View Full Version : 5.0 Mustang
  1. h/c/i combo/ input plz!
  2. Converting from Fuel Injection to Carb
  3. 3g pully ???
  4. Anyone Successfully swapped a 2.3 for a SBC
  5. t5
  6. EQUAL LENGTH HEADERS HITTING
  7. CLUTCH
  8. Fuel Pressure??
  9. which roller rockers to buy?
  10. low coolant light, but overflow is fine?
  11. Harmonic Balancer Install In The AM
  12. belt routing
  13. cleveland heads on a '94 F.I. 5.0?
  14. bay area engine mechanics!
  15. Lower intake gasket help!
  16. Can parts interchange? Mustang/Thunderbird
  17. shaker hood
  18. dart vs dss blocks
  19. Starter
  20. tire ?
  21. running hotter then normal
  22. HELP
  23. starter prob
  24. loss of power
  25. Can HID's fit in 87-93GT fogs?
  26. Smog Pump removal
  27. New owner-Engine cutting out
  28. Typhoon intake question?
  29. milling da heads?
  30. Plugs and Wires
  31. Looking for some input (Nitrous setups.)
  32. Driveshaft
  33. Header gasket- easy?
  34. 1990 rear end question
  35. wierd problem
  36. block question
  37. TPS differances
  38. fixing a seatbelt
  39. Harmonic balancer
  40. A little help here
  41. Super Charger?
  42. SN-95 Gurus! Question~>!
  43. very frustrated
  44. How easy is it to Run a Turbo on a Carb'd 351w Fox?
  45. Just a Thought, 4 cyl springs?
  46. 4 cyl springs
  47. Sd cam help!!
  48. Smog pump question
  49. stock trans limit?
  50. MOVED: TT 331 build pics
  51. auto to T5 swap article?
  52. distributor question
  53. problem with long tube headers
  54. 347 horsepower?
  55. Figured out my sticking throttle problem...
  56. ID a 302
  57. engine lift question
  58. 355s or 373s????
  59. 94-95 5.0 Underdrive Pulleys
  60. dropping front swap bar
  61. Electrical issue
  62. Help finding a good shop in South TX
  63. Bad Idle And Skaking At Speed....
  64. inside of car very hott
  65. EFI or Carb
  66. Will stock 99-04 springs fit a fox?
  67. starting the search
  68. Helppppp
  69. pulling trans and intake this weekend??
  70. Sqeeky lower control arm
  71. ZEX Install almost finished - Timing/Plug Questions
  72. holley alum. heads?
  73. How can i make this work?
  74. new to 5.0's want 300 rwhp
  75. bad throwout bearing?
  76. questiona bout cobra intake
  77. idle question
  78. comparing a 87-93 alternator to a 94/95
  79. c4/c5 vaccum questions
  80. switching to carborated
  81. SCT Chip for 94 GT?
  82. looking for a 5.0 project car. lots of questions.
  83. screwed on heads
  84. Strange acting car
  85. cobra intake
  86. Need rear gear/mph/rpm chart
  87. hot undercharging alternator
  88. how to hook up tach
  89. plug wires, rotor. cap related question
  90. sometimes starts then sometimes doent
  91. Car wont start
  92. MOVED: how much is it worth
  93. Smoking alternator, dead battery wtf???
  94. Hows this combo sound
  95. MOVED: Damaged 88 GT
  96. idle problems
  97. What went wrong
  98. injectors
  99. electrical problems???
  100. Fuel delivery problems
  101. E cam with 1.7s
  102. windshield washer nozzles...
  103. Clutch Disc for Centerforce DF Plate
  104. valve spring question
  105. 3 angle valve job help.
  106. Timing problem maybe more
  107. ZEX Wet Kit - Which wire to use on TPS?
  108. 347 Stroker Kit
  109. new and have some questions
  110. SN-95 front brake swap
  111. installing a posi
  112. What would be easier?
  113. another question
  114. GT fog lamp problem
  115. AFR 165's or 185's ??? who has them ???
  116. carb setup
  117. timing
  118. MOVED: got pix of the wreck want to sell the whole car!
  119. MOVED: im goin broke
  120. New Heads?
  121. need help diagnosing problem
  122. air/fuel ratio questions
  123. keep EFI or go to carb
  124. Resistor Trick = Horsepower???
  125. Wilwood Brakes
  126. 1990 INSTRUMENT CLUSTER HOOKUP
  127. Need opinion on motor
  128. Need an opinion on a motor and interior
  129. manual rack setup
  130. Leaking Intake - How Much Power Loss?
  131. gear questions
  132. MOVED: 86 GT RIMS
  133. do I have a cracked head or broken gasket?! Pleases help. it overheats!
