View Full Version : 5.0 Mustang
  1. header question
  2. 347ci wanting to go turbo
  3. Clutch quadrant, firewall adjuster ?'s
  4. Long Tube VS Shorty
  5. 87 steering wheel on a 86?
  6. NeEd HeLp!!!!
  7. Lookin to turbo my 90 gt 302 any help?
  8. problem with front strut tower brace for 94-95 stang gt?
  9. 1262r's or 1265 intake gaskets?
  10. leaky macs
  11. Any idea?..
  12. What stall speed?
  13. need help with auto tranny!
  14. Big problem need help
  15. Back from the Dyno
  16. is this short shifter any good?
  17. a/c help
  18. driveshaft removal
  19. T-5
  20. GT-40 cast iron heads on 347 HELP!!
  21. hydraulic clutch
  22. roush side exaust skirts, and rear bumper
  23. need help with passenger door
  24. Leaking Tranny Cooler Line *help*
  25. shutting that tube going to the exhaust???
  26. wont start
  27. exhaust discharge
  28. I got this code from my computer DTC222
  29. 351 heads
  30. Car overheating! Please help!!
  31. ? for Carb Tuners
  32. need to know??clutch adjustment
  33. all sortsa questions..
  34. oil leak
  35. Hurst QuarterStick shifter?????????
  36. axle bushings..NAPA?POLY's?FORD?
  37. 7.5 to 8.8 rearend
  38. Whats this connector??
  39. update from last night code 33
  40. Difference b/t Mustang dyno and regular dyno?
  41. intake still making a noise
  42. Suspension Ideas?
  43. 91 5.0 stuff
  44. Installing poly mounts, Is grease needed?
  45. Trying to remove front & rear window molding
  46. Back firing problem
  47. Convertible Top Latch Question???
  48. timming and fuel preasure?
  49. Procomp Aluminum heads?
  50. couple ?'s
  51. Thermactor Plug's
  52. Header Torque Specifications??
  53. Gauge cluster removal.
  54. which wideband for tweecer RT
  55. chassis braces???
  56. SN 95 Cobra "Crabs"
  57. using a MM adjustable LCA to raise ride height???
  58. clutch cable problems..
  59. worn out timing chain?
  60. shes at the shop now what
  61. hey guys quick question before i go to junkyard
  62. 94-95 Fuel Lines
  63. Oil pump shaft Help?!?!?!
  64. suspension suspicion
  65. Who runs a 347?
  66. stock interanls?
  67. dyno tune vs. DIY tune
  68. tranny question
  69. Dash Removal
  70. Loose rod???
  71. Throw out bearing went up
  72. Just getting started...
  73. starving for fuel?
  74. Shifting Issue
  75. emissions?? pahhlease
  76. Relation between cam and air/fuel ratio and such...
  77. CAI Not Starting
  78. Oil pressure problem and gas consumption problem.
  79. 85/90 GT questions
  80. Mustang going downhill!
  81. MOROSO TRICK SPRINGS or 4cyl springs?
  82. 500hp rear end build q's?
  83. High Idle
  84. Hatch back quarter windows
  85. Just wondering about a few codes i got
  86. newbee performance questions
  87. SHIFT KIT STOCK TRANNY?
  88. Trick flow intake clearence
  89. Putting Timing chain on.. Need a little help
  90. how much vac?
  91. Air/smog pump
  92. idle prob... and yes, I did read the stickys
  93. has anyone else done this?
  94. Belt size?
  95. how does it work
  96. tech ADVICE please, vortec with my 5.0
  97. 1979 coupe exhaust
  98. Thoughts on Patriot Heads?
  99. Fuel Preasure
  100. radiator flush
  101. Shift light
  102. Write-ups on starting mods?
  103. Fuel pressure regulator?
  104. HELP
  105. transmission problem? Car shakes around 45mph
  106. Clutch Adjustment
  107. Underdrive Pulley Options
  108. Couple Questions
  109. New Balancer
  110. installing MAF and TB before h/c/i???
  111. Hard to start when cold
  112. Video of my engine... what is this noise? Valve tap?
  113. Have ZEX wet kit...
  114. Rack and Pinion Help
  115. Stock ride height.
  116. weird noise
  117. floor pan? question
  118. cam help
  119. need a little help plzz
  120. help with my 5.0!
  121. Auto tranny
  122. 98 Explorer 5.0 block
  123. is this a good tranny?
