- Flowmaster catback- hits everything
- power loss after warmup
- best cold air intake?
- balancing rotating assembly?
- heads question
- Squeeking noise...
- Explorer intake
- 5l swap wiring help
- 8.8 parking brake
- torque specs on intake
- bumping up the timing
- torque box reinforcment
- cracked block? warped head? what?
- bad vibration
- How can I get 400 HP out of my mustang?
- MOVED: FINALLY GOT MY 5.0
- headers
- EGR eliminator plate? How does that fit?
- X or H Pipe IMPORTANT!!
- Compression stock 302
- running no 02's question
- recent idle problem
- Oh Crap! Intake help!
- Throttle body setup
- turning radius
- Motor Mounts!!!!!!!!!
- 5 lug conversion
- B+M shft improv.kit??
- cam specs
- 6al question
- comp polymers?
- idle problem??
- Harmonic Balancer
- front end
- 2.5 2.25 3.0 what is stock on a 91 mustang gt rack and pinion?
- '90 mustang LX 5.0 OBD1 Connecter?
- injector size
- Cams, cams, and more cams.
- MOVED: What t5 shifter are you using?
- Mass air flow meter question!!!!
- Shocks, struts, and springs . . . oh my!
- FK-35 Install help
- MOVED: anyone know what would be the best lubricant on wheld wheel lugs??
- tranny
- bigest stroker w/o boring
- Motor mounts...
- Steeda #19 Questions
- MAF questions
- BBK Throttle Body Gasket Set
- Bad Alternator?????
- Another electric fan question
- Best Size throttle body and mass air meter
- bbk intake question
- 1976 Mach 1
- Need a special tool to take of Fuel Filter?
- 5 lug conversion
- Need help pulling gauge cluster out
- ALUMINUM RADIATOR AND PRESTONE RAD FLUSH
- Liberty tranmission parts
- SUPERCHARGED MUSTANG
- 93 Cobra Help
- vacuum tree
- Dash upgrade?
- shift light help
- Need Timing Help
- WTF is wrong???
- What Carb
- cam? not about which profile
- Rear brake conversion?
- how big of a shot
- Steering Wheel Help?
- 93 cobra air intake
- Eibach drag springs
- fuel guage problem
- most common problems with foxes?
- high rpm backfire
- Anybody exceptionally good with engines?
- 2 questions
- EGR removal
- Fuel Pump (?) Question--And a Wierd Coincidence? Diagnostic Challenge?
- E-303 in a 95 GT
- 87 Mustang GT won't start
- Possible Misfire?
- 24lb injectors maf for 30's
- CLUTCH HELP
- tfs efi hci kit
- Anyone Not Running Smog & PS ???
- MOVED: 11 Second Street Car with Stock Black and Cam?
- suspen?
- how long will this last trying to go 10's in my 2800lb sn95
- Help with wheels for 93 Notchback
- MOVED: This is my dream mustang... Check this out
- carb conversion almost complete
- wont idle after tb install
- patriot heads.
- Mufflers and H-pipe vs X-pipe
- Short Block
- MOVED: Looking for a 91LX 5.0
- valve spring help
- buying 3.73s this friday need advice
- MAF Advantages?
- The best HCI combo for under $1800 ?
- need help question about belt size?
- MOVED: Looking for another mustang
- 7.5 Rear end
- Hooking up an engine?
- MAF Conversion
- Fuel Line **PICS INCLUDED** help!!
- smoke on startup
- what would you do?
- shock question
- 93 COBROA INTAKE GASKET SAME AS 94 FIT??
- Problem - Setting Timing with a "Timing Light"
- Power Window Switch Oddity
- anit-lock light??? 94 gt 5.0
- window wiper help????
- STEERING WHEEL ADAPTER
- patriot heads
- MOVED: Whats a fair price??
- maybe im just dumb but need your help 3g upgrade
- gonna stay with the fi
- is this worth it?