  134. afr or gt40 heads?
  135. about the 3.73s
  136. Where to weld O2 sensor bungs on Tri-Y headers
  137. Decreasing Compression
  138. engine wiring harness and ecu help
  139. lowering kit ?
  140. IDEAS?
  141. MOVED: looking for sugestions
  142. lower intake gasket
  143. I must be bad at searching, but... torque spec help
  144. Starter Problem
  145. chip???? anyone know??
  146. Getting computer out???
  147. Getting arc off wires..HELP!
  148. overheating 5.0
  149. impeller carnage
  150. Trashed Tranny
  151. Same old problem
  152. just got 3.73s put in
  153. New aluminum radiator. Which one?
  154. long story..all input helpfull new to 5.0 world!!!
  155. Question on the 4eye front
  156. What are the differences between GT & LX?
  157. Plugs and fuel pressure???
  158. 93 cobra intake for 94????
  159. Which coil to use (Resistances included)
  160. synthetic oil Q
  161. Timing
  162. aod tranny question?
  163. strut tower brace
  164. help me spend my money....(yes its tech related lol)
  165. trans fluid
  166. Small suspension upgrade
  167. fuel line
  168. T-56 or built AOD
  169. Fuel Pressure at moderate acceleration?
  170. replace or fix radiator help plz
  171. Exhaust opinions
  172. Stock Track Width
  173. clutch chatter
  174. intake gaskets for head swap
  175. not sure what this sound is
  176. 5.0 spark cuts out when warm
  177. Kills in REverse
  178. Altenator Fire!!
  179. TKO500 OR 600
  180. quick question.
  181. injectors...
  182. compression
  183. WhiTch 1..?
  184. Cam compatable with 1.7rockers?
  185. fast air/fuel meter.
  186. Turbo Setup?
  187. AOD converter/vb question
  188. overheating after electric fan
  189. MOVED: Price check on a 95 GT MOTOR?!!?
  190. MOVED: new additions
  191. Calling electrical pros
  192. 1000 rpmplease help me with this motor idle problem
  193. Need some serious advice/opinions!!
  194. Motor
  195. 95 cobra intake..?
  196. Considering this
  197. car runs better with maf unplugged?
  198. speed density cam
  199. Cooling Help
  200. Vibration at 1,000
  201. short throw shifter
  202. BBK Equal Length Shorty Problems
  203. A lot of questions
  204. How to replace plastic gear in 95 GT odometer
  205. HELP!!! throttle sticking!!!
  206. fidanza clutch?
  207. Vibration/clunking when decelerating
  208. smog delete
  209. MOVED: I'mmmm Baaaaaaaaccckkk
  210. Several Questions
  211. Exhaust Leak please help
  212. Exhaust question???
  213. The "new" boss 302
  214. Installed 4cyl t5 yesterday
  215. This Could Be Bad....
  216. Help with KOEO and KOER codes
  217. Speedometer is not working
  218. 255 or 255 high pressure pump?
  219. odd electrical and starting problem
  220. 94 gt with 351w WILL IT FIT?
  221. smog pump and emissions
  222. MOVED: please help me to find out wht it will run at the strip
  223. Header bolts
  224. Installing front springs need help
  225. frpp vs. bosch fuel injectors???
  226. Mass Air Conversion
  227. wiring harness question
  228. Stroker question
  229. HP question
  230. automatic or manual
  231. what plugs are the best
  232. Manual steering swap?
  233. Engine knock on 95 Mustang GT
  234. Pistons 92 forged vs. 93 hyper.
  235. 911!!! Tranny Help
  236. Is MAF a necessity for power?
  237. list of stock parts
  238. Mass Air question
  239. gauge/lighting problem
  240. Headers Anyone
  241. MOVED: Almost lost my hood
  242. hello---new to 5.0 world
  243. Vacuum lines
  244. supercharger on stock 5.0 ?
  245. 3.31 to 4.10
  246. twin turbo 302
  247. weird question but i must ask
  248. injectors: 24lb vs. 30lb
  249. help..fan hiting shroud on 91 mustang gt
  250. having problems
