View Full Version : 5.0 Mustang
  1. MOVED: Anyone drive a mustang all year round?
  2. will these parts fit and are the worth it
  3. 5 lug swap
  4. move to 351c or stay 302??
  5. Turn Signal Switch
  6. Need help on Manifold decission
  7. Pistons installed crank wont turn
  8. backfiring problems
  9. Gears
  10. Starter keeps running
  11. Water Pump Question
  12. how wide of draglite can I go
  13. muddy brown coolant
  14. asking for trouble?
  15. GT40P
  16. no brake lights
  17. Mass air Question
  18. 160k miles on an SN95
  19. yet another typhoon intake question
  20. Car dies with the A/C on.
  21. Block casting Number
  22. poping/squicking noise in the steering
  23. my fuel pump still wont kick on
  24. Clutch Pedal
  25. 87-93 door panels in an 86??
  26. Clutch
  27. quadrant problem?
  28. would anyone happen to have
  29. MOVED: slp loudmouth
  30. MOVED: Rough Ride To NJ...
  31. head question
  32. bigger fuel pump on 19pounders
  33. electric water pump
  34. Heat ?
  35. Can you help me identify this intake manifold?
  36. Why is this 5.0 so much slower now?
  37. broken tac
  38. mechanical fuel pump?'s
  39. fuel pump install
  40. MOVED: Buying 89' 5.0 worth it?
  41. rear needs to hold 600rwhp
  42. BIG PROBLEM, help me out
  43. tires 315s
  44. valves
  45. fuel door
  46. MOVED: RACE TIME NEED A QUICK ANSWER
  47. Any good speed shops?
  48. What's wrong with my car?
  49. radiator brackets
  50. guess to the redline of my stroker
  51. MOVED: i got a race tomorrow
  52. 225/70/15 how much will i be off on the speedo?
  53. torque-loc
  54. 88 GT problems while runing ?
  55. Odd Rattle sound on 93 5.0 LX
  56. fuel pump wont turn on
  57. Stripped Intake bolt
  58. harmonic balancer
  59. What will happen
  60. spark plug gap
  61. Reverse Light switch?
  62. What size socket do O2 sensors take?
  63. Door Hinge Roller Problem
  64. Coil making wierd noise
  65. car running lean?
  66. Cam Question
  67. MOVED: what you think
  68. car wont stay running? help
  69. 50oz or 28oz balance
  70. Thinking about 4.10s (MPG drop?)
  71. heater fan
  72. MOVED: nitto dr vs mickey thompson dr
  73. 331 Turbo
  74. Need some pics of this
  75. INTAKE HELP
  76. Piston Ring installation
  77. T5 Tranny
  78. slow start off
  79. fuel pump
  80. Compression numbers
  81. dart pro 1 vs. trick flow r series????????????????????
  82. Rear Main Seal Change
  83. I want to use an '85 flexplate on a rollor motor, will it work?
  84. sn95 Rear
  85. Do I need a hardened gear on my non roller distributor?
  86. headers
  87. Radiator help
  88. vibration at 85mph
  89. weiand supercharger
  90. SN95 Cobra Front bumper on GT??
  91. What intake is better for cobra
  92. fresh rebuild disaster
  93. Ran Engine Cylinder Balance Test
  94. 2 kinds of 19lb injectors?
  95. Which is Better for My 95????
  96. Diy turbos
  97. MOVED: its like the 5.0 anthem
  98. My 427 W idea...
  99. fox body axle shafts/ side gears
  100. Shift light
  101. where can i get a hogan intake?
  102. ram air vs. cold air
  103. 351 W
  104. exhaust ?
  105. 295/60/15
  106. electrical headache
  107. what size tire
  108. 347 buring oil?
  109. How Long to seat new rings?
  110. how to replace rear quarter panel
  111. Speedometer question:
  112. how do i find out if my crank is stock?
  113. cam install..!
  114. had to jump new battery
  115. is there any intake mani made specifically for sn-95?
  116. SBF gurus, O-ringed heads. Which gaskets?
  117. help please : how to improve throttle response/ aod
  118. making dumps?
  119. calipers rattling??
  120. 95 mustang gt new add ons?
  121. rims...?
  122. where can i get a intake for a 88
  123. need some help so i dnt get fvkd over
  124. pulled my motor
  125. EGR Valve Replacement
  126. what year explorer heads for 90 5.0?
