View Full Version : 5.0 Mustang
  1. Rear Taillights???
  2. fuel pump for carb
  3. Next Mod Suggestions?
  4. HEADS AND GEARS?
  5. Supercharger Powerdyne any good?
  6. 460 question
  7. Problem SOLVED!!
  8. HELP!
  9. removing fan
  10. Grinding Noise is....?
  11. tremc 500 trans
  12. might have a problem with the diff
  13. Water Pump Bolt Kit
  14. Help
  15. How much horsepower can a stock fuel pump handle?
  16. a/c removal
  17. Headers.
  18. rear differential question
  19. bushings?
  20. Problem at full throttle
  21. exhaust choices
  22. 1995 gt 5.0 drivetrain to fox body swap
  23. bare bones street car
  24. tune
  25. new headers and now a weird noise
  26. Could someone please check my overhaul shopping list? Thanks!
  27. Header gasket/exhaust question
  28. Mustang differece help
  29. My 5.0 Is Shaking + IDLE Ruff
  30. mods that should be done?
  31. Ok big problem...
  32. gearing question?
  33. rear sway bar??
  34. electrical problem
  35. Need vacuum diagram for 1987-1990 5.0
  36. Clutch cable
  37. MSD
  38. stock coil
  39. possibe wheel probs on fox w 17"
  40. super chargers
  41. Twisted Wedge vs Vic Jr's
  42. T-5 to T-56 Swap
  43. Can I run MAF without 02 sensors?
  44. Mounting Subframe Connectors today!
  45. Motor Mounts
  46. FMU question (getting rdy to install s/c)
  47. White smoke????
  48. Pedistal or stud?
  49. New Clutch????
  50. Pics of parts of the motor. (Previous question)
  51. M112 on a 95 GT
  52. Exhaust gasket help
  53. problem starting/running
  54. Injector Question
  55. Need help guys - diagnose this..
  56. AOD removal
  57. REMANUFACTURED MOTOR
  58. New Intake
  59. autolite 26s?
  60. 80mm TB
  61. radiator
  62. Quick Question: Oxygen sensor thread size
  63. Whats the scoop on DSS blocks any good?
  64. Engine bolts need help ASAP!
  65. Maf Cleaning
  66. syncros replaced in a t-5 trans price?
  67. A/C question... kinda
  68. Control arm install
  69. FLEXPLATE..?
  70. cai question
  71. 14psi on 351w
  72. 75mm maf
  73. '95 Boss Shinoda charging problems...
  74. New carb
  75. Code 63 - TPS
  76. shaking...?
  77. smells like an oil deprived lawnmower?
  78. Does anybody know what cam this is??
  79. Need help with MM Adj RLCA's
  80. 94 gt is getting no spark?
  81. Fuel pump relay shuts off after 1 second
  82. 03 mach1 driveshaft fit?
  83. whistling noise?
  84. Exaust Nuts??
  85. Bumper cropping
  86. Got it tuned finally
  87. Does anyone run an electric water pump?
  88. Overheating
  89. in middle of motor pull
  90. Brake booster help?
  91. Need quick identification help w/ plugs(pics)
  92. 302 build help
  93. Odometer Question
  94. 5 crank startup please help!
  95. Should I take my mustang to the Ford garage?
  96. manual vs. electric choke
  97. Crank Case Ventilation
  98. H pipe or X pipe?? advise please =D
  99. PLEASE HELPPP
  100. helppppp
  101. Stock Heads
  102. Help quick, computer removal
  103. newbe ??
  104. sparkplugs
  105. Need engine date code/casting location
  106. Intermittent fuel pressure
  107. When in Reverse sounds horrible
  108. wierd smell anyone know what i can check..
  109. AOD Rebuild Ripoff? UPDATE
  110. Fluids
  111. coolant leak, found where it leaking in this pic
  112. easy dumb ?
  113. what to do
  114. GT40 heads/intake
  115. Trick flow track heat H/I
  116. Headlight wiring issue **SOLVED**
  117. How reliable are fox body Stangs?
  118. whats the trick to getting the damn h pipe out???
  119. BBK UNIVERSAL FUEL RAIL
  120. Anyone run a 1-wire HEI distributor?
  121. Intake poll
  122. got an 89 LX
  123. acessory brackets
  124. would you rather....
  125. TW vs AFR vs RHS
  126. rear shock or strut ceazed. need help!!!!!
  127. intake bolt torque specs
  128. how do you burnout/heat the tires up?
  129. built AOD with widegearset and Slicks?
