View Full Version : 5.0 Mustang
  1. MOVED: NMRA pure street rules
  2. MOVED: WTB! pms
  3. 89gt cobra no spark
  4. flushing the whole coolant system
  5. t5 swap from an AODE in a 94 GT conv.
  6. 400hp and streetable?
  7. Losing coolant, heater core???
  8. converting brakes an dtranny problems pls help
  9. clutch cable adjustment?
  10. Idle going crazy and jerking/bucking
  11. ive decided
  12. 2k RPM at 60, gears?
  13. 347 or 308
  14. lowered, tires rubbing
  15. New car, new path?
  16. general oil pressure
  17. I hit the jackpot!!
  18. 460 in a 93 notch
  19. bumper support HELP
  20. Installation?
  21. Clutch Help!
  22. Bought some GT40P's: a couple questions
  23. E Fan Setup's... What are you guys running?
  24. Progress:
  25. MOVED: what are you notch guys paying?
  26. MOVED: I highly recomend the "air adjuster". Fixed my idle and drivability problems
  27. still having problems
  28. Fluidyne Users HERE!
  29. identifying numbers on stock 5.0L
  30. BBK X-Pipe for AOD
  31. The best Heads for the buck???
  32. drag radials or slicks on ten wholes?
  33. These any good?
  34. Spark plugs
  35. MOVED: Car is Finalllyyyyy Painted, pics
  36. I gotta problem....
  37. 5.0 swap
  38. Is this bad?
  39. i need help
  40. hatchback VS notchback
  41. speedometer off
  42. If you think you know your AOD's, speak up.
  43. please help me!
  44. Low Coolant Sensor
  45. where is my window relay
  46. Unplugged Mass Air - Should car die?
  47. 1989 Power Door Locks
  48. OBD I OR II??
  49. Need help programming ZEX window switch
  50. AOD options
  51. EEC Tuning Tips UPDATED
  52. aod 1 piece input shaft question
  53. best intake manifold
  54. Engine rocking
  55. exhaust
  56. still having problems
  57. throttle body idel ?
  58. Where can I buy TPS Screws from?
  59. DRI WASH 'n GUARD(R) Special for Forum Members
  60. Car is burning rich?
  61. Air bag light
  62. AODE to AOD???
  63. 31-Spline 3.73 gears from an '01 Mountaineer?
  64. All the sudden, running like ****...
  65. CARB OR FI?
  66. Running Hot
  67. What else do I need to replace
  68. fuel pump questions....
  69. 15x8 prostars
  70. venom 400 control module
  71. sluggish when cold?
  72. probly an easy cobra question
  73. Bearing replacement
  74. Bearings
  75. Injectors rebuild
  76. List of what I need for H/C/I
  77. rubber plug?
  78. Aluminum driveshaft U joints
  79. k-member
  80. rad/coolant filters?
  81. main bearings
  82. diaphragm leak
  83. help with signals...
  84. gear drive timing, anyone using them here?
  85. Tranny Problem
  86. diameter of a 351w lifter bore??
  87. LONG BLOCK AND SHORT BLOCK????
  88. the t-5 finally broke
  89. MOVED: Hello!
  90. Best Underdrive Pulleys?
  91. 1993 fox body 5.0 vs 1995 5.0
  92. in need of a cam
  93. MACH 460 Problem!!
  94. quick question..help
  95. Burning smell
  96. P/S relocation
  97. line lock
  98. Will my car run ok if I put stock stuff back?
  99. What sizes
  100. Tranny Bellhousings
  101. Cam question
  102. Digital 6 hookup
  103. Bad Idle Part 1 *FIXED,MUST READ * New 5.0 Discovery
  104. new car with problem
  105. balancer
  106. cooling problem....
  107. IAC valve
  108. DOES STEADA..?
  109. ? about a hci w/ SD
  110. clutch cable..?
  111. MOVED: well....
  112. MOVED: fully built fox-would it be worth 10 grand?
  113. Carburetor Whistle
  114. Exhaust question
  115. Exhaust info
  116. what is the wheel horsepower on a stock 1994 5.0 AODE
  117. car wont start
  118. AODE transmissions
  119. hci
  120. switching to a carb?
