
  88. exhuast advice
  89. starting from the rear
  90. which subframe connectors
  91. anyone know where i can get a bolt that fits the cam shaft thrust plate?
  92. injector/fuel pump upgrade?
  93. Starter engagement problems
  94. Intake Parts
  95. 5.0 engine build
  96. patriot of procomp heads
  97. low voltage
  98. MOVED: gt5.0 vs. rsx type S 05
  99. squar fuel tank/ with sump
  100. well today was hell
  101. Just bought my 2nd 5-0, help me get back in the game
  102. Er... power steering fluid?
  103. what should i do
  104. best intake mani
  105. power gains-cobra top end???
  106. Input needed
  107. Cali Smog Sucks!
  108. slugish of the line... help please...
  109. vacuum line? (pic inside please help)
  110. What would you do
  111. Air pump problems
  112. 13 INCH COBRA BRAKE CONVERSION HELP
  113. B&M hammer shifter/shafty mechanic
  114. how will it run?
  115. suspension chime in
  116. 5 speed swap ?
  117. 40 Series Delta Force Race Mufflers
  118. Fuel Pump Install Problem
  119. alignment specs
  120. rocker arms
  121. 5.0 non HO VS. 5.0 HO
  122. speedo question please help
  123. gauge cluster speedo funny
  124. oil pan
  125. 1988 Guage Problems?
  126. Will these fit?
  127. pedestal rockers???Please help
  128. whining
  129. Need some advice with headers
  130. Installing 4 barrel TB
  131. A/C only blows
  132. mustang question
  133. how do remove the motor mount on the driver side?
  134. Fuel Pressure.?
  135. 351W intake and T5 boltup?
  136. Tech Article on fooling your incoming air temp, can't find it
  137. help with window motor install
  138. electric fan push or pull
  139. gasoline question
  140. AOD??
  141. Tuner Chips for 95 Mustang GTS
  142. head flow
  143. driveshaft
  144. is anyone running a paxton novi 1000?
  145. MOVED: Good deal?
  146. Well i'm back with something new to build.
  147. Computer (SD) controlling electric fan?
  148. does ford rebuild a9l?
  149. replacing heads difficult?
  150. 1993 GT Overheating
  151. new radiator before heads?
  152. wat do u guys think gasket or tube? coolant leak
  153. a few questions...
  154. new clutch
  155. quiet electric fuel pump?
  156. bbk exhaust
  157. need a quick fix
  158. oil pressure guage
  159. heater/ac vent question...
  160. FMU question
  161. Switch Panel
  162. BAD IDLE FIXED PART 2 General Info
  163. 10* Timing and it still pings with 93 octane- Help
  164. MOVED: carpet color help
  165. T-5 is quitting me? Any Suggestions?
  166. Oxygen sensors
  167. Shocks/springs
  168. Emissions Help!!!!!!
  169. 94 stang 5.0 new oil pan
  170. MOVED: any idea what color this is?
  171. idle problem
  172. MOVED: how much should i ask for it?
  173. engine code
  174. n/a hp and torque on sn95
  175. little prob
  176. 1994 mustang GT 5.0 auto>5 speed swap
  177. Trying to retard timing in a 94
  178. help pulling motor
  179. What to do if engine is ticking
  180. What size MAF is best for my application
  181. 86 top end rebuild problem
  182. Battery Issues
  183. Weld 15x8 backspacing & Bolt pattern
  184. MOVED: is this a good deal
  185. Vibration--HELP!!!!
  186. Over heating!! : (
  187. i have a 7,5 rear end and i want to switch to a 8.8 wht do i do
  188. Scat stroker kit
  189. Mechanical vs Electric
  190. Potential Fox Build. Questions?
  191. auto x
  192. 73MM or 76MM MAF?
  193. Luberacating ball joints
  194. engine temp problem
  195. Stroker questions for night owls- HELP!
  196. body help
  197. WTF HP PER CYLINDER
  198. 347 motor oil
  199. MOVED: body work
  200. body work
  201. Cam
  202. 347 with Gt-40X heads
  203. Whered you mount your MSD box....
  204. Loud Whistle sound
  205. coil over suspension
  206. Tried search, nothing, 86 5.0 into 96 3.8 swap???
  207. Ring and Pinion
  208. 5 lug conversion kit?
  209. motorvation
  210. Vents won't work after heater core replacement.
  211. factory headers to aftermarket shorties??
  212. sorry, i meant "95" mustang rear rotors
  213. electrical problem
  214. Stator help
  215. err gears
  216. wiring an alternator
  217. MOVED: rear rotors on 05 mustang gt
  218. Fuse Problem
  219. Rearend?
  220. MOVED: WhoooHoooo!!!
  221. trany question
  222. Which Way to Go?
  223. 5.0 Carburetor Adjustment ??
  224. Buying 5-lug drums...what do I tell them?
  225. Frozen spark plugs
  226. MOVED: Is this worth it?
  227. Oil pressure question
  228. T5 'stuck in 3rd'
  229. Dash light
  230. engine specs
  231. trick flow head
  232. Has anyone ever heard of oval port heads?
  233. tachometer from MSD.....
  234. well the 351 c is goin in
  235. want to remove a/c from car.
  236. 5 lug conversion...worth it?
  237. how to test a o2 sensor w/ a multi meter?
  238. 10 second on motor
  239. steering help plz
  240. What's Happening??
  241. fuel pump relay?????
  242. Supercharging a 95 mustang
  243. big problems.
  244. Tremec 3650 behind a 5.0L ????
  245. Handling...
  246. Disapointment Wow
  247. bad sound when wheel turns
  248. Hydraulic to Solid
  249. electric water pump
  250. not running on all 8
