View Full Version : 5.0 Mustang
  1. how to fix my door?
  2. How many amps?
  3. How do I tighten the rear shocks?
  4. tire gear combo
  5. New motor mounts
  6. Quite Possibly the Strangest Thing...HELP!
  7. charging problem, any ideas??
  8. MOVED: holy crap thats expensive
  9. 347 prices
  10. Ground wire gauge question????
  11. Best setup for drag
  12. temp question?
  13. Window motor removal, please help
  14. engine codes
  15. Help!!! Weird thing on my stang
  16. belt to bypass ps, smog, and ac
  17. do i need to get upgraded axles
  18. Strange threaded 'sensor'(?) with a ball in it. Attaches to NSS on T5 maybe?
  19. aod shift improver
  20. F***IN Header Bolt!
  21. subframe connectors
  22. Quick fitment question
  23. bad luck
  24. Transmission question
  25. Smog Pump problems
  26. left tail light out?
  27. nitrous question
  28. Need Transmission help !!!
  29. Side exit exhaust on a fox
  30. the shakes UPDATED
  31. Front Struts ?
  32. steering shaft u joint specs; what r they?
  33. Possitive battery cable
  34. In the middle of a build plz help!
  35. AODE acting up...
  36. Smoke coming from vent - Help!
  37. Intake Gasket Differences?
  38. Oil Return Grommet For SC??
  39. AOD SHIFT PORBLEM
  40. what do you think about this?
  41. ADJUSTABLE VALVETRAIN
  42. What Brand lifters
  43. amazing power gains from a diff tuner
  44. Lots of questions regarding upgrades...
  45. which is better/what else needed?
  46. Car Idles at 3k!!! Help
  47. 86 fuse digram
  48. Fubar'd steering.
  49. What are the best plugs to run with wet nitrous?
  50. Where does the starter get its power from?
  51. another gauge question
  52. Best way to make clearance for the h-pipe to transmission crossmember.
  53. FINALLY fixed the Mustang!!
  54. 88 mustang starter not engaging?
  55. I can't find my oil leak!!
  56. y lifters calapsed
  57. Does this bump steer look right? UPDATED W/ PICS
  58. paint wheels?
  59. vacuum leak
  60. tire size?
  61. What I found when I took apart my engine - Suggestions wanted
  62. engine rebuild question...
  63. Replacement console for a '94 Convertible?
  64. manifold gaskets
  65. 140 speedo install wtf
  66. MSD Dizzy Gear
  67. replacing ignition coil
  68. AC harness
  69. GETTING READY TO SPRAY
  70. 50resto headlight kits
  71. something on my exhaust broke and i dont know what it is help please
  72. gt40p headers
  73. Reverse lights not working
  74. just bought my 5.0..few issues
  75. IAC with B303 Cam
  76. oops
  77. Need suspension help!
  78. wireing question
  79. A/C not working
  80. 93 pollution pump
  81. need pics of your fox body 5.0 engine
  82. Dash install now AC control issue
  83. Smog elimination
  84. 5.0 and a auto trans
  85. EEC
  86. new rebuild wont start
  87. fpr guage
  88. Will it pass smog?
  89. F P R help
  90. How to comp test?
  91. The perfect engine t-stat?
  92. AOD TV Cable Adjustment & rpm
  93. Help with my fuel pressure regulator!
  94. 347 in a street strip car
  95. so i finished
  96. some new info on her:)
  97. Shaking Mustang?
  98. two problems / questions or w\e
  99. front brake calipers
  100. heater core bypass
  101. squeeking sound...HELP!! please =)
  102. anyway .....?
  103. inline fuel pump issues
  104. I need pics from you procharger ppl!!
  105. Installing gear and lowering springs
  106. One leak stops and another starts.
  107. block prep, water pits/ water in the cylinder help!
  108. Fuel Pump died
  109. MOVED: 1/8th mile EST.??????
  110. 93 airbag to tilt???
  111. k-member
  112. Gear ?'s
  113. Is no sway bars okay?
  114. STALL?
  115. clutch issues
  116. i have a leaning condition on my 88 lx
  117. cobra grill insert??
  118. fuel rails
  119. Stiff Clutch
  120. intake/headers , ca smog legal?
