View Full Version : 5.0 Mustang
  1. Clutch feels too tight.
  2. Interchangeable Alternator Years
  3. harsh idle
  4. fan and radiator set up for me
  5. CFI to Carb (works but with issues)
  6. Broken Oil Dipstick tube
  7. helllpppp
  8. HELP!
  9. noise
  10. cowl hood suggestions
  11. What kind of oil fluid is needed for standard on a 1988
  12. Fender bowed out
  13. How to ID FRPP "B" springs
  14. what size are strut bolts on 89 mustang lx?
  15. Transmission build
  16. High-idle
  17. Powerdyne supercharger Crank Pulley Size
  18. 1992 GT sagging rear-end
  19. turbo the 5.0
  20. fuel/ecc problem
  21. building for RPM?
  22. Vibration/Rumbling in rear driver's side area
  23. Fuel Pressure Regulator or Fuel Pump?
  24. Trick Flow Throttle Body
  25. Just want to make sure these lifters will fit
  26. 87-93 Where Could I Get This Bumper?
  27. Would a transmission from a 1988 5.0 work on a 1979 302 engine?
  28. steering wheel quick release
  29. what numbers should be on gears if i got 3.55 or 3.73?
  30. Reusing stock intake bolts for GT40 intake?
  31. Pro Electric Help PLEASE
  32. Air bag Light
  33. BUMP STEER
  34. tko 600 issues need advice
  35. Tranny Problems
  36. motor not running right
  37. Rear End Question
  38. 347 stroker problems
  39. Need Help Picking Best Spring/Strut Combo
  40. Another part to cooling saga
  41. timing question with pic
  42. intake clearance
  43. Hanging RPM and Inconsistant Idle
  44. Upgrading Dash Back Lighting?
  45. Goodyear Gatorback 225-60-VR60 Tire Question
  46. ingector rack
  47. rear end
  48. Fuel pressure
  49. fuel preasure
  50. quick help-working in garage-lights
  51. dual sump oil pan?
  52. widest tire
  53. Battery Cable and Starter Solenoid
  54. AOD to C4
  55. Question about a T5
  56. Cfi to carb (dies after start up)
  57. MM Roll bar?
  58. quick valve spring question
  59. E-brake is really weak
  60. coolant mix
  61. holley vs. cobra
  62. Charging Battery
  63. car running hot
  64. 1984 Mustang Power issues (electrical)
  65. moaning in rear at highway seeds
  66. Problem after adjusting stud mount roller rockers
  67. lube speedocable
  68. tire and non technical questions?
  69. need answers about mid pipe, headers, intakem, cam etc!!
  70. Did the sn95 to Fox computer conversion and now:
  71. What do the mustangs redline at?
  72. Air intake...
  73. Turbo Kit Question?
  74. Car won't shift into any other gear but 4th. What could be the cause?
  75. I have a altenator question???????????please help
  76. Electric Water Pump
  77. Sealing an oil pan
  78. water pump ?
  79. Check Engine
  80. too much wheel hop
  81. California Cats
  82. tuner
  83. need help!!
  84. plug size
  85. which vehicles and years have gt40's?
  86. possible purchase need your thoughts
  87. Breaking Clutch Cables
  88. starter issues
  89. car body shifting
  90. Time to make it Faster
  91. Oil Loss
  92. clutch cable
  93. paint matching questions
  94. What adapter for temp gauge in Victor jr. intake?
  95. t5 shifting problem-please help
  96. MM K-member
  97. '87 AOD w/ no upshift to 3rd
  98. not to sure.......
  99. headlight problem!!
  100. idle problem
  101. Stock heads or gt40 heads?
  102. Just bought a taurus fan, need some help
  103. cats or no cats?
  104. what type of trans?
  105. 1993 Notch and wheel hop
  106. Looking to buy an aluminum radiator
  107. ratchet and Auto in a 94?
  108. Choking up the engine
  109. question about heads!?
  110. Key Ignition Help
  111. tremec 3550 shifting
  112. A/C problem please help!!!!!
  113. hesitation
  114. Fuel milage got worse
  115. need help buying a new distributor
  116. Ran into a big problem with k-member
  117. Thoughts on possible exhaust setup
  118. Wondering What I am Supposed To Do Now???
  119. 91 5.0 swap into 94
  120. smog pump???