  124. Questions from a newbie...
  125. Trick flow valve covers
  126. power steering pump
  127. strut bushings/caster camber plates
  128. New Member- Anyone bought a 454 stroker?
  129. 500hp aod rebuild kit
  130. '89 Gt Rear Brake Question/Help
  131. New springs for my 1995 convertible 5.0
  132. water pump
  133. Fuel pressure regulator?
  134. Best top end kit
  135. Will stock valve covers from a 91 stang work with e303 cam and 1.7rr?
  136. will this rear tire combo fit?
  137. question about CAI and the throttle body
  138. Harmonic balancer?
  139. C&L maf kit???
  140. quick question
  141. upper torque box reinforcements, how necessary??
  142. Clutch adjustment
  143. Aurora Wire sets, Blue streak cap
  144. cam install
  145. still need help! wont start...
  146. sensor and bracket for MAF
  147. where can i just buy slp mufflers?
  148. Broke a damn rolloer rocker pedestal
  149. Passenger side sits lower than driver. Help!
  150. clunking noise
  151. do i need new axles??
  152. throttle body, and heads?
  153. SLP loudmouth 1 or 2 with catted X
  154. remote key fob
  155. New question
  156. Brakes
  157. Header Questions
  158. Proper tv cable adjustment?
  159. clutch, flywheel, and yoke
  160. ECM Flash for 1995 GTS 5.0 Running Rich
  161. 460?
  162. Idle sticking at 2k rpms
  163. Suspension time, need a expert.
  164. Timing question
  165. Oil leak - rear of intake?
  166. Help with Oil Pan I.D.
  167. push rod guide plate problem
  168. tapping noise from valve.
  169. Timing issue?
  170. LSD
  171. Cooling problem
  172. shaking noise up hill
  173. Vaccume Diagram
  174. what year is my AOD?
  175. 6mo project still hasn't started
  176. rocker upgrade
  177. Spark plugs for nitrous application
  178. sn95 semi daily driver question
  179. What would happen if..
  180. Odd Stutter ? A/C Compressor ?
  181. 6spd.HD T-56tremec or Cobra Rtremec HD 5spd
  182. just put new fan motor in.
  183. Gears Growl
  184. Putting my motor back in today
  185. 1995 GT 5.0 Will Not Start!!! Help
  186. needs an overhaul??
  187. 4 cylinder to 5.0 Carb wiring
  188. AOD Rebuild
  189. 10.5 on stock rear end
  190. Big effin problem. need help
  191. GT40 Heads Combustion Chamber Size
  192. How can I get my gauges to work (EFI to Carb)
  193. Need ideas on how to free a rusted sleeve.
  194. broke a rearend bolt
  195. Cobra vs. 5.0HO computer
  196. my upgrade ideas
  197. front brakes
  198. ITS ALIVE!!!
  199. replace or not
  200. get new interior moldings or paint the stock ones?
  201. K member
  202. gear bearing
  203. Installing TFS timing chain
  204. Need Help
  205. brand of gears?
  206. Water Pump/Cracked/Chipped Block
  207. fuel problem?
  208. Oil Pump with no engine hoist. Can be done??
  209. about to install my new fuel pump
  210. Dropping k-member???
  211. Flywheel ?
  212. Heat shrink for fuel pump swap
  213. GOOD DRIVERS ONLY
  214. new or rebuild
  215. Help!!!!
  216. Will this fit
  217. gasket/bolt/rocker questions
  218. a9p ecu? need to change with t-5 swap
  219. RE: Side Window
  220. Re: SuperCharger
  221. Fuel Pump eccentric?
  222. Trouble taken off brake lines off proportion valve
  223. mufflers
  224. crank oil slinger
  225. question about upgrade
  226. New Headlights
  227. 89 brakes
  228. Which oil/lubricants do you use
  229. 88 t-bird 5 speed into a 92 mustang???
  230. Trottle body size...?
  231. Which Headlights..!?
  232. question about engine
  233. 4 Cyl T5 Swap > Pilot Bearing?
  234. Side Exhaust?
  235. hurst shifter
  236. Need some quick help
  237. PRO come heads...
  238. Will this gasket kit work?
  239. where to begin
  240. Oil Pan Gasket
  241. Crank but no Spark.
  242. car wont start by key
  243. I know another gear question.
  244. UPDATED Copped A 351W FTW
  245. 95 v8 swapped into a 96 v6
  246. Kenne Bell twin screw for the 5.0
  247. Help with 1990 5.0 door seal leak
  248. Found a real 93 Cobra intake
  249. GOT HER RUNNIN TODAY
  250. How do I tell what kind of Trickflow heads I have?