  121. t5 tranny: rebuild or aftermarket
  122. BELT SIZE
  123. fuel filter? ringing noise in my speakers
  124. seafoam
  125. FOrd Falcon parts car?
  126. Quick question
  127. fresh rebuild..wont run....
  128. fuel pressure?!
  129. How to remove window trim
  130. Starting Issues Still
  131. Starter and fuel line routing suggestions please
  132. new engine
  133. suspension question??
  134. somebody please tell me what is wrong!!
  135. Exterior Rear View Mirror Paint ?
  136. Car dies when I come to a stop or idle it for a minute
  137. cai
  138. suggestions on my build idea :)
  139. how much would my ET drop...
  140. Leaking tranny fluid
  141. overheating problem
  142. Soft pedal with brakes
  143. 85 roller cam block Q
  144. TKO600 crossmember question
  145. coolant in my oil :( :(
  146. truck head to gt-40p
  147. strut dust boot?????
  148. few quick questions
  149. 94 gt and 94 cobra
  150. tranny fluid
  151. Everyone's Got One
  152. CHANGING YOUR CAM MADE EASY.
  153. What cam to get?
  154. Might Install Header Gasket myself....
  155. jegs max box intake?
  156. Car stops running when hot
  157. 86 4 banger to V-8 Power Steering Question
  158. Strut Tower Brace...worth it?
  159. Rear wheel and tires
  160. 302 front brackets
  161. 1995 Mustang issues
  162. MOVED: what does it take....
  163. Help ASAP "quick Pulley question"
  164. Replacing Harmonic Balancer
  165. Temp Sensor/Sending Unit
  166. Overheating question.
  167. Body Repair
  168. radio wiring diagram?
  169. Wires
  170. MOVED: Pics of my stang
  171. Rectangle exhaust ports???
  172. Dash lights wiring diagram
  173. fuel pump?
  174. MOVED: supra for 5.0
  175. Can't keep my car charged
  176. shorter belt No air pump
  177. anyway?
  178. SHOULD I NOTICE A DIFFERANCE?
  179. TRANNY EXPERTS
  180. Seat belt removal
  181. 5.0 coversion
  182. turbo manifolds
  183. Oil Pan question ?
  184. leaking oil
  185. Starter question
  186. Timing
  187. Installing TPS
  188. airbag question
  189. MOVED: my ex just took my car
  190. a/c eliminator install
  191. shift kit?
  192. clutch specs for a tremec
  193. Drag slick size Question
  194. Were to put nitrous arming switch?
  195. how in the hell do you remove the body moldings?
  196. Beeping sensor help plz!!
  197. Leakin Antifreez Question.
  198. LT Headers Install
  199. clutch adjustment
  200. Backfire problem
  201. Track time EST.????
  202. timing confermation
  203. Installing a torque converter?
  204. MOVED: What Color?
  205. MOVED: Paint job cost
  206. listen to this $hit
  207. typhoon intake question
  208. should i go with a nos system?
  209. Best way to align mufflers and tailpipes?
  210. Intake V K&N V Factory.. Need a filter what to do??
  211. is it bad
  212. 347 stroker kit?
  213. rear end lockers. opinions please
  214. Lifter Tick
  215. A/C question.
  216. Edelbrock Performer intake question
  217. Some questions/suggestions bout buildn her up :)
  218. 4.6 and 3650 in my 89 notch
  219. losing power at a constant speed
  220. headers.....
  221. Need instructions
  222. Suspension questions
  223. would this harness work?
  224. 2k explorer motor swap
  225. nawwwwwwwzzzzzzzzzzz
  226. Studs and gaskets
  227. question..?
  228. March Engine brackets?
  229. its almost ready to go back together (updated 8/10)
  230. Decision
  231. Summit high capacity water pump
  232. wtf will be next
  233. 90-93 gauge cluster? asap please
  234. Fuel pump size?
  235. No voltage at TPS
  236. ignition problem
  237. MOVED: My project progress - Almost!
  238. torque box repair
  239. What color is the Volt lead ?
  240. Maybe valve float? Need help!!!!
  241. Rear Control Arm Bushing
  242. Wire harness
  243. Installing a 460 in a Fox Coupe?
  244. transmission install question
  245. Nex wet nitrous install help pics
  246. tranny problems
  247. Car Dies While Driving (Help!) TFI?
  248. brakestand rpm level
  249. Newbie here, need some advice
  250. Electric Fan Install Help