  121. glasspack mufflers
  122. snow boost cooler
  123. Hatch Support shocks
  124. hey 5.0 guys
  125. Plugging MAP vacuum line
  126. a bad day
  127. 429 swap
  128. another smog pump question?
  129. Replacement bolt for the air box?
  130. What is the best H/C/I setup with: Vortech s/c,Full Exhaust, 3.73's, Auto 94 GT?
  131. Exhaust set up-Your Opinioin?
  132. Clutch
  133. windows wont work
  134. solenoid clicks an car doesn't start
  135. What size rivet for door actuator?
  136. Now I'm Pi$$ed!!!
  137. I need help identifying these parts
  138. good suspension
  139. need to replace front rotors
  140. c4 to aod
  141. 331
  142. turbo size
  143. wire size for fog lights...
  144. 89 LX 5.0 misses at cruise speed (only)
  145. N-41 & N-412 cam ?
  146. where can i get a washer for a 3g alternator to put the old pulley on
  147. Doner parts
  148. Could use some help
  149. Proform wiring help
  150. MSD TIMING RETARD BOX! help
  151. need help. pics included.
  152. TOP????
  153. black smoke!!!!
  154. MAF importance...
  155. Top Header-to-Hpipe bolts
  156. MOVED: Should i keep her?
  157. 95 mustang gt
  158. 30 39 42lb injectors??
  159. wat size piping
  160. dashboard swap
  161. cobra intake a direct bolt on?
  162. Thrust Bearing Cap question.
  163. rear axle seal??leaking
  164. How Much Horsepower - Just got a COBRA INTAKE MANIFOLD
  165. 351 in my hatch (yes ive searched)
  166. Tranny Cooler
  167. clutch pedal makes racheting noise
  168. coil
  169. Car seats
  170. car slugish
  171. axle tag
  172. Rough Idle after Smog
  173. Extremely Weird Problem
  174. Anybody using the Paxton SL (self Lubricating) superchargers?
  175. 83 mustang question
  176. Transmissions
  177. vacume line question
  178. fog light switch....
  179. Rear suspension question
  180. HELP: thermostat
  181. Clutch time
  182. rear again?
  183. Supercharger Options
  184. carpet...
  185. choked engine & back fires from the engine
  186. .550 lift is tough on retainer/guide relations
  187. Electric Fan Setup....
  188. Battery Relocation Please!
  189. 4cyl to 5.0 transmission question:
  190. AODE problems
  191. rear end
  192. anyone have a stock fuel pump?
  193. Turn the key and does not start???
  194. Transmission fluid??
  195. Oil leak??
  196. IS IT TRUE
  197. got a 83 stang have question
  198. Window Fails to Go Up all The way - How to fix
  199. Holly Systemmax II
  200. how expensive is it to do a 5lug conversion?
  201. megasquirt II tunes
  202. Neutral Safety Switch Please Help!
  203. Intake manifold???
  204. FR Steering Shaft Help
  205. very dissapointed.. need advice
  206. nitrous, methonal injection, boost cooler
  207. what 3rd member has 3.73's
  208. supercharger pulley????
  209. fogs light illegal!
  210. Draglite
  211. 95 Front crash sensors
  212. rev limiter?
  213. msd cap and rotor
  214. alternator bracket
  215. that little red wire
  216. no cruise control
  217. Tensioner bracket
  218. Pics and a question:
  219. water pump
  220. turn signal frustration
  221. Power steer pump bad?
  222. small 3G alternator?
  223. another tire question
  224. firewall adj. help
  225. Almost Positive its a miss now
  226. MOVED: 1989 5.0 LX
  227. 94 performance help!?
  228. New Problem
  229. turn signals not working
  230. gangsta lean?
  231. Flowmaster catback- hits everything
  232. power loss after warmup
  233. best cold air intake?
  234. balancing rotating assembly?
  235. heads question
  236. Squeeking noise...
  237. Explorer intake
  238. 5l swap wiring help
  239. 8.8 parking brake
  240. torque specs on intake
  241. bumping up the timing
  242. torque box reinforcment
  243. cracked block? warped head? what?
  244. bad vibration
  245. How can I get 400 HP out of my mustang?
  246. MOVED: FINALLY GOT MY 5.0
  247. headers
  248. EGR eliminator plate? How does that fit?
  249. X or H Pipe IMPORTANT!!
  250. Compression stock 302