  127. Are all O/R H-Pipe's the same?
  128. double hump crossmember
  129. problem with car starting up
  130. 100k miles on stock motor want to do H/C/I swap
  131. MOVED: buying a 5.0 looking for advice.
  132. H/C/I - will this work on a 347?
  133. how do you know?
  134. will 88-93 parts work on a 94?
  135. Mass Air Conversion Kits
  136. novi 1000 without a/c & smog
  137. springs for a vert
  138. 5.0 Thumpr cam
  139. starting issues
  140. Carb Question
  141. intake and head help plzzzz.
  142. aod on its last leg here are my options?
  143. leaking engine oil
  144. what would happen if....
  145. MOVED: I'm a Fu**** Idiot
  146. 91 lx rear end
  147. HEADS???
  148. MOVED: New owner and dyno #'s
  149. safty issues
  150. intake bolts w/ 1/2in spacer
  151. MOVED: loud
  152. DIY Rear Seat Delete
  153. MOVED: I got screwed.
  154. MOVED: installed 4 cyl springs/struts PICS and ???
  155. Cyberdine Digital Dash ?'s
  156. MOVED: Best HP Muffler for the $$$$
  157. MOVED: Emissions in PA
  158. MOVED: How much for a TKO 600?
  159. Loud {HISSSSSSINNNGGGG} Sound?
  160. some question but my new project
  161. Too small of an intake?
  162. 5.0 Emblem
  163. Caliper Bracket Bolts
  164. 500 hp 5.0?
  165. gonna seafoam my car
  166. welds with 13inch rotors?
  167. Cable dipstick for 5.0
  168. 306 ?s
  169. Can a fan cause A LOT of vibrations?
  170. my top is stuck, rather urgent
  171. 5.0 mod ?
  172. 5.0 Project, Need Help and Opinions!
  173. is it worth degreeing the stock cam?
  174. cast iron heads
  175. dipstick breather?????
  176. need 95 5.0 input
  177. MOVED: Pricing out some parts. What should I ask?
  178. electrical gremlins
  179. Hole in Trick flow intake
  180. are the 5.0/2.3/94-95 throttle cables the same?
  181. 3.90 gears..Are they right??
  182. what kind of cam for my common setup!
  183. Need help with Ford Racing A/C Delete
  184. Will I run out of gear at the 1/4?
  185. a hard question without a lot of details yet
  186. 93 gauges in a 69
  187. new dash
  188. ignition coil noise
  189. Another how much power and will my tranny last post
  190. going c4
  191. 351 or 302?
  192. control arms
  193. a0de to t5...?
  194. headlight switch
  195. TFS stage 1 cam or FMS E-303
  196. brake question
  197. Strange idle problem PLEASE HELP!!
  198. 351 windsor heads
  199. electrical issues
  200. a4od to a t5....?'s
  201. springs on a vert fox
  202. tranny swap?
  203. Suspension Setup
  204. 302 Beefing
  205. tranny noise from bellhousing area
  206. exhaust question
  207. fuel pump problem
  208. turbine rims
  209. turbo or supercharger...?
  210. Sparatic Misfire - HELP!
  211. performance automatics
  212. Pre detonation
  213. spout check connector?
  214. tool for 302 heads???
  215. right cam for the job
  216. Transmission wont go back on
  217. MOVED: Distributorless ignition install - update
  218. throttle cable
  219. Remote oil filter kit
  220. Mid 13's
  221. What does the mass air flow meter do?
  222. Hey guys
  223. I want another mustang!
  224. Long Tube Header sizes
  225. engine help.......
  226. radio problem
  227. another valvetrain question
  228. Havin a charge issue
  229. 306 or 331
  230. Fuel Cell Question
  231. How is fordstroker with there kits
  232. MOVED: dynojet
  233. is this bad
  234. what mileage
  235. 88gt dash in 86 is it plug and go?
  236. 89 lx moldings
  237. New springs ! Still leaning!!!!!!
  238. comp test is 140 ok???
  239. headers
  240. 5ive lug conversion
  241. exhaust sealer?
  242. Popping and heavy hesitation...
  243. Factory Radiator Material
  244. 1985 Mustang as a Project
  245. 351 - 302 INTERCHANGE???
  246. what valve covers to get?
  247. new h pipe
  248. Powerglide?????
  249. Engine Code help
  250. help installing msd 6al on a 93 5.0