  121. competition engineering drag shocks/struts
  122. Need to find 02 senser
  123. twin turbo's
  124. under drive pulley kit
  125. Does anyone know?
  126. Vibration in the drive train
  127. Aod rebuild...help
  128. ***** 83 MUSTANG GT ENGINE SWAP TO 06 ROUSH STG 3***
  129. How do you tell if your car has a chip?
  130. 69 with a 5.0 backfire problem
  131. hp goal. hope u guys can help
  132. Best fiberglass Cowl hood?
  133. help!!!! i need advise
  134. 550hp 408w 1999 6 Banger
  135. need help with lighting asap please
  136. new intake mani (carb) question
  137. IDK the difference gt40 and gt40p heads?
  138. fuel rail How to disconnect???
  139. newb question
  140. Clutch
  141. GT 40 Heads $100 Off 97 Ex. Should I Buy Heavy Pics?!
  142. INTAKE MANIFOLD BOLTS
  143. Starter Issues 351W
  144. should i replace the lifters?
  145. 5.0 from an 87 Lincoln Towncar
  146. BBK SSI-R!!!
  147. Removing Quad Shocks?
  148. cylinder head choice for 306
  149. sn 96 spindles
  150. Eagle ESP Armor?
  151. My car is Vibrating. Any help?
  152. aero to 4eye question
  153. high speed fan
  154. Ready For BEEF??
  155. Gummy clutch and low friction point = fork/bearing
  156. Eletrical Problem maby?
  157. burning coolant! need some help.
  158. Question about my edelbrock heads
  159. Need mechanical help/advice
  160. Turn signal issue
  161. suspension ???
  162. Rough Idle and dieing
  163. transmission problem
  164. Can't run 14* timing anymore...wtf???
  165. are these LCA's a good purchase?
  166. How does the horn pad come off?
  167. help me please
  168. 1994 GT 5.0
  169. AMMETER NEEDLE IS JUMPING
  170. Some issues with my Fox
  171. A9P/A9L
  172. clutch fork cover
  173. speedo prob
  174. ROTM
  175. shifters
  176. INTAKE BOLTS
  177. new clutch, which one?
  178. snapped the centre pin bolt!
  179. finding out what computer i have.
  180. camshafts?
  181. 1995 Ford Mustang GT 5.0L
  182. Computer Upgrade
  183. A Few questions from a newer stangbanger.
  184. excess crankcase pressure!!
  185. I want some 1.7 rockers
  186. mustang gt auto 87 mustang gt 5 speed & motor swap help please asap
  187. vacuum?
  188. Radiator Replacement Suggestions?
  189. did my H/C/I project, whill a perf. chip make any difference?
  190. How do i adjust timing?
  191. anybody ever heard of running a plug wire the opposite way
  192. FORD RACING PULLEY'S
  193. what to watch for?
  194. new dizzy problems
  195. Blueprints for Solid Motor Mounts
  196. Rolling your rear fenders
  197. Transmission ??
  198. car wont' stay on...
  199. 347 heads on 302
  200. A Few Electrical Problems
  201. Which Radiator, Is 2 1 inch rows enough. Be Cool? or 2 1.5 inch rows?
  202. Only Power to Windows and Fuel Pump while cranking it over
  203. stock 5.0 What is the best position for the distributor?
  204. stock 5.0 is running rich? Need some help here
  205. Vacuum stall
  206. Question about o2 sensor...
  207. Mass Air Conversion
  208. BEST WAY TO SEAL INTAKE
  209. Head swap
  210. should i buy this motor
  211. a few questions
  212. 88 GT
  213. tweecer rt on a d1sc
  214. I COULD USE SOME HELP.......
  215. whats your favorite cam?
  216. Pinging and smoke just went away?
  217. Gummy clutch pedal moving friction point
  218. Cutting out under load
  219. Steering wheel and dash shake @ 65mph +
  220. Steering Rack Issues
  221. How to tell if I have gears?
  222. Ford Racing Distributor Gear
  223. 84 MUSTANG, 5.0 NEED HELP STARTING
  224. Carb valve covers on EFI?
  225. block check
  226. rear tires keep rubbing HELP
  227. Whirring or whining noise
  228. Hooker
  229. deleting smog and egr? and other questions
  230. will all this work for cfi to carb?
  231. Electric fan over stock fan
  232. Need Egr Help
  233. 427-428ci block in a 95 gt?
  234. Coolant spewing out of the reservoir
  235. Supercharged-Elbow vs. Upper Intake manifold?
  236. Hunting idle/IAC ??
  237. DIY 5 lug conversion
  238. Valve Spring Decision
  239. intermittin bogg issue
  240. Car stalls when idle in drive
  241. best places to use loctite
  242. High speed shifter vibration still
  243. i need help
  244. Oil Pan to pickup clearance
  245. New member and i need help!
  246. Rattle in my shifter?
  247. test drove a car, won't stay running
  248. where an i get this? i've looked all over
  249. High Idle
  250. GT40 intake gaskets help!