- DOG BONE? for 351w?
- MOVED: 351w Guru's Help!!
- starting problems
- MOVED: 351 (427) gud idea??
- Smog delete .. what size belt would i need.
- Question about slicks
- Can a speed density computer have a check engine light/
- wheel hop
- under-carb'd
- afr heads
- puttin the motor together...im guessing pump gas is a no-no
- Swapping in motor, unsure of cam
- PICS! choosing to repair my vert or get another
- Harmonic balancer.... and rear end
- MOVED: used parts?
- Nitto Drag Radial Help
- Have MPH gauge problem 10 to 15 off and bounces
- Motorcraft spark plug wires?
- motor mounts
- engine codes?
- Oil pan gasket???
- help me
- Cylinder Heads comparison
- Couple issues
- K-Member help with steering install
- 85 or 92 stang?
- 93 cobra intake for 94 5.0 direct fit?
- 160* thermostat
- My new Fox Overheating...
- replacing valve guides in heads?
- Headers and exhaust
- help with building a motor
- fuel pressure release
- quick question
- balancer
- 92 bronco 351 heads
- trickflow or edelbrock??
- surface rust and ? about bearings
- Base idle Question?
- front suspension kit>?
- How easy is this to fix?
- Vibration question's--
- aod guys with 4.10s
- cat back suggestions
- tires
- Quick Underdrive Pulley Question
- HELP
- texas smog laws blah!
- Differences in 1986 wiring harness? Check engine light wiring help needed.
- has anyone installed those window retainers from 50 resto
- T-5 Inputshaft
- first time at track, how well will i do with my mods.
- New clutch
- stalling
- Steering Problem
- cooling concern .. 95 cobra
- coil
- Beeping sound
- lsd
- Tech related pics needed for 3.8 fan
- smoking out vents on valve covers
- Need assistance...
- 89 steering wheel removal
- Mass air conversion
- summit headers
- Terrible gas mileage question
- RIGHT REAR LEAKING?? 84 GT 5.0HO
- transmission came with?? 94 gt 5.0 ho
- Power loss
- do only gt's come with trac loc rear ends
- which intake
- need rear end spec so fast that its not funny.....
- buying an 87" 5.0, what to look out for
- Spark Plugs for a '94 GT
- help...!
- which supercharger
- bbk x pipe ?
- modifications
- AOD transmission question
- Are these heads any good?
- Replacing Door Window, NEED HELP!!!
- are these heads any good? (never heard of these)
- gt40--cobra vs explorer
- Important Transmission Question
- transmission question
- 30lb injectors with 347
- got caught in storm now car running bad
- 347 with a9 ecu?
- speed bleeders
- gauge lighting
- any one know how to ID a borg &warner trans
- Codes Help
- help 331 stroker w/s-trim supercharger
- H.O. questions and 95 gts
- MOVED: afr 165
- MAC Coated Unequal Length Shorty Headers -- any good?
- dallas speed cal
- Power Loss
- What Kind of Coil OVer springs 2 get?
- A few quick questions.
- Need a parts list.
- Help Oil Pressure
- Lightning injectors & MAF on my 5.0
- gt40 heads question
- MOVED: neew whip
- Head Valves
- Whirring noise coming from (I believe) the wheels..?
- Crunch into 3rd. w Vid
- Which supercharger to get Paxton or Vortech?
- MOVED: finally my car is finished after 7 months work! pics look
- rear end
- EVER SEEN THESE?
- suspension
- maf question
- quick exhaust question
- 5.0L and 5.0 HO diffrence?
- Stuck an gettin you know what 3g alt swap need help!!!
- Nitrous - Common point of detonation?
- lower control arms
- New here, getting a foundation
- Attention Lowered Mustang Users
- new rockers or new cam
- HELP PLEASE!!!!!!!!!!!!
- Motor HELP!!
- 347 w/ Eagle Stroker, what type of head
- replacing springs
- clutch
- One more HCI question..