  130. FRONT OR REAR?
  131. (not ur usuall)t5 problem, need just some ideas
  132. battery light comes on at 4000+ rpm... why?
  133. Brakes and shock replacement
  134. Heater Core Bypass Removal?
  135. Another idle question... please help
  136. Started the install on my 4:10's today and need some help.
  137. whats the differance between my gt and my 305 auto fired bird drivetrainwise?
  138. Car is Slow
  139. Stupid question but im in need of help
  140. 5.0 radiator size?
  141. MOVED: 97% Done *PICS*
  142. what auto transmission for 351w.
  143. Well I bought it...87 LX 5.0
  144. MOVED: 89 GT 5.0 A/C Kit
  145. One more wiring question
  146. SUSPENSION??????
  147. help!!!
  148. Adding relays to Mass air/o2 sensors
  149. wont start or go
  150. I Need New Battery Cables Plz Help
  151. pre ignation.
  152. 5.0's & 302's
  153. need help right now
  154. should i gutt my cats???
  155. temp help!!
  156. Replaced alot. Still crappy brakes! HELP!!!
  157. trouble installing transmission!!
  158. Need Convertible Top Switch 86 GT
  159. anyone using canfield heads? help with 351w heads?
  160. aod trans help
  161. mgw shifter
  162. Aluminum Control arms
  163. rear window defrost relay
  164. e7 heads on a 86?
  165. 460
  166. '91 GT Heater Control Issue
  167. Long Tube Headers W/C4 in a Fox
  168. heads
  169. Any truth...
  170. HELP!!! Need a Diagnosis
  171. added cooland 2 weeks ago now says low cooland
  172. Sea foamed the car today..
  173. Twin Turbo Question
  174. what do you all think
  175. Sits wierd.
  176. 5.0 HO Engine
  177. newb questions
  178. best cam for rhs heads?
  179. sagging doors
  180. good size maf
  181. electric water pump?
  182. anyone have a sumped fuel tank?
  183. More new toys.. got a few questions
  184. You 5.0 guys may be intrested.
  185. humming sound
  186. cigarette lighter and power outlet
  187. 303 vs TFS stage 1
  188. lookin at a 79 what kind of mpg?
  189. under drive pulleys
  190. HELP!!
  191. 1989 5.0 Trans Question
  192. RAISING YOUR GAS PEDAL?
  193. AOD tailshaft length?
  194. idle?????????????????????????????
  195. Electric fan...
  196. MOVED: Pulled On a Trailblazer SS!
  197. Fuel pump relay
  198. trunk latch (in corro with hatch latch)
  199. FRPP B303
  200. Another damn sea foam question...
  201. Hatch Latch
  202. MOVED: how a car's engine works
  203. Building A block from scratch
  204. c clip eliminator?
  205. 6 speed trany?
  206. rpms
  207. 86 mustang weight? and weight reduction help.
  208. Need help selecting a cable...
  209. kyb struts/shocks
  210. Car Shaking - Shifter Shaker 0 (Very COnfused) NEED HELP!
  211. clunky noise.
  212. Setting up gears
  213. need help, i have no idea
  214. Which Cam?
  215. Lugnuts
  216. speedo gear
  217. wheel hop and performance upgrades ?
  218. Putting in Rear Suspension
  219. Faint Rattle - Driving Me Crazy! Please assist
  220. MOVED: 1992 HEADLIGHT???
  221. bad headers?
  222. timing q's
  223. SVO Brake question
  224. another clutch issue. sticking?
  225. Stall Converter?
  226. getting paid, time to order some stuff
  227. What brand of clutch is best?
  228. MOVED: SLP LOUDMOUTH EXHUAST?
  229. GT40P ENGINE SWAP DONE!
  230. MOVED: what mods?
  231. f..ked up clutch
  232. 8 pin brown round connector plug? I don't have it?
  233. Nitrous Application Question
  234. 3" H-pipe or X-pipe w/ dumped flows. would they be to loud for the street?
  235. light issues
  236. E Brake Light Wont Go Off!!!
  237. tko 600 clutch
  238. finally gettin ready to drop in new motor
  239. Any way?
  240. MOVED: my cupholder is broken!
  241. MOVED: what should i pay for bbk stuff? and install of subframes? and how much spray?
  242. intake leak?
  243. MOVED: Filling fuel tank. Spill or no spill
  244. Piston Rings????
  245. Clutch installation problems **FIXED
  246. Another h pipe quesiton, what is.....
  247. car cut's out at any rpm above 2500
  248. where is the relay's for the convertable top? 90 5.0
  249. Carb question
  250. Catback questions
